Google Nest Audio and Wyze Cam Pan v3 Bundle for Smart Home Security
Enhance your smart home security with the perfect combination of Google Nest Audio and Wyze Cam Pan v3. This bundle offers seamless integration of voice assistant capabilities with advanced, weather-resistant security cameras, providing you with a comprehensive smart home experience.
Wyze Cam Pan v3: Advanced 360° Security Camera
All-Around Surveillance with Pan & Tilt
The Wyze Cam Pan v3 is a versatile indoor/outdoor security camera featuring a 360° horizontal pan and 180° vertical tilt. This allows you to monitor every corner of your home or property without blind spots. With a fast rotation speed of up to 110° per second, it can quickly track movement for enhanced security.
Durable and Weather Resistant
Built with a polycarbonate body and IP65 weather resistance, the Wyze Cam Pan v3 is designed to withstand harsh outdoor conditions, including rain and snow. For outdoor use, pairing it with the Wyze Outdoor Power Adapter (sold separately) ensures reliable power supply.
Crystal Clear 1080p HD Video & Night Vision
Equipped with a 1/2.9" CMOS image sensor, the camera delivers sharp 1080p HD video at 20 fps during the day and 15 fps at night. Four IR LEDs provide night vision up to a considerable range, ensuring your home is monitored even in complete darkness.
Two-Way Audio with Noise Cancellation
Communicate directly through the camera using its built-in speaker and microphone. The Wyze Cam Pan v3 supports two-way audio with noise and echo cancellation, perfect for interacting with family members or deterring intruders.
Smart Home Integration
The camera integrates smoothly with Alexa, Google Assistant, and IFTTT, allowing voice control and automation within your smart home ecosystem. It supports 2.4 GHz Wi-Fi connectivity and works with Android 9.0+ and iOS 15.0+ devices.
Storage and Alerts
Wyze Cam Pan v3 supports local storage up to 256 GB microSD cards and offers push notifications for real-time alerts. Video encoding uses H.264 for efficient streaming and storage.
Wyze Cam Pan v3 + 30-Day Cam Plus Bundle: Enhanced Security Experience
For those seeking an all-in-one package, the Wyze Cam Pan v3 + 30-Day Cam Plus Bundle includes the camera along with a 30-day trial of Cam Plus, Wyze’s subscription service that unlocks advanced features such as person detection, package detection, and unlimited video length.
What’s Included in the Bundle?
- Wyze Cam Pan v3 (available in Black or White)
- 6-foot micro USB cable
- Power adapter
- Mounting kit
- Quick start guide
This bundle is ideal for users who want to maximize their security camera’s capabilities right out of the box.
Google Nest Audio: Voice Control for Your Smart Home
While the Wyze Cam Pan v3 secures your home visually, Google Nest Audio provides the voice assistant power to control your smart devices hands-free. Use Google Assistant to:
- Control your Wyze Cam Pan v3 with voice commands
- Receive security alerts and status updates
- Manage other smart home devices like lights, thermostats, and locks
Together, Google Nest Audio and Wyze Cam Pan v3 create a smart home security system that is both intuitive and powerful.
Why Choose This Bundle for Smart Home Security?
Combining Wyze Cam Pan v3’s robust, weather-resistant design and 360° coverage with Google Nest Audio’s voice control capabilities offers a seamless, smart security solution. Whether you want to monitor your pets, keep an eye on your property, or interact remotely, this bundle covers all bases.
Additional Accessories for Wyze Cam Pan v3
- Wyze Cam Pan v3 Skins by dBrand: Customize and protect your camera with stylish vinyl skins available in Green Camo and Triple Black.
- Wyze Cam Pan v3 USB Cable: Replacement USB cable to keep your camera powered without interruption.
- Pan v3 + Lamp Socket v2 Bundle: Power your Pan v3 camera through a lamp socket without needing an outlet, perfect for flexible installation options.
Product Summary
Product | Key Features |
Wyze Cam Pan v3 | 360° pan, 180° tilt, IP65 weather resistant, 1080p HD, two-way audio, night vision |
Wyze Cam Pan v3 + 30-Day Cam Plus Bundle | Includes Cam Plus subscription, full mounting kit, power adapter |
Google Nest Audio | Voice assistant, smart home control, integrates with Wyze Cam Pan v3 |
Secure your home with the Wyze Cam Pan v3 and Google Nest Audio bundle — the smart, reliable, and easy-to-use solution for modern home security.
What is included in the Google Nest Audio and Wyze Cam Pan v3 bundle?
The bundle includes a Wyze Cam Pan v3 security camera (available in Black or White), a 6-foot micro USB cable, a power adapter, a mounting kit, a quick start guide, and Google Nest Audio for voice control and smart home integration.What are the key features of the Wyze Cam Pan v3 security camera?
The Wyze Cam Pan v3 offers 360° horizontal pan, 180° vertical tilt, IP65 weather resistance, 1080p HD video, night vision, two-way audio with noise cancellation, and smart home integration with Alexa, Google Assistant, and IFTTT.Is the Wyze Cam Pan v3 suitable for outdoor use?
Yes, the Wyze Cam Pan v3 is designed with a durable polycarbonate body and IP65 weather resistance, making it suitable for both indoor and outdoor use. For outdoor installation, it is recommended to use the Wyze Outdoor Power Adapter (sold separately) for reliable power.How does the Wyze Cam Pan v3 provide night vision?
The Wyze Cam Pan v3 is equipped with a 1/2.9" CMOS image sensor and four IR LEDs, delivering clear 1080p HD video during the day and night vision up to a considerable range, ensuring your property is monitored even in complete darkness.Can I communicate through the Wyze Cam Pan v3 camera?
Yes, the Wyze Cam Pan v3 features two-way audio with noise and echo cancellation, allowing you to communicate directly through the camera using its built-in speaker and microphone.Does the Wyze Cam Pan v3 support smart home integration?
Absolutely. The Wyze Cam Pan v3 integrates with Alexa, Google Assistant, and IFTTT, enabling voice control and automation within your smart home ecosystem. It supports 2.4 GHz Wi-Fi and works with Android 9.0+ and iOS 15.0+ devices.What storage options are available for the Wyze Cam Pan v3?
The Wyze Cam Pan v3 supports local storage with microSD cards up to 256 GB and provides push notifications for real-time alerts. Video encoding uses H.264 for efficient streaming and storage.What is the Wyze Cam Pan v3 + 30-Day Cam Plus Bundle?
The Wyze Cam Pan v3 + 30-Day Cam Plus Bundle includes the camera and a 30-day trial of Cam Plus, Wyze’s subscription service that unlocks advanced features such as person detection, package detection, and unlimited video length.How does Google Nest Audio enhance smart home security?
Google Nest Audio acts as a voice assistant, allowing you to control your Wyze Cam Pan v3 and other smart home devices hands-free. You can use voice commands to receive security alerts, check camera status, and manage devices like lights, thermostats, and locks.Are there additional accessories available for the Wyze Cam Pan v3?
Yes, accessories include Wyze Cam Pan v3 Skins by dBrand for customization and protection, replacement USB cables, and the Pan v3 + Lamp Socket v2 Bundle, which allows you to power the camera through a lamp socket for flexible installation.Why should I choose the Google Nest Audio and Wyze Cam Pan v3 bundle for home security?
This bundle combines the robust, weather-resistant Wyze Cam Pan v3 with Google Nest Audio’s voice control, offering seamless integration, comprehensive coverage, and intuitive smart home security for monitoring your property, pets, and interacting remotely.
