Smart Home Package: Google Nest Hub & Wyze Devices Bundles
Smart Home Package Featuring Google Nest Hub and Wyze Devices
Create a seamlessly connected smart home environment with the perfect combination of Google Nest Hub (2nd Gen) and Wyze smart devices. This package offers comprehensive home monitoring, entertainment, and voice-controlled automation to elevate your daily living experience.
Google Nest Hub (2nd Gen) + Wyze Bundles: The Heart of Your Smart Home
All-in-One Smart Display and Camera Control
The Google Nest Hub (2nd Gen) combined with Wyze devices is designed to keep your home connected and secure while providing entertainment and smart home control at your fingertips.
  • Integrated Wyze Cam Control: Easily view and manage your Wyze Cam v3 or Wyze Cam Pan v3 live streams directly on the Nest Hub’s vibrant display.
  • Voice and Touch Control: Use Google Assistant voice commands or the touchscreen to control your Wyze cameras, smart bulbs, plugs, and more.
  • Privacy First: A mic switch lets you turn off the microphone anytime for added privacy.
  • Enhanced Audio: Enjoy 50% more bass than the original Nest Hub, perfect for music, podcasts, or alerts.
  • Sleep Sense Assistant: Benefit from Google’s Sleep Sense technology to monitor and improve your sleep quality (free trial until 2023).
Bundle Options to Fit Your Needs
Choose from various bundles including:
  • Nest Hub + Wyze Cam v3 or Cam Pan v3
  • Nest Hub + smart bulbs (A19 or BR30)
  • Nest Hub + outdoor plugs or video doorbells
This flexibility allows you to customize your smart home setup with the devices you need most.
"Your camera watches the kids. Your kids watch the screen. The screen watches your camera. It’s the circle of life."
Family enjoying smart home with Google Nest Hub and Wyze cameras Alt text: Family using Google Nest Hub and Wyze cameras in playroom
Wyze Cam v4 Home Security Bundle: Crystal-Clear Protection Day and Night
Advanced Security Camera with 2.5K QHD Resolution
Wyze Cam v4 offers unmatched home security with features designed to keep your property safe and monitored around the clock.
  • 2.5K QHD Video Quality: Capture every detail with crystal-clear resolution.
  • Enhanced Color Night Vision: See vibrant colors even in low light conditions.
  • Motion-Activated Spotlight: Automatically lights up when motion is detected to deter intruders.
  • Person Detection: Smart alerts that distinguish people from other movement.
  • Weather Resistant (IP65): Suitable for both indoor and outdoor use.
  • Wi-Fi 6 Support: Faster and more reliable connectivity.
  • Compatibility: Works seamlessly with Alexa and Google Assistant for voice control.
Flexible Mounting Options
Mount your Wyze Cam v4 on walls, ceilings, or use the magnetic mount for easy placement anywhere around your home. Outdoor lifestyle with Wyze Cam v4 monitoring home Alt text: Wyze Cam v4 mounted outdoors for home security
Wyze Sense Hub: The Central Command for Home Monitoring
Connect and Control Your Sensors
The Wyze Sense Hub acts as the brain of your home monitoring system, linking all your Wyze sensors and sending instant alerts to your phone.
  • Supports Up to 100 Sensors: Expand your system with door/window sensors, motion detectors, and more.
  • Multiple Communication Methods: Ethernet, Wi-Fi (2.4 GHz), Bluetooth 4.1 + BLE 5.1, and 915MHz RF.
  • Built-in Rechargeable Battery: Provides up to 10 hours of backup power.
  • Indoor Use: Compact and discreet with a matte white and grey finish.
  • Loud Siren: 88db alarm to alert you of any security breach.
This hub ensures your smart home devices work in harmony for maximum security and convenience.
Enhance Your Smart Home Experience with Google Nest Audio + Wyze Bundles
Premium Sound Meets Smart Control
Complement your smart home setup with Google Nest Audio paired with Wyze devices for immersive sound and voice control.
  • Rich, Room-Filling Sound: Crisp highs and deep bass for music, podcasts, and more.
  • Adaptive Sound: Automatically adjusts audio based on your environment.
  • Built-in Google Assistant: Hands-free voice commands to control Wyze cameras, bulbs, plugs, and other smart devices.
  • Privacy Controls: Hardware mic mute switch for peace of mind.
  • Multiple Color Options: Chalk, Grey, and White to match your home decor.
Choose bundles that combine Nest Audio with Wyze cameras, smart plugs, or bulbs to create a fully integrated smart home ecosystem.
Why Choose This Smart Home Package?
  • Seamless Integration: Google Nest Hub and Nest Audio work flawlessly with Wyze’s award-winning cameras and smart devices.
  • Comprehensive Security: From high-resolution cameras to a central monitoring hub, your home stays protected 24/7.
  • Voice and App Control: Manage your entire smart home with simple voice commands or the Wyze app.
  • Customizable Bundles: Pick the combination that fits your lifestyle and budget.
  • Enhanced Lifestyle: Enjoy entertainment, security, and convenience all in one package.
Transform your living space into a smart, secure, and connected home with this powerful Google Nest and Wyze smart home package.
Feature / ProductGoogle Nest Hub (2nd Gen) + Wyze BundlesWyze Cam v4 Home Security BundleWyze Sense HubGoogle Nest Audio + Wyze Bundles
TypeConnected HomeCamerasHome MonitoringPartnership Item
Price Range$99.00 - $190.99 (varies by bundle variant)$169.99$45.98$99.98 - $159.99 (varies by bundle variant)
Main ComponentsGoogle Nest Hub (2nd Gen) + Wyze Cam(s) or accessories4x Wyze Cam v4 + 4x 128GB MicroSD CardsWyze Sense Hub (central hub for sensors)Google Nest Audio + Wyze Cam(s) or accessories
Camera IncludedWyze Cam v3, Cam Pan v3, Cam OG, Video Doorbell variants4x Wyze Cam v4 (2.5K QHD, Color Night Vision)NoWyze Cam Pan v3 or Cam v4 (depending on variant)
Audio / SpeakerGoogle Nest Hub speaker with 50% more bass than originalNoNoGoogle Nest Audio speaker with room-filling sound
Voice AssistantGoogle Assistant built-inCompatible with Alexa and Google AssistantNoGoogle Assistant built-in
Smart Home ControlYes, control Wyze devices, lights, plugs, locks via Nest HubNoNoYes, voice control for smart home devices
Privacy FeaturesMic switch to turn off mic, clear Google Assistant historyNot specifiedNot specifiedMic mute switch, privacy controls
ConnectivityWi-Fi, integrates with Wyze devicesWi-Fi 6, wired power for camerasEthernet, Wi-Fi 2.4 GHz, Bluetooth, 915MHz RFWi-Fi (2.4/5 GHz), Bluetooth, Chromecast built-in
Night VisionDepends on Wyze Cam variant includedEnhanced Color Night VisionN/ADepends on Wyze Cam variant included
RecordingDepends on Wyze Cam variant included24/7 local recording, motion-activated recordingN/ADepends on Wyze Cam variant included
Additional FeaturesSleep Sense sleep assistant free until 2023Motion-activated spotlight, smoke & CO alertsSupports up to 100 sensors, 88db sirenAdaptive sound, stereo capability
Battery / PowerPowered deviceWired camerasBuilt-in rechargeable battery (10-hour backup)Powered device
Weather ResistanceDepends on Wyze Cam variant includedWired, outdoor compatibleIndoor use onlyDepends on Wyze Cam variant included
Included ItemsGoogle Nest Hub + Wyze Cam(s) or accessories4x Wyze Cam v4, 4x 128GB MicroSD CardsWyze Sense Hub, power adapter, Ethernet cable, decalsGoogle Nest Audio + Wyze Cam(s) or accessories
What is included in the Google Nest Hub and Wyze Smart Home Package?The Google Nest Hub and Wyze Smart Home Package includes a Google Nest Hub (2nd Gen) paired with your choice of Wyze smart devices such as Wyze Cam v3, Cam Pan v3, smart bulbs (A19 or BR30), outdoor plugs, or video doorbells. Bundle options allow you to customize your smart home setup to fit your needs.
How does the Google Nest Hub (2nd Gen) work with Wyze devices?The Google Nest Hub (2nd Gen) seamlessly integrates with Wyze devices, allowing you to view live streams from Wyze Cam v3 or Cam Pan v3 directly on the Hub’s display. You can control Wyze cameras, smart bulbs, plugs, and more using Google Assistant voice commands or the touchscreen interface.
Can I control Wyze devices with my voice using Google Assistant?Yes, you can control Wyze cameras, smart bulbs, plugs, and other compatible devices using Google Assistant voice commands through the Google Nest Hub or Nest Audio.
What privacy features are available on the Google Nest Hub and Nest Audio?Both the Google Nest Hub (2nd Gen) and Nest Audio include a hardware microphone mute switch, allowing you to turn off the microphone for added privacy whenever you choose.
What are the key features of the Wyze Cam v4 included in the security bundle?The Wyze Cam v4 offers 2.5K QHD video quality, enhanced color night vision, a motion-activated spotlight, person detection, weather resistance (IP65), Wi-Fi 6 support, and compatibility with Alexa and Google Assistant for voice control.
Is the Wyze Cam v4 suitable for outdoor use?Yes, the Wyze Cam v4 is weather resistant with an IP65 rating, making it suitable for both indoor and outdoor use.
What is the Wyze Sense Hub and how does it work?The Wyze Sense Hub is the central command unit for your home monitoring system. It connects up to 100 Wyze sensors, such as door/window sensors and motion detectors, and sends instant alerts to your phone. It features multiple communication methods, a built-in rechargeable battery for up to 10 hours of backup power, and an 88db siren for security alerts.
How many sensors can the Wyze Sense Hub support?The Wyze Sense Hub can support up to 100 sensors, allowing you to expand your home monitoring system as needed.
What are the audio features of Google Nest Audio in the smart home bundle?Google Nest Audio delivers rich, room-filling sound with crisp highs and deep bass. It features adaptive sound technology that automatically adjusts audio based on your environment and includes built-in Google Assistant for hands-free voice control.
Can I customize my smart home bundle with different Wyze devices?Yes, you can choose from various bundle options that combine the Google Nest Hub or Nest Audio with Wyze cameras, smart bulbs, plugs, or video doorbells to create a smart home setup tailored to your needs.
What are the benefits of choosing the Google Nest and Wyze smart home package?This smart home package offers seamless integration between Google Nest and Wyze devices, comprehensive home security, voice and app control, customizable bundles, and an enhanced lifestyle with entertainment, convenience, and peace of mind.
Is the Google Nest Hub (2nd Gen) suitable for entertainment purposes?Yes, the Google Nest Hub (2nd Gen) features enhanced audio with 50% more bass than the original, making it ideal for music, podcasts, and alerts, in addition to its smart home control capabilities.
Does the Google Nest Hub (2nd Gen) offer sleep tracking features?Yes, the Google Nest Hub (2nd Gen) includes Google’s Sleep Sense technology, which helps monitor and improve your sleep quality. A free trial of this feature is available until 2023.
Are the Wyze devices compatible with both Alexa and Google Assistant?Yes, Wyze devices such as the Wyze Cam v4 are compatible with both Alexa and Google Assistant, allowing for flexible voice control options.
Can you tell me more about the features of the Google Nest Hub (2nd Gen)?What types of Wyze devices can I control with the Google Nest Hub?Do you have any ongoing sales or discounts for the smart home packages?
