Wyze Battery Cam Pro: No-Drill, Wire-Free Security for Renters
Flexible Security Options for Renters: Wyze Battery Cam Pro Series
Renters often face challenges when it comes to installing security cameras due to restrictions on drilling holes or running permanent wiring. The Wyze Battery Cam Pro lineup offers an ideal solution with flexible, wire-free security options that require no permanent installation, making them perfect for renters who want reliable home protection without damaging their living space.
Wyze Battery Cam Pro: Wire-Free, Powerful Security
Key Features
  • 2.5K HDR Video Resolution: Capture crystal-clear footage with 2560 x 1440 resolution, ensuring every detail is visible.
  • Wire-Free Design: Completely wireless with no hub required, allowing easy placement anywhere without drilling or wiring.
  • Removable, Rechargeable Battery Packs: Equipped with a 6200mAh battery that lasts up to 6 months on a single charge.
  • Integrated Spotlight & Siren: Built-in spotlight and 100 dB siren enhance security by deterring intruders.
  • Radar + PIR Motion Detection: Advanced motion sensors reduce false alerts and detect movement accurately.
  • Weatherproof (IP65): Durable for outdoor use in temperatures ranging from -20°C to 50°C (-4°F to 122°F).
  • Dual-Band WiFi Support: Connects to both 2.4 GHz and 5 GHz networks for stable streaming.
  • Two-Way Audio: Communicate through the camera with a built-in speaker and microphone.
  • Easy Mounting: Comes with a wall mount that uses a standard 1/4” - 20 thread, perfect for renters who want a no-drill solution using adhesive or magnetic mounts.
Why It’s Perfect for Renters
The Wyze Battery Cam Pro’s wireless and rechargeable design means no permanent wiring or drilling is necessary. Its lightweight and compact size (2.5 x 1.8 x 3.5 inches) make it easy to move or reposition as needed, ideal for rental properties where flexibility is key.
Wyze Battery Cam Pro + Solar Panel: Continuous Power Without Wiring
Enhanced Features
  • All Features of Wyze Battery Cam Pro: Includes 2.5K HDR video, spotlight, siren, radar + PIR motion detection, and two-way audio.
  • Solar Panel Integration: The included solar panel continuously charges the camera’s battery, reducing the need for manual recharging.
  • Weatherproof Solar Panel: Rated IP65, designed to withstand outdoor conditions and provide reliable power.
  • Extended Battery Life: With solar power, enjoy longer periods of uninterrupted security without worrying about battery drain.
Ideal for Renters Who Want Hassle-Free Power
This bundle is perfect for renters who want the convenience of wire-free security with the added benefit of solar charging. It eliminates the need to remove the camera for charging, making it a truly set-and-forget security solution.
Wyze Removable Battery Pack: Keep Your Camera Running Longer
Features
  • 6200mAh Rechargeable Battery: Same capacity as the original battery, providing up to 6 months of use.
  • Quick USB-C Charging: Conveniently recharge the battery in about 9 hours.
  • Compact and Lightweight: Easy to swap batteries without interrupting your camera’s security coverage.
  • Compatible with Wyze Battery Cam Pro and Duo Cam Doorbell: Perfect accessory for renters who want to extend their camera’s uptime without wiring.
Why It Matters for Renters
Having an extra battery pack means you can keep your camera powered without needing to take it down for long periods. Swap batteries quickly and maintain continuous security without any wiring hassles.
Why Choose Wyze Battery Cam Pro for Rental Security?
“Wyze Battery Cam Pro offers renters a flexible, powerful, and wire-free security solution that respects rental agreements while providing peace of mind.”
  • No Drilling or Wiring Required: Perfect for renters who cannot make permanent modifications.
  • Long Battery Life: Up to 6 months on a single charge means less maintenance.
  • Weatherproof and Durable: Suitable for indoor and outdoor use.
  • Smart Home Integration: Works with Alexa, Google Assistant, and IFTTT for seamless automation.
  • Local and Cloud Storage Options: Supports up to 256GB microSD cards and cloud recording with Cam Plus.
Summary
For renters seeking a flexible, no-drill security camera, the Wyze Battery Cam Pro and its solar-powered variant provide an unbeatable combination of high-resolution video, long battery life, and easy installation. Supplement your setup with removable battery packs to ensure continuous protection without the need for permanent wiring or drilling.
Outdoor Security Camera in Use Wyze Battery Cam Pro providing flexible, wire-free security for renters Solar Panel Charging Camera Solar panel keeps your Wyze Battery Cam Pro charged without wiring Swapping Battery Pack Easily swap removable battery packs to keep your camera running
FeatureWyze Battery Cam ProWyze Battery Cam Pro + Solar PanelWyze Removable Battery Pack
TypeCameraCamera + Solar Panel BundleAccessory (Battery Pack)
Video Resolution2.5K HDR2.5K HDRN/A
PowerRemovable, Rechargeable Battery PacksRemovable, Rechargeable Battery Packs + Solar Panel for continuous power6200mAh Rechargeable Lithium Ion Battery
Battery LifeUp to 6 months per chargeExtended with Solar PanelUp to 6 months per charge
Weatherproof RatingIP65IP65N/A
Motion DetectionRadar + PIRRadar + PIRN/A
Spotlight & SirenIntegrated Spotlight & SirenIntegrated Spotlight & SirenN/A
WiFi Support2.4 & 5 GHz2.4 & 5 GHzN/A
Local RecordingYes, with microSD card (not included)Yes, with microSD card (not included)N/A
SetupWire-free, no hub requiredWire-free, no hub requiredN/A
Solar Panel IncludedNoYes (2.5W, 5VDC, IP65, 13 ft cable)N/A
Battery CapacityIncluded battery packIncluded battery pack6200mAh, USB-C charging port
Charging TimeN/AN/AApprox. 9 hours at 25°C
DimensionsCamera: 2.5" x 1.8" x 3.5"Camera + Solar Panel (173mm x 120mm x 17mm)2.9" x 1.6" x 0.9" (75mm x 40mm x 22mm)
Weight0.94 lb (camera)Camera + Solar Panel3.9 oz (110g)
Price$89.98 (1 pack)$109.98 (bundle)$22.99
What makes the Wyze Battery Cam Pro a good security camera for renters?The Wyze Battery Cam Pro is ideal for renters because it offers a completely wire-free design that requires no drilling or permanent wiring. Its compact size and easy mounting options, including adhesive or magnetic mounts, allow renters to install and move the camera without damaging their living space or violating rental agreements.
Does the Wyze Battery Cam Pro require drilling or permanent installation?No, the Wyze Battery Cam Pro does not require any drilling or permanent installation. It features a wire-free design and can be mounted using adhesive or magnetic mounts, making it perfect for renters who cannot make permanent modifications to their property.
How long does the Wyze Battery Cam Pro battery last on a single charge?The Wyze Battery Cam Pro is equipped with a 6200mAh rechargeable battery that can last up to 6 months on a single charge, depending on usage and environmental conditions.
Can the Wyze Battery Cam Pro be used outdoors?Yes, the Wyze Battery Cam Pro is weatherproof with an IP65 rating, making it suitable for both indoor and outdoor use in temperatures ranging from -20°C to 50°C (-4°F to 122°F).
What video quality does the Wyze Battery Cam Pro offer?The Wyze Battery Cam Pro provides 2.5K HDR video resolution (2560 x 1440), ensuring crystal-clear footage and detailed video capture for enhanced security.
How does the Wyze Battery Cam Pro detect motion?The Wyze Battery Cam Pro uses advanced radar and PIR (Passive Infrared) motion detection technology to accurately detect movement and reduce false alerts.
What are the benefits of the Wyze Battery Cam Pro + Solar Panel bundle for renters?The Wyze Battery Cam Pro + Solar Panel bundle offers continuous, wire-free power by using a weatherproof solar panel to keep the camera charged. This eliminates the need for manual recharging and provides a hassle-free, set-and-forget security solution for renters.
Can I extend the battery life of my Wyze Battery Cam Pro?Yes, you can extend the battery life by using the Wyze Removable Battery Pack. This 6200mAh rechargeable battery is easy to swap, allowing you to keep your camera running without interruption or the need for wiring.
Is the Wyze Battery Cam Pro compatible with smart home systems?Yes, the Wyze Battery Cam Pro integrates with popular smart home platforms such as Alexa, Google Assistant, and IFTTT, enabling seamless automation and voice control.
What storage options are available for Wyze Battery Cam Pro recordings?The Wyze Battery Cam Pro supports both local and cloud storage. You can use a microSD card up to 256GB for local storage or subscribe to Cam Plus for cloud recording and additional features.
How do I recharge the Wyze Battery Cam Pro or its removable battery pack?The Wyze Battery Cam Pro and its removable battery pack can be recharged using a USB-C cable. Charging typically takes about 9 hours for a full charge.
Is the Wyze Battery Cam Pro easy to move or reposition?Yes, the Wyze Battery Cam Pro is lightweight and compact, making it easy to move or reposition as needed. This flexibility is especially beneficial for renters who may need to change camera locations.
What are the key features of the Wyze Battery Cam Pro?How does the solar panel work with the Wyze Battery Cam Pro?Do you have any deals, ongoing sales, discounts, or promotions?
