Compact Solar Panel for Wyze Battery Cam: Preserve Your Camera’s Battery Life
If you own a Wyze Battery Cam or Wyze Cam Outdoor, extending your camera’s battery life is essential for uninterrupted security monitoring. The
Wyze Battery Cam Solar Panel is a compact, weather-resistant solar panel designed specifically to keep your Wyze cameras powered longer by harnessing the sun’s energy. Whether you have the Wyze Battery Cam Pro or Wyze Cam Outdoor v1/v2, this solar panel accessory ensures your camera stays charged without frequent manual recharging.
Wyze Battery Cam Solar Panel: Key Features & Benefits
Designed for Continuous Power
The Wyze Battery Cam Solar Panel is engineered to provide continuous power to your Wyze cameras, allowing you to record for longer periods without bringing the camera inside for recharging. This means more peace of mind with less maintenance.
- Compatibility: Works seamlessly with Wyze Cam Outdoor v1/v2 and Wyze Battery Cam Pro.
- Weather Resistance: Rated IP65, it is dustproof and weatherproof, built to withstand rain, dust, and other outdoor elements.
- Flexible Mounting: Comes with a 360° freestyle mount and a 13-foot weatherproof power cable, giving you ultimate flexibility to position the panel for maximum sun exposure anywhere around your home or property.
“Record for longer. Designed to be weather resistant and mountable anywhere.”
Perfect for Outdoor Use
Whether mounted on your porch, garden, or RV, the solar panel’s durable design ensures reliable power supply in various environments. Its compact size makes it unobtrusive while still delivering efficient solar charging.
Wyze Battery Cam Pro: The Ultimate Wireless Security Camera
High-Resolution Video & Smart Detection
The
Wyze Battery Cam Pro offers stunning 2.5K HDR video resolution, providing crystal-clear images day and night. It features integrated spotlight and siren, radar + PIR motion detection for precise alerts, and supports both 2.4 GHz and 5 GHz WiFi for reliable connectivity.
- Battery: Removable, rechargeable battery packs that can be hot-swapped to avoid downtime.
- Weatherproof: IP65 rating ensures it performs well in all weather conditions.
- Smart Features: Includes color night vision, two-way audio, and local recording with microSD card support.
- Easy Setup: No hub required, and BluetoothⓇ setup makes installation quick and hassle-free.
Extend Battery Life with Solar Power
Pairing the Wyze Battery Cam Pro with the Wyze Battery Cam Solar Panel transforms it into a solar-powered security camera, reducing the need for frequent battery charging and enhancing your camera’s uptime.
Wyze Battery Cam Pro + Solar Panel Bundle: Convenience & Savings
For those looking for an all-in-one solution, the
Wyze Battery Cam Pro + Solar Panel bundle offers the best value. This combo provides the advanced features of the Battery Cam Pro along with the solar panel accessory to keep your camera powered continuously.
Bundle Highlights
- 2.5K HDR Video with Color Night Vision: Capture every detail with enhanced clarity.
- Integrated Spotlight & Siren: Deter intruders with motion-activated light and sound.
- Radar + PIR Motion Detection: Double sensors for smarter, earlier alerts.
- Battery Life: Up to 6 months on a single charge, extended further with solar power.
- Weatherproof & Wireless: IP65 rating and no hub needed for flexible placement.
- Supports Local & Cloud Storage: Record locally on microSD cards up to 256GB or use Cam Plus cloud storage.
This bundle is perfect for users who want a ready-to-go solar-powered security camera with premium features and hassle-free installation.
Why Choose Wyze Solar Panel for Your Battery Cam?
- Compact & Lightweight: Easy to install without bulky hardware.
- Weatherproof Durability: Reliable in rain, sun, and dust.
- Long Power Cable: 13-foot cable allows versatile mounting locations.
- Compatible with Multiple Wyze Cameras: Supports Wyze Cam Outdoor v1/v2 and Battery Cam Pro.
- Affordable Price: At $24.99, it’s a cost-effective way to extend your camera’s battery life.
Enhance Your Home Security with Wyze
Using the Wyze Battery Cam Solar Panel with your Wyze Battery Cam Pro or Wyze Cam Outdoor ensures your security system stays powered and ready, no matter the weather or location. Enjoy the freedom of wireless, solar-powered security that keeps an eye on what matters most.
Keep your Wyze Battery Cam powered outdoors with the compact solar panel.
Experience crystal-clear 2.5K HDR video and smart motion detection.
Flexible mounting options with a weatherproof design for any outdoor setting.
Summary of Products Mentioned
Optimize your Wyze Battery Cam experience today with the compact, efficient Wyze Battery Cam Solar Panel and enjoy extended battery life and continuous security coverage.
What is the Wyze Battery Cam Solar Panel and how does it work?
The Wyze Battery Cam Solar Panel is a compact, weather-resistant solar panel designed to keep your Wyze Battery Cam Pro or Wyze Cam Outdoor v1/v2 powered by harnessing solar energy. It provides continuous power to your camera, reducing the need for frequent manual recharging and ensuring uninterrupted security monitoring.Which Wyze cameras are compatible with the Wyze Battery Cam Solar Panel?
The Wyze Battery Cam Solar Panel is compatible with the Wyze Battery Cam Pro and Wyze Cam Outdoor v1 and v2 models. It is specifically designed to work seamlessly with these Wyze cameras for optimal performance.Is the Wyze Battery Cam Solar Panel weatherproof?
Yes, the Wyze Battery Cam Solar Panel is rated IP65, making it dustproof and weatherproof. It is built to withstand rain, dust, and other outdoor elements, ensuring reliable performance in various weather conditions.How long is the power cable included with the Wyze Battery Cam Solar Panel?
The Wyze Battery Cam Solar Panel comes with a 13-foot weatherproof power cable, allowing for flexible and versatile mounting options to maximize sun exposure around your home or property.Can I mount the Wyze Battery Cam Solar Panel anywhere outdoors?
Yes, the solar panel features a 360° freestyle mount and a long power cable, making it easy to install on porches, gardens, RVs, or any outdoor location where your Wyze camera is placed.What are the benefits of using the Wyze Battery Cam Solar Panel?
Using the Wyze Battery Cam Solar Panel extends your camera’s battery life, reduces the need for manual recharging, and ensures continuous security coverage. Its compact, lightweight, and weatherproof design makes it easy to install and reliable in various outdoor environments.What features does the Wyze Battery Cam Pro offer?
The Wyze Battery Cam Pro offers 2.5K HDR video resolution, color night vision, integrated spotlight and siren, radar and PIR motion detection, two-way audio, and supports both 2.4 GHz and 5 GHz WiFi. It also features removable, rechargeable battery packs and local recording with microSD card support.How does the Wyze Battery Cam Pro + Solar Panel bundle benefit users?
The Wyze Battery Cam Pro + Solar Panel bundle provides an all-in-one solution for wireless, solar-powered security. It combines the advanced features of the Battery Cam Pro with the continuous charging capability of the solar panel, offering convenience, savings, and hassle-free installation.How long can the Wyze Battery Cam Pro last on a single charge, and how does the solar panel extend this?
The Wyze Battery Cam Pro can last up to 6 months on a single charge under typical usage. When paired with the Wyze Battery Cam Solar Panel, the battery life is extended even further, reducing the need for manual recharging and maximizing camera uptime.Is the Wyze Battery Cam Solar Panel affordable?
Yes, the Wyze Battery Cam Solar Panel is priced at $24.99, making it a cost-effective accessory to extend your Wyze camera’s battery life and ensure continuous security coverage.
