Energy Efficient Outdoor Power Supply for 24/7 Wyze Video Surveillance
When it comes to reliable, energy-efficient power solutions for your Wyze outdoor video surveillance, the
Wyze Outdoor Power Adapter stands out as the perfect companion. Designed specifically to keep your Wyze cameras running continuously in all weather conditions, this power adapter ensures your security system never misses a moment.
Wyze Outdoor Power Adapter: Durable, Weather-Resistant Power for Wyze Cameras
Built for All Weather Conditions
The Wyze Outdoor Power Adapter is IP67 rated, meaning it is fully weather-resistant and ready to withstand rain, snow, or shine. Whether you live in a rainy climate or experience harsh winters, this adapter keeps your Wyze cameras powered safely and reliably outdoors.
Compatibility and Convenience
- Compatible with Wyze Cam v3, Cam v4, Pan v3, and Battery Cam Pro (with required adapters).
- Comes with multiple variants including the Outdoor Adapter + L-shaped Adapter + USB-C Adapter for versatile camera connections.
- Cable lengths designed for flexible installation: 12.5 ft (3.8 m) cable to camera, 3.9 ft (1.2 m) AC cable, and 8.5 ft (2.6 m) DC cable.
- Operating temperature range from -30°C to 50°C (-22°F to 122°F) ensures performance in extreme climates.
Energy Efficient Power Output
- Input power: 100V-240V
- Output power: 5V 2A, optimized for low energy consumption while maintaining steady power delivery.
Included Accessories
- Wyze Outdoor Power Adapter
- Wire Clips and Screws for secure mounting
- Weatherproof L-shaped Micro-USB Adapter for protected connections
Keep your Wyze cameras powered 24/7 with a power adapter designed to endure the elements and deliver consistent, energy-efficient performance.
Wyze Cam Pan v3: The Perfect Outdoor Surveillance Camera
360° Pan and 180° Tilt for Complete Coverage
The Wyze Cam Pan v3 offers a full 360-degree horizontal and 180-degree vertical view, allowing you to monitor every angle of your property with a single camera.
Weather-Resistant and Durable
With an IP65 rating, the Pan v3 is built to handle outdoor environments, but for safe and continuous outdoor use, pairing it with the Wyze Outdoor Power Adapter is essential.
High-Quality Video and Audio
- 1080p Full HD video resolution with H.264 encoding
- Night vision with 4 IR LEDs for clear images in low light
- Built-in speaker and microphone enable 2-way audio with noise and echo cancellation
Smart Features and Connectivity
- Compatible with Alexa, Google Assistant, and IFTTT for voice and automation control
- Supports up to 256 GB microSD card for local storage
- Connects via 2.4 GHz Wi-Fi for stable streaming
Compact and Lightweight
- Dimensions: 124mm x 60mm x 63mm
- Weight: 320 g (11.29 oz)
Wyze Cam Pan v3 powered by Wyze Outdoor Power Adapter, ready for all seasons
Pan v3 Security Bundle: Complete Setup with Power Adapter Included
For those looking for an all-in-one solution, the
Pan v3 Security Bundle includes two Wyze Cam Pan v3 cameras, power adapters, mounting kits, and 32GB microSD cards. This bundle is perfect for comprehensive outdoor surveillance with energy-efficient power supply included.
Bundle Highlights
- Two fully weather-resistant Pan v3 cameras
- Two Wyze Outdoor Power Adapters for continuous 24/7 power
- Mounting kits for easy installation
- 32GB microSD cards for local video storage
This bundle offers a cost-effective way to secure multiple outdoor areas with reliable, energy-efficient power and high-quality video surveillance.
Why Choose Wyze Outdoor Power Solutions?
- Energy Efficiency: Low voltage 5V 2A output ensures minimal power consumption while maintaining camera performance.
- Weatherproof Design: IP67 rating for the power adapter and IP65 for cameras means your system withstands harsh outdoor conditions.
- Seamless Compatibility: Designed specifically for Wyze outdoor cameras, ensuring plug-and-play convenience.
- Long Cable Lengths: Flexible installation options with cables up to 12.5 ft to reach your ideal camera placement.
- Certified Safety: FCC and UL certifications guarantee safe and reliable operation.
With Wyze Outdoor Power Adapter and compatible cameras like the Pan v3, you get a robust, energy-efficient outdoor surveillance system that works rain or shine.
Summary of Key Products for 24/7 Wyze Outdoor Surveillance
Product | Key Features | Weather Resistance | Power Output | Compatibility |
Wyze Outdoor Power Adapter | IP67 rated, 12.5 ft cable, multiple adapters | IP67 | 5V 2A | Wyze Cam v3, v4, Pan v3, Battery Cam Pro |
Wyze Cam Pan v3 | 360° pan, 1080p HD, 2-way audio, IP65 rated | IP65 | Requires adapter | Works with Wyze Outdoor Power Adapter |
Pan v3 Security Bundle | 2 cameras + power adapters + 32GB microSD cards | IP65 (cameras) | Included | Complete outdoor surveillance kit |
By choosing the Wyze Outdoor Power Adapter paired with Wyze Cam Pan v3 or the Pan v3 Security Bundle, you ensure your outdoor video surveillance system is powered efficiently and reliably 24/7, no matter the weather.
Reliable outdoor security with Wyze Cam Pan v3 and Outdoor Power Adapter
What is the Wyze Outdoor Power Adapter and how does it benefit outdoor video surveillance?
The Wyze Outdoor Power Adapter is a weather-resistant, energy-efficient power supply designed specifically for Wyze outdoor cameras. It ensures your Wyze cameras remain powered 24/7 in all weather conditions, providing reliable and continuous video surveillance for your property.Which Wyze cameras are compatible with the Wyze Outdoor Power Adapter?
The Wyze Outdoor Power Adapter is compatible with Wyze Cam v3, Cam v4, Pan v3, and Battery Cam Pro (with required adapters). It comes with multiple adapter variants for versatile camera connections.Is the Wyze Outdoor Power Adapter weatherproof?
Yes, the Wyze Outdoor Power Adapter is IP67 rated, making it fully weather-resistant and capable of withstanding rain, snow, and extreme temperatures from -30°C to 50°C (-22°F to 122°F).How energy efficient is the Wyze Outdoor Power Adapter?
The Wyze Outdoor Power Adapter delivers a low voltage output of 5V 2A, optimized for minimal energy consumption while maintaining steady and reliable power for your Wyze cameras.What accessories are included with the Wyze Outdoor Power Adapter?
The Wyze Outdoor Power Adapter package includes the power adapter itself, wire clips and screws for secure mounting, and a weatherproof L-shaped Micro-USB adapter for protected connections.What are the cable lengths provided with the Wyze Outdoor Power Adapter?
The Wyze Outdoor Power Adapter features a 12.5 ft (3.8 m) cable to the camera, a 3.9 ft (1.2 m) AC cable, and an 8.5 ft (2.6 m) DC cable, allowing for flexible and convenient installation.What makes the Wyze Cam Pan v3 suitable for outdoor surveillance?
The Wyze Cam Pan v3 is IP65 rated for weather resistance, offers 360° pan and 180° tilt for complete coverage, delivers 1080p Full HD video, and features night vision and 2-way audio. For continuous outdoor use, it should be paired with the Wyze Outdoor Power Adapter.Does the Wyze Cam Pan v3 support local video storage?
Yes, the Wyze Cam Pan v3 supports up to a 256 GB microSD card for local video storage, allowing you to record and review footage directly from the camera.What is included in the Pan v3 Security Bundle?
The Pan v3 Security Bundle includes two Wyze Cam Pan v3 cameras, two Wyze Outdoor Power Adapters, mounting kits, and 32GB microSD cards, providing a complete and cost-effective outdoor surveillance solution.Are Wyze outdoor power solutions certified for safety?
Yes, Wyze outdoor power solutions, including the Wyze Outdoor Power Adapter, are FCC and UL certified, ensuring safe and reliable operation for your outdoor surveillance system.Can I use voice assistants with Wyze Cam Pan v3?
Yes, the Wyze Cam Pan v3 is compatible with Alexa, Google Assistant, and IFTTT, allowing for convenient voice and automation control of your surveillance system.Why should I choose Wyze Outdoor Power Adapter for my outdoor cameras?
The Wyze Outdoor Power Adapter offers energy efficiency, weatherproof design, seamless compatibility with Wyze cameras, long cable lengths for flexible installation, and certified safety, making it an ideal choice for reliable 24/7 outdoor video surveillance.
