Durable Weatherproof Pan Tilt Security Cameras with Two-Way Audio
Durable Weatherproof Pan Tilt Security Cameras with Enhanced Two-Way Audio
When it comes to securing your home or business, having a reliable, weatherproof security camera with pan and tilt capabilities and enhanced two-way audio is essential. Whether you want to monitor your outdoor spaces in any weather or communicate clearly with visitors or intruders, the right camera can make all the difference. Below, we highlight the top Wyze security cameras that meet these needs, combining durability, advanced audio features, and versatile viewing angles.
Wyze Cam Pan v3: Weatherproof 360° Pan & 180° Tilt Security Camera
Wyze Cam Pan v3 in snowy outdoor setting Experience full outdoor protection with Wyze Cam Pan v3 The Wyze Cam Pan v3 is a redesigned indoor/outdoor security camera that offers a full 360° pan and 180° tilt range, allowing you to monitor every corner of your property effortlessly. Its IP65 weather resistance rating ensures it withstands rain, snow, and dust, making it perfect for outdoor use when paired with the Wyze Outdoor Power Adapter (sold separately).
Key Features:
  • 360° Pan & 180° Tilt: Complete coverage with the ability to look straight up and down.
  • IP65 Weather Resistant: Durable for all weather conditions.
  • Automatic Motion Tracking: The camera detects and follows motion quietly without disturbing your environment.
  • Two-Way Audio: Speak and listen through the camera using the Wyze app, enabling clear communication.
  • Color Night Vision: See vivid colors even in low light with the Starlight Sensor.
  • Privacy Mode: Easily disable the camera’s view by pointing it downward for privacy.
  • Custom Patrol Routes: Set up to 4 waypoints for automatic patrols.
This camera is ideal for users who want a versatile pan-tilt camera that can brave the elements while providing detailed, real-time communication and monitoring.
Wyze Cam v4: Crystal-Clear 2.5K QHD Weatherproof Camera with Enhanced Two-Way Talk
Wyze Cam v4 is the clearest Wyze camera yet, boasting 2.5K Quad HD resolution and enhanced color night vision. It is IP65 rated for weather resistance, making it suitable for outdoor installation without worry.
Highlights:
  • 2.5K QHD Resolution: Capture sharp, detailed video footage day and night.
  • Enhanced Color Night Vision: See vibrant colors in darkness, surpassing traditional night vision.
  • IP65 Weather Resistance: Reliable performance in rain, snow, and dust.
  • Enhanced Two-Way Audio: Advanced Audio Coding (AAC) and a powerful amplifier deliver crystal-clear conversations.
  • Motion-Activated Spotlight & Siren: Deter intruders with a bright spotlight and 99 dB siren.
  • 24/7 Local Recording: Supports microSD cards up to 256GB for continuous recording without subscription.
  • Wi-Fi 6 Support: Enjoy a stronger, more reliable connection.
  • Smart Assistant Compatibility: Works seamlessly with Alexa, Google Assistant, and IFTTT.
Wyze Cam v4 is perfect for those who want a high-resolution, weatherproof camera with superior audio and smart home integration.
Wyze Cam Floodlight v2: Bright 2K Outdoor Security with Two-Way Audio and IP65 Rating
Wyze Cam Floodlight v2 illuminating driveway at night Illuminate and secure your property with Wyze Cam Floodlight v2 For those who want powerful lighting combined with security, the Wyze Cam Floodlight v2 offers 2800 lumens of bright LED light, a 160° wide-angle 2K camera, and two-way audio communication.
Features:
  • 2800 Lumens LED Lighting: Two dimmable LED panels provide bright, adjustable illumination.
  • 2K Video with Color Night Vision: Clear, colorful video even in the dark.
  • IP65 Weatherproof: Built to withstand harsh outdoor conditions.
  • Two-Way Audio: Built-in speaker and microphone for real-time communication.
  • AI-Powered Light Control: Automatically adjusts lighting based on ambient conditions.
  • Motion-Activated Spotlight & Siren: Scare off unwanted visitors with a loud 105 dB siren.
  • Dusk-to-Dawn Automation: Lights turn on and off automatically based on natural light.
  • Smart Assistant Integration: Compatible with Alexa, Google Assistant, and IFTTT.
This camera is ideal for securing driveways, porches, and other outdoor areas where bright lighting and clear communication are needed.
Wyze Battery Cam Pro: Wire-Free, Weatherproof Security with Two-Way Audio
Wyze Battery Cam Pro offers a flexible, wire-free solution with 2.5K HDR video, IP65 weatherproofing, and enhanced two-way audio. Its rechargeable battery packs provide up to 6 months of operation on a single charge.
Advantages:
  • Wire-Free Design: No hub required, easy to install anywhere.
  • 2.5K HDR Video: High-resolution footage with excellent dynamic range.
  • IP65 Weatherproof: Durable for outdoor use in various climates.
  • Two-Way Audio: Communicate clearly with visitors or intruders.
  • Integrated Spotlight & Siren: Built-in deterrents for added security.
  • Radar + PIR Motion Detection: Advanced motion sensing for accurate alerts.
  • Supports 2.4 & 5 GHz Wi-Fi: Flexible connectivity options.
  • Local Storage: Supports up to 256GB microSD cards.
Perfect for users who want a portable, battery-powered camera with robust weather resistance and communication features.
Summary
For durable, weatherproof pan tilt security cameras with enhanced two-way audio, Wyze offers several excellent options:
  • Wyze Cam Pan v3 for full 360° pan and 180° tilt with weatherproof design.
  • Wyze Cam v4 for high-resolution 2.5K video, enhanced audio, and spotlight.
  • Wyze Cam Floodlight v2 for bright outdoor lighting combined with 2K video and two-way talk.
  • Wyze Battery Cam Pro for wire-free, rechargeable, weatherproof security with advanced audio.
Each of these cameras is designed to provide reliable outdoor security with clear communication, making them ideal choices for protecting your home or business in any weather.
Two-way audio communication with Wyze camera Stay connected with enhanced two-way audio
FeatureWyze Cam Pan v3Wyze Cam v4Wyze Cam Floodlight v2Wyze Battery Cam ProWyze Duo Cam Battery Doorbell
Video Resolution1080p2.5K QHD (2560 x 1440)2K (2304 x 1296)2.5K (2560 x 1440)Front: 2K (2048 x 1536), Bottom: 1080p
Field of View360° pan, 180° tilt115.9° (D) x 98.5° (H) x 53.1° (V)160° diagonal134° (DFOV), 108° (HFOV), 56° (VFOV)Front: 132° H x 100° V, Bottom: 121° H x 60° V
Night VisionColor Night Vision (Starlight Sensor)Enhanced Color Night VisionColor Night VisionIR LEDs + White LEDs (Color Night Vision)IR LEDs (6x 850 nm)
Weather ResistanceIP65 (requires Outdoor Power Adapter)IP65IP65IP65IP65
Power SourceWired (Outdoor Power Adapter sold separately)WiredHardwiredBattery (Removable, Rechargeable)Battery or Hardwired (10-24V AC)
AudioTwo-Way AudioEnhanced Two-Way TalkTwo-Way AudioTwo-Way AudioTwo-Way Talk
SpotlightNo (sold separately)Yes (motion-activated)Yes (2 dimmable LED panels)Integrated SpotlightNo
SirenNo99 dB105 dB100 dB90 dB
Local Storage SupportmicroSD up to 256GBmicroSD up to 256GBmicroSD up to 256GBmicroSD up to 256GBmicroSD up to 256GB
Motion DetectionYes, with automatic motion trackingYes, with AI Smart FocusYesRadar + PIR Motion DetectionYes, with AI detections
Additional FeaturesPrivacy Mode, Pan Scan™ WaypointsWi-Fi 6 support, 24/7 local recording, Alexa/Google AssistantAmbient Light Mode, AI-Powered Light Control, Dusk-to-Dawn AutomationUp to 6 months battery life, 2.4 & 5 GHz WiFiDual camera views (people & packages), motion-activated voice deterrence
DimensionsNot specifiedNot specified9.5" x 7.7" x 7.0"2.5" x 1.8" x 3.5"5.90" x 1.88" x 1.18"
WeightNot specifiedNot specified2.76 lbs (1.25 kg)0.94 lbs0.92 lbs (416 g)
Price (Single Pack)$39.98$35.98$89.98$159.98$109.99
What are the best weatherproof pan tilt security cameras with two-way audio?Wyze offers several top-rated weatherproof security cameras with pan and tilt capabilities and enhanced two-way audio, including the Wyze Cam Pan v3, Wyze Cam v4, Wyze Cam Floodlight v2, and Wyze Battery Cam Pro. These cameras are designed for outdoor use, providing reliable monitoring and clear communication in any weather.
Is the Wyze Cam Pan v3 suitable for outdoor use?Yes, the Wyze Cam Pan v3 is IP65 weather resistant, making it suitable for outdoor use when paired with the Wyze Outdoor Power Adapter (sold separately). It can withstand rain, snow, and dust, providing 360° pan and 180° tilt coverage for comprehensive monitoring.
What features does the Wyze Cam Pan v3 offer?The Wyze Cam Pan v3 features 360° pan and 180° tilt, IP65 weather resistance, automatic motion tracking, two-way audio, color night vision, privacy mode, and custom patrol routes. It is ideal for users seeking versatile, weatherproof surveillance with real-time communication.
How does the Wyze Cam v4 enhance outdoor security?Wyze Cam v4 offers 2.5K QHD resolution for crystal-clear video, enhanced color night vision, IP65 weather resistance, advanced two-way audio with AAC, a motion-activated spotlight and siren, 24/7 local recording, Wi-Fi 6 support, and compatibility with Alexa, Google Assistant, and IFTTT.
Does the Wyze Cam Floodlight v2 provide both lighting and security?Yes, the Wyze Cam Floodlight v2 combines 2800 lumens of bright, dimmable LED lighting with a 2K wide-angle camera, two-way audio, AI-powered light control, motion-activated spotlight and siren, dusk-to-dawn automation, and smart assistant integration for comprehensive outdoor security.
What are the benefits of the Wyze Battery Cam Pro?The Wyze Battery Cam Pro is a wire-free, weatherproof security camera with 2.5K HDR video, enhanced two-way audio, integrated spotlight and siren, radar and PIR motion detection, support for both 2.4 and 5 GHz Wi-Fi, and local storage up to 256GB. Its rechargeable battery provides up to 6 months of operation on a single charge.
Do Wyze security cameras support two-way audio communication?Yes, all featured Wyze security cameras, including the Cam Pan v3, Cam v4, Cam Floodlight v2, and Battery Cam Pro, offer enhanced two-way audio. This allows you to speak and listen through the camera using the Wyze app, enabling clear communication with visitors or intruders.
Are Wyze security cameras compatible with smart home assistants?Yes, Wyze security cameras such as the Cam v4 and Cam Floodlight v2 are compatible with Alexa, Google Assistant, and IFTTT, allowing for seamless integration into your smart home ecosystem.
Can Wyze security cameras record video locally without a subscription?Yes, Wyze cameras like the Cam v4 and Battery Cam Pro support local video recording via microSD cards (up to 256GB), enabling 24/7 continuous recording without the need for a subscription.
What makes Wyze security cameras ideal for outdoor use?Wyze security cameras are IP65 weatherproof, ensuring durability in rain, snow, and dust. They offer advanced features such as high-resolution video, color night vision, two-way audio, motion detection, and smart assistant compatibility, making them perfect for reliable outdoor security.
What are the key features of the Wyze Cam Pan v3?Can you tell me more about the IP65 weather resistance rating for the cameras?Are there any ongoing sales or discounts for the Wyze cameras?
