Durable Security Stickers & Cameras for Door and Window Protection
Durable Security Solutions for Door and Window Intruder Deterrence
When it comes to protecting your home from intruders, durable security measures are essential. While security stickers can act as a visual deterrent, combining them with advanced security cameras and accessories significantly enhances your home's defense. Below, discover top-rated Wyze security products designed to safeguard your doors, windows, and outdoor areas with robust technology and reliable performance.
Wyze Cam Floodlight v2: Powerful Illumination Meets Smart Security
Bright, Clear, and Always Vigilant
The Wyze Cam Floodlight v2 is a cutting-edge security camera integrated with a powerful 2800 lumens LED floodlight. This combination not only illuminates your door and window areas but also captures crystal-clear 2K video with color night vision, ensuring no detail goes unnoticed—even in the darkest conditions.
  • Wide 160° diagonal field of view covers large areas including entryways and windows.
  • Dusk-to-dawn automation automatically lights up your property when needed.
  • AI-powered light control and motion detection trigger the floodlight and camera recording.
  • Built-in 105dB siren and two-way audio allow you to deter intruders with voice commands remotely.
  • Weather-resistant IP65 rating ensures durability against rain, dust, and extreme temperatures.
  • Supports up to 256GB microSD for local storage and seamless integration with Alexa, Google Assistant, and IFTTT.
This floodlight camera is perfect for mounting near doors and windows to provide both a strong visual deterrent and active monitoring. Wyze Cam Floodlight v2 illuminating driveway at night Bright floodlight security for doorways and windows
Wyze Cam v4 Outdoor Bundle: Advanced Outdoor Surveillance
Crystal-Clear 2.5K QHD Video with Enhanced Night Vision
For those seeking a dedicated outdoor camera to monitor doors and windows, the Wyze Cam v4 Outdoor Bundle offers exceptional clarity and smart features:
  • 2.5K QHD resolution delivers sharp, detailed video footage.
  • Enhanced color night vision ensures visibility even in low-light conditions.
  • Motion-activated spotlight adds an extra layer of deterrence by illuminating suspicious activity.
  • 24/7 local recording with included 128GB microSD card.
  • Wi-Fi 6 support for faster, more reliable connectivity.
  • Compatibility with Alexa and Google Assistant for voice control and smart home integration.
  • Wired power source and weatherproof design make it ideal for permanent outdoor installation near entry points.
This bundle is a comprehensive solution for continuous monitoring and deterrence at vulnerable access points like doors and windows.
Wyze Cam Pan v3: 360° Pan and 180° Tilt for Complete Coverage
Flexible Indoor/Outdoor Security with Smart Tracking
The Wyze Cam Pan v3 is a versatile security camera that can be positioned to cover multiple angles around your home’s doors and windows:
  • 360° horizontal pan and 180° vertical tilt allow you to remotely adjust the camera view to track movement.
  • 1080p HD video with 4 IR LEDs for night vision ensures clear footage day and night.
  • 8x digital zoom to focus on specific areas of interest.
  • Two-way audio with noise and echo cancellation for clear communication.
  • IP65 weather resistance for outdoor use when paired with the Wyze Outdoor Power Adapter.
  • Supports up to 256GB microSD card for local video storage.
  • Smart assistant compatibility with Alexa, Google Assistant, and IFTTT.
Ideal for mounting near doors or windows where wide and adjustable coverage is needed to deter intruders effectively. Wyze Cam Pan v3 outdoor in snowy environment Flexible pan-tilt camera for full door/window coverage
Wyze Universal Mount (Long): Durable and Versatile Camera Mounting
Secure Your Cameras Exactly Where You Need Them
To maximize the effectiveness of your security cameras, proper mounting is crucial. The Wyze Universal Mount (Long) offers:
  • Heavy-duty metal construction for durability and stability.
  • Longer neck design for versatile mounting options on ceilings, walls, or patios.
  • Compatible with most Wyze cameras using the standard 1/4”-20 mount.
  • Easy installation with included screws and drywall anchors.
  • Supports up to 2 kg load, ensuring your camera stays firmly in place.
This mount helps position your cameras optimally near doors and windows for maximum deterrence and coverage.
Why Combine Security Stickers with Wyze Security Cameras?
While durable security stickers serve as a visible warning to potential intruders, pairing them with smart cameras like the Wyze Cam Floodlight v2 or Wyze Cam v4 Outdoor Bundle provides active surveillance and real-time alerts. This combination not only deters but also documents suspicious activity, giving you peace of mind and stronger protection for your home.
Summary: Best Security Products for Door and Window Intruder Deterrence
ProductKey FeaturesIdeal Use Case
Wyze Cam Floodlight v22800 lumens LED, 2K color night vision, sirenBrightly lit door/window security
Wyze Cam v4 Outdoor Bundle2.5K QHD, spotlight, Wi-Fi 6, 24/7 recordingOutdoor door/window monitoring
Wyze Cam Pan v3360° pan, 1080p HD, two-way audio, IP65Flexible indoor/outdoor coverage
Wyze Universal Mount (Long)Heavy-duty, adjustable, easy installSecure camera placement
Enhance your home security by combining durable deterrents like security stickers with these advanced Wyze products for comprehensive protection against intruders.
FeatureWyze Universal Mount (Long)Wyze Cam v4 Outdoor BundleWyze Cam Floodlight v2Wyze Cam Pan v3Wyze v3 Bundle
TypeAccessoryCamera BundleCameraCameraCamera Bundle
Price$9.99$69.99$89.98$39.98 (single)$92.94
Mount CompatibilityStandard 1/4”-20 mount; Not compatible with Wyze Cam OG/OG TelephotoN/AWall or Ceiling mountScrew 1/4" - 20 mountN/A
Camera ResolutionN/A2.5K QHD (2560 x 1440 approx.)2K (2304 x 1296)1080p (1920 x 1080)1080p (1920 x 1080)
Night VisionN/AEnhanced Color Night VisionColor Night VisionIR LEDs (850 nm)IR LEDs (850 nm)
Field of ViewN/ANot specified160° diagonal120° FOV121° diagonal
Pan/TiltN/AFixedFixed360° horizontal, 180° vertical360° horizontal, 180° vertical
Weather ResistanceDurable metal, weather resistantOutdoor readyIP65IP65IP65
Power SupplyN/AWired (requires Wyze Outdoor Power Adapter for outdoor use)Hardwired (110-120V AC)USB powered (requires outdoor power adapter for outdoor use)USB powered
AudioN/ABuilt-in mic and speaker; 2-way audioBuilt-in mic and speaker; 2-way audioBuilt-in mic and speaker; 2-way audioBuilt-in mic and speaker; 2-way audio
StorageN/AmicroSD card included (128GB)Supports up to 256GB microSDSupports up to 256GB microSDIncludes 32GB MicroSD card
Special FeaturesLonger neck for versatile mounting (ceiling, patio)Wi-Fi 6 support, motion-activated spotlight, 24/7 local recording, Alexa/Google Assistant compatible2800 Lumens LEDs, Ambient Light Mode, AI-Powered Light Control, 105dB sirenMotion tracking, noise & echo cancellation, 8x digital zoomMotion tracking, two-way audio, indoor/outdoor use
DimensionsN/AN/A9.5in x 7.7in x 7.0in (24.13cm x 19.56cm x 17.78cm)124mm x 60mm x 63mm124mm x 60mm x 63mm
WeightN/AN/A2.76 lbs (1.25 kg)11.29 oz (320 g)11.29 oz (320 g)
WarrantyNot specifiedNot specified1 year1 yearNot specified
What are the best Wyze security products for door and window intruder deterrence?The top Wyze security products for deterring intruders at doors and windows include the Wyze Cam Floodlight v2, Wyze Cam v4 Outdoor Bundle, Wyze Cam Pan v3, and the Wyze Universal Mount (Long). These products offer features like powerful LED floodlights, high-resolution video, night vision, motion detection, and flexible mounting options for comprehensive home protection.
How does the Wyze Cam Floodlight v2 enhance door and window security?The Wyze Cam Floodlight v2 combines a 2800 lumens LED floodlight with a 2K security camera, providing bright illumination and crystal-clear video coverage for doors and windows. It features AI-powered motion detection, dusk-to-dawn automation, a 105dB siren, two-way audio, and weather-resistant IP65 construction, making it ideal for deterring and monitoring intruders.
What features does the Wyze Cam v4 Outdoor Bundle offer for outdoor surveillance?The Wyze Cam v4 Outdoor Bundle delivers 2.5K QHD video resolution, enhanced color night vision, a motion-activated spotlight, 24/7 local recording with a 128GB microSD card, Wi-Fi 6 support, and weatherproof design. It is perfect for continuous monitoring and deterrence at outdoor entry points like doors and windows.
Can the Wyze Cam Pan v3 be used for both indoor and outdoor security?Yes, the Wyze Cam Pan v3 is designed for flexible indoor and outdoor use. It offers 360° horizontal pan, 180° vertical tilt, 1080p HD video, night vision, two-way audio, and IP65 weather resistance (when paired with the Wyze Outdoor Power Adapter), making it suitable for monitoring doors and windows from multiple angles.
How does the Wyze Universal Mount (Long) improve camera placement for security?The Wyze Universal Mount (Long) features heavy-duty metal construction and a longer neck design, allowing for versatile and secure mounting of Wyze cameras on ceilings, walls, or patios. It supports up to 2 kg load and is compatible with most Wyze cameras, ensuring optimal positioning for maximum coverage of doors and windows.
Why should I combine security stickers with Wyze security cameras?Combining durable security stickers with Wyze security cameras provides both a visible warning and active surveillance. Stickers deter potential intruders, while smart cameras like the Wyze Cam Floodlight v2 or Wyze Cam v4 Outdoor Bundle offer real-time alerts and video documentation, enhancing overall home security.
Are Wyze security cameras weather-resistant for outdoor use?Yes, Wyze security cameras such as the Wyze Cam Floodlight v2, Wyze Cam v4 Outdoor Bundle, and Wyze Cam Pan v3 (with the Outdoor Power Adapter) are designed with weather-resistant features, including IP65 ratings, to withstand rain, dust, and extreme temperatures for reliable outdoor performance.
Do Wyze security cameras support local video storage?Yes, Wyze security cameras support local video storage via microSD cards. The Wyze Cam Floodlight v2 and Wyze Cam Pan v3 support up to 256GB microSD cards, while the Wyze Cam v4 Outdoor Bundle includes a 128GB microSD card for 24/7 local recording.
Can Wyze security cameras be integrated with smart home systems?Wyze security cameras are compatible with popular smart home systems, including Alexa, Google Assistant, and IFTTT. This allows for voice control, automation, and seamless integration with other smart devices in your home.
What are the key features of the Wyze Cam Floodlight v2?How does the Wyze Cam v4 Outdoor Bundle enhance outdoor security?Do you have any deals, ongoing sales, discounts, or promotions available?
