Affordable Weatherproof Reflective Stickers for Home Security
Affordable Weatherproof Reflective Stickers for Door, Window, and Yard Security
Enhance your home security with affordable, weatherproof reflective stickers designed to deter unwanted visitors and increase visibility around your doors, windows, and yard. Combining these with smart security cameras and yard signs creates a comprehensive security system that protects your property day and night.
Wyze Security Reflective Stickers: High-Visibility Outdoor Protection
Weatherproof and Easy to Install
Wyze Security Reflective Stickers are specially made for outdoor use, featuring UV and weatherproof materials that withstand rain, sun, and harsh conditions without fading. Their bright blue reflective surface ensures high visibility, making them an effective deterrent for potential intruders.
Perfect for Doors, Windows, and Yard Areas
These stickers come in two sizes (8.5" x 10" and 10" x 12") and are easy to peel and stick on any smooth surface, including doors and windows. Their reflective nature catches light from flashlights or car headlights, alerting trespassers that your property is monitored.
"Deters unwanted visitors with high visibility and weatherproof durability."
Wyze Security Yard Sign: Stylish and Durable Crime Deterrent
Tough Aluminum Build with Reflective Surface
Complement your reflective stickers with the Wyze Security Yard Sign, crafted from durable aluminum with a highly visible reflective blue finish. This yard sign stands tall and is designed to be both an effective security warning and a stylish addition to your yard.
Easy Installation and Enhanced Security
The yard sign includes an aluminum stake and installation kit for quick setup in your yard. Its weatherproof and fade-resistant design ensures long-lasting protection, making it a perfect companion to your Wyze camera system and reflective stickers.
"Highly visible, durable, and easy to install yard sign."
Wyze Cam v4: Weatherproof Smart Camera for Door and Window Surveillance
Wyze Cam v4 Outdoor Setup Wyze Cam v4 installed outdoors in snowy weather, showcasing its IP65 weather resistance.
Crystal-Clear 2.5K QHD Resolution with Color Night Vision
Wyze Cam v4 delivers stunning 2.5K Quad HD video with enhanced color night vision, allowing you to see clear, vibrant footage even in low light. This makes it ideal for monitoring doors and windows around the clock.
IP65 Weather Resistance for Outdoor Use
Rated IP65, this camera withstands rain, snow, and dust, making it perfect for outdoor installation on doors, windows, or yard areas. Its motion-activated spotlight and 99 dB siren add extra layers of security.
Smart Features and Easy Setup
With Wi-Fi 6 support, two-way audio, and compatibility with Alexa and Google Assistant, Wyze Cam v4 offers seamless integration into your smart home. The magnetic mount allows for screw-free installation, perfect for quick placement on door frames or window sills.
"Weatherproof, high-resolution, smart home compatible camera."
Wyze Cam Pan v3: 360° Pan and Tilt Outdoor Security Camera
Wyze Cam Pan v3 in Winter Wyze Cam Pan v3 providing full outdoor coverage with weather resistance.
Full 360° Pan and 180° Tilt Coverage
Wyze Cam Pan v3 offers complete coverage with its 360° horizontal pan and 180° vertical tilt, ideal for monitoring large yard areas, doors, and windows from a single camera.
IP65 Weatherproof for Outdoor Durability
Built to withstand outdoor elements, this camera is fully weather resistant. Pair it with the Wyze Outdoor Power Adapter for reliable power in any weather.
Automatic Motion Tracking and Privacy Mode
The camera automatically tracks motion, following moving objects to ensure nothing goes unnoticed. Privacy Mode lets you disable the camera view instantly when needed.
"Complete outdoor coverage with motion tracking."
Wyze Cam Floodlight v2: Bright Lighting and Security in One
Wyze Cam Floodlight v2 Lighting Driveway Wyze Cam Floodlight v2 illuminating a driveway with motion detection.
Powerful 2800 Lumens LED Floodlight with 2K Video
Wyze Cam Floodlight v2 combines bright, dimmable LED lighting with 2K video resolution and color night vision, providing clear visibility and recording for your yard, doorways, and windows.
IP65 Weather Resistance and Smart Automation
This floodlight camera is built to endure outdoor conditions and features dusk-to-dawn automation, motion-activated lighting, and AI-powered light control to enhance security and energy efficiency.
Two-Way Audio and Loud Siren
Communicate directly through the built-in speaker and microphone, and deter intruders with a 105 dB siren, making it a powerful addition to your home security setup.
"Bright floodlight with smart security features."
Wyze Duo Cam Battery Doorbell: Advanced Video Door Security
Wyze Duo Cam Doorbell Installation Wyze Duo Cam Battery Doorbell installed at a front door.
Dual Camera Views with 2K Video and AI Detection
Wyze Duo Cam Doorbell offers two camera angles to monitor people and packages at your door with crisp 2K video. AI-powered alerts notify you of visitors and package deliveries in real time.
Battery-Powered and Weather Resistant
With IP65 weather resistance and a removable battery pack, this doorbell is easy to install without wiring and built to withstand outdoor conditions.
Motion-Activated Voice Deterrence and Two-Way Audio
Warn visitors with customizable voice messages and communicate through two-way audio, enhancing your door security with interactive features.
"Smart, battery-powered video doorbell."
Why Choose Wyze Reflective Stickers and Security Cameras?
Combining Wyze’s weatherproof reflective stickers and yard signs with advanced security cameras like Wyze Cam v4, Pan v3, Floodlight v2, and Duo Cam Doorbell creates a layered security system. Reflective stickers and yard signs act as visible deterrents, while cameras provide real-time monitoring and alerts, ensuring your doors, windows, and yard are protected affordably and effectively.
Enhance your home security today with Wyze’s affordable, weatherproof reflective stickers and smart cameras designed for comprehensive door, window, and yard protection.
FeatureWyze Security Reflective StickerWyze Security Yard SignWyze Cam v4Wyze Cam Pan v3Wyze Cam Floodlight v2Wyze Duo Cam Battery Doorbell
TypeAccessoryAccessoryCameraCameraCameraCamera
Price$7.99 (Sticker), $22.98 (Sticker + Yard Sign)$16.99 (Yard Sign), $22.98 (Yard Sign + Stickers)$35.98 - $107.94 (varies by pack/color)$39.98 - $114.94 (varies by pack/color)$89.98$89.98 - $109.99
Main PurposeSecurity deterrent via stickersSecurity deterrent via yard signIndoor/outdoor security cameraIndoor/outdoor pan & tilt security cameraOutdoor floodlight cameraBattery-powered video doorbell
MaterialUV & weatherproof stickerTough aluminumPolycarbonate body, Glass + Plastic lensPolycarbonate body, Glass + Plastic lensPolycarbonate body, Glass + Plastic lensPlastic body, Resin lens
Visibility FeaturesReflective stickersHighly visible reflective surface2.5K QHD video, Enhanced Color Night Vision1080p video, 120° FOV, IR night vision2K video, 2800 Lumens LEDs, Color Night VisionDual 2K cameras, IR LEDs
Weather ResistanceYes (UV & weatherproof)Yes (weatherproof & fade-resistant)IP65IP65IP65IP65
InstallationEasy peel & stick on doors/windowsYard placementStand, wall, ceiling, magnetic mountScrew mountWall or ceiling mountBattery powered, hardwired optional
Audio FeaturesNoneNone99dB waterproof speaker, 2-way talkBuilt-in speaker & mic, 2-way audioBuilt-in speaker & mic, 2-way audioSiren 90dB, 2-way talk
Video ResolutionN/AN/A2.5K QHD (2560x1440)1080p (1920x1080)2K (2304x1296)Front: 2K (2048x1536), Bottom: 1080p
Night VisionN/AN/A4 IR LEDs + 2 white spotlight LEDs4 IR LEDs (850 nm)Color Night Vision6x 850 nm IR LEDs
Motion DetectionN/AN/AYesYesYesYes
Local StorageN/AN/AmicroSD card up to 512 GBmicroSD up to 256 GBmicroSD up to 256 GBmicroSD up to 256 GB
Cloud StorageN/AN/AAvailable with subscriptionN/AN/AAWS Cloud storage
ConnectivityN/AN/AWi-Fi 6, 2.4 GHz Wi-Fi2.4 GHz Wi-Fi2.4 GHz Wi-Fi2.4 GHz & 5 GHz Wi-Fi
Smart Assistant IntegrationN/AN/AAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTT
Power SourceN/AN/AWired (Indoor 5V/1A adapter)Wired (5V/2000mA adapter)Hardwired (110-120V AC)Battery or AC (10-24V AC)
DimensionsN/AN/A2in x 2in x 2 3/8in124mm x 60mm x 63mm9.5in x 7.7in x 7.0in5.90in x 1.88in x 1.18in
WeightN/AN/A0.49 lb (222 g)11.29 oz (320 g)2.76 lbs (1.25 kg)0.92 lbs (416 g)
WarrantyN/AN/A1 Year1 Year1 Year1 Year
Additional FeaturesEasy installation, UV/weatherproofReflective, weatherproof, fade-resistantMotion-activated spotlight, color night vision360° pan, 180° tilt, noise & echo cancellation2800 Lumens LEDs, AI-Powered Light ControlDual camera views, motion-activated voice deterrence
What are Wyze Security Reflective Stickers and how do they improve home security?Wyze Security Reflective Stickers are weatherproof, UV-resistant stickers designed for outdoor use on doors, windows, and yard areas. Their bright blue reflective surface increases visibility and acts as a deterrent to unwanted visitors by signaling that your property is monitored, enhancing your overall home security.
Are Wyze Security Reflective Stickers weatherproof and durable?Yes, Wyze Security Reflective Stickers are made from UV and weatherproof materials, ensuring they withstand rain, sun, and harsh outdoor conditions without fading. This makes them ideal for long-term use on doors, windows, and other exterior surfaces.
What sizes are available for Wyze Security Reflective Stickers?Wyze Security Reflective Stickers are available in two sizes: 8.5" x 10" and 10" x 12", making them suitable for various applications on doors, windows, and yard areas.
How do I install Wyze Security Reflective Stickers?Wyze Security Reflective Stickers are easy to install. Simply peel and stick them onto any smooth surface, such as doors, windows, or yard signs. Their adhesive backing ensures a secure fit for outdoor use.
What is the Wyze Security Yard Sign and how does it work?The Wyze Security Yard Sign is a durable aluminum sign with a reflective blue finish, designed to be placed in your yard as a visible crime deterrent. It comes with an aluminum stake and installation kit for easy setup and is weatherproof and fade-resistant for long-lasting outdoor use.
Are Wyze security cameras weatherproof for outdoor use?Yes, Wyze security cameras such as the Wyze Cam v4, Wyze Cam Pan v3, and Wyze Cam Floodlight v2 are rated IP65 weather resistant, making them suitable for outdoor installation on doors, windows, and yard areas. They are built to withstand rain, snow, and dust.
What features does the Wyze Cam v4 offer for door and window surveillance?Wyze Cam v4 provides 2.5K Quad HD video resolution, enhanced color night vision, IP65 weather resistance, motion-activated spotlight, a 99 dB siren, Wi-Fi 6 support, two-way audio, and compatibility with Alexa and Google Assistant. Its magnetic mount allows for easy, screw-free installation.
How does the Wyze Cam Pan v3 provide full outdoor coverage?Wyze Cam Pan v3 offers 360° horizontal pan and 180° vertical tilt, allowing it to monitor large areas from a single location. It features automatic motion tracking, privacy mode, and is fully weatherproof for reliable outdoor use.
What are the benefits of the Wyze Cam Floodlight v2 for home security?Wyze Cam Floodlight v2 combines a powerful 2800 lumens dimmable LED floodlight with 2K video resolution and color night vision. It features IP65 weather resistance, dusk-to-dawn automation, motion-activated lighting, AI-powered light control, two-way audio, and a 105 dB siren for enhanced security.
What makes the Wyze Duo Cam Battery Doorbell a good choice for door security?The Wyze Duo Cam Battery Doorbell features dual camera views for monitoring people and packages, 2K video resolution, AI-powered alerts, IP65 weather resistance, a removable battery pack for easy installation, motion-activated voice deterrence, and two-way audio for interactive security.
How do Wyze reflective stickers and yard signs complement Wyze security cameras?Wyze reflective stickers and yard signs serve as visible deterrents to potential intruders, while Wyze security cameras provide real-time monitoring and alerts. Together, they create a layered and comprehensive security system for doors, windows, and yard areas.
Can Wyze security products be integrated with smart home systems?Yes, Wyze security cameras such as the Wyze Cam v4 are compatible with Alexa and Google Assistant, allowing for seamless integration into your smart home ecosystem.
How do I install the Wyze Cam v4 for outdoor use?Can the reflective stickers be used indoors as well?Do you have any ongoing sales or discounts for the Wyze security products?
