Dual Camera Stack Kit: Ultimate Package Theft Prevention System
Dual Camera System with Stack Kit for Package Theft Prevention
Protecting your packages and home has never been easier with advanced dual camera systems designed to provide comprehensive surveillance coverage. Combining wide-angle views with telephoto zoom capabilities, these systems allow you to monitor your front porch or delivery area with precision and clarity, deterring theft and capturing critical details. Explore the best dual camera solutions featuring stack kits that enhance your security setup, offering versatile viewing angles, smart alerts, and robust weather resistance.
Wyze Cam OG Stack Kit Bundle: Two Views in One System
The Wyze Cam OG Stack Kit Bundle is the perfect dual camera system for package theft prevention, offering a unique stackable design that combines two cameras for enhanced coverage.
Key Features:
  • Dual Camera Setup: Stack a wide-angle camera with a 3x telephoto lens camera to get both a broad overview and a close-up view of your porch or package area.
  • 1080p Full HD Video: Crisp video resolution ensures you catch every detail.
  • Color Night Vision: See clearly even in low light conditions with color night vision.
  • Two-Way Audio: Communicate directly through the camera with built-in speaker and microphone.
  • Fast Notifications: Receive instant alerts on your phone when motion is detected.
  • Built-in Siren: Deter potential thieves with an integrated siren.
  • Weather Resistant: Rated IP65 for reliable outdoor use.
  • Smart Home Integration: Works seamlessly with Alexa, Google Assistant, and IFTTT.
Technical Specs:
  • Frame Rate: 20 FPS (day), 15 FPS (night)
  • Field of View (Wide): 121.4° diagonal
  • Field of View (Telephoto): 27° diagonal
  • Storage: Supports up to 256 GB microSD card (included 32GB card)
  • Power: 110-240V AC adapter with 6 ft cable
This stack kit is ideal for users who want to monitor both the entire delivery area and zoom in on suspicious activity without blind spots. Wyze Cam OG Stack Kit in Use Dual Wyze cameras mounted outdoors for comprehensive package monitoring
Wyze Cam OG Telephoto: Zoom in on Details
Complement your security system with the Wyze Cam OG Telephoto, designed to provide a powerful 3x telephoto zoom lens that captures fine details from a distance.
Highlights:
  • 3x Telephoto Lens: Narrow field of view (27° diagonal) for focused zoom on packages or faces.
  • 1080p HD Video: Clear and detailed video quality.
  • Night Vision: Equipped with 4 IR LEDs for visibility in darkness.
  • Two-Way Audio: Built-in speaker and microphone with noise and echo cancellation.
  • Weatherproof: IP65 rating for outdoor durability.
  • Easy Mounting: Supports stand, wall, or ceiling mounts.
Specifications:
  • Video FPS: 20 FPS (day), 10 FPS (night)
  • Connectivity: 2.4 GHz Wi-Fi (802.11 b/g/n)
  • Power: 5V/1A adapter with 6 ft cable
Use the telephoto camera alongside a wide-angle camera to get a layered security approach, perfect for identifying package thieves or suspicious activity at a distance.
Wyze Battery Cam Pro: Wireless Freedom with High-Resolution Video
For flexible placement without wiring constraints, the Wyze Battery Cam Pro offers a wire-free solution with impressive 2.5K HDR video quality and smart detection features.
Why Choose Wyze Battery Cam Pro?
  • 2.5K HDR Video: Superior resolution for crystal-clear images and videos.
  • Wire-Free Design: No hub required, powered by removable rechargeable batteries lasting up to 6 months.
  • Radar + PIR Motion Detection: Advanced motion sensing reduces false alerts.
  • Integrated Spotlight & Siren: Illuminate and scare off intruders instantly.
  • Dual-Band Wi-Fi: Supports both 2.4 GHz and 5 GHz networks for stable connectivity.
  • Weatherproof: IP65 rating ensures reliable outdoor performance.
  • Smart Integrations: Compatible with Alexa, Google Assistant, and IFTTT.
Technical Details:
  • Video Resolution: 2560 x 1440 (2.5K)
  • Battery Capacity: 6200mAh, approx. 9 hours charging time
  • Field of View: 134° diagonal
  • Night Vision: 2 IR LEDs + 2 white LEDs (spotlight)
  • Audio: Two-way with MEMS digital mic and speaker
This camera is ideal for users who want high-quality video and flexible installation options to cover multiple angles around their property. Outdoor Security Camera Lifestyle Secure your home and packages with wireless, weatherproof cameras
Why Choose a Dual Camera System with Stack Kit for Package Theft Prevention?
"A dual camera system with stack kit offers the best of both worlds: wide coverage and detailed zoom, ensuring no blind spots and clear identification of package thieves."
  • Comprehensive Coverage: Wide-angle cameras capture the entire porch area, while telephoto cameras zoom in on suspicious activity.
  • Enhanced Night Vision: Color and infrared night vision keep your property monitored 24/7.
  • Smart Alerts: Instant notifications help you respond quickly to potential theft.
  • Easy Installation: Stack kits and wireless options simplify setup without compromising performance.
  • Weather Resistant: Designed to withstand outdoor elements year-round.
Conclusion
For effective package theft prevention, combining the Wyze Cam OG Stack Kit Bundle with the Wyze Cam OG Telephoto and Wyze Battery Cam Pro creates a powerful, versatile security system. This setup provides wide-angle views, detailed zoom, and wireless flexibility, ensuring your packages and home stay safe. Invest in these dual camera solutions today to enjoy peace of mind with smart, reliable, and high-quality surveillance.
FeatureWyze Cam OG Stack Kit BundleWyze Cam OG TelephotoWyze Battery Cam Pro
Price$89.99$25.98 (1 Pack), $58.98 (2 Pack)$159.98 (1 Pack), $219.98 (2 Pack), $89.98 (3 Pack)
Video Resolution1080p HD (1920 x 1080)1080p HD (1920 x 1080)2.5K HDR (2560 x 1440)
Field of ViewWide-angle (120°) + Telephoto (3x zoom)27° Field of View (3x Telephoto)134° DFOV, 108° HFOV, 56° VFOV
Zoom3x Telephoto lens included3x Telephoto lens8x Digital Zoom
Night VisionColor Night Vision, 4 IR LEDs (850nm)Color Night Vision, 4 IR LEDs (850nm)Color Night Vision, 2 IR LEDs (850nm), 2 White LEDs (187 lumens)
AudioTwo-way audio with upgraded mic and speakerTwo-way audio with upgraded mic and speakerTwo-way audio with built-in speaker and microphone
Siren90-decibel user-activated siren90-decibel user-activated siren100 dB SPL siren @ 0.1m
Power SourceWired, runs two cameras off one power sourceWiredWire-free, removable rechargeable battery packs
Weather ResistanceIP65IP65IP65
Local Storage SupportmicroSD card up to 256 GBmicroSD card up to 256 GBmicroSD card up to 256 GB
Connectivity2.4 GHz Wi-Fi2.4 GHz Wi-Fi2.4 & 5 GHz Wi-Fi
Operating Temperature Range-20°C to 55°C (-4°F to 131°F)-20°C to 55°C (-4°F to 131°F)-20°C to 50°C (-4°F to 122°F)
Weight4.1 oz (116 g)Not specified0.94 lbs
Dimensions1.89 in x 1.89 in x 1.89 in (48 mm cube)Not specified2.5 x 1.8 x 3.5 inches
Additional FeaturesStack Kit to run two cams off one power source, built-in spotlight (40 lumens), custom detection zones, smoke and CO alertsFaster live streaming, 3x faster notifications, weatherproof, user-activated siren, customizable detection zonesIntegrated spotlight & siren, radar + PIR motion detection, rechargeable battery, supports 2.4 & 5 GHz Wi-Fi
Included in Bundle1x Wyze Cam OG, 1x Wyze Cam OG Telephoto, 1x Stack Kit, 1x 128GB microSD, 1x 32GB microSDSingle or 2-pack Wyze Cam OG TelephotoSingle or multi-pack Wyze Battery Cam Pro
What is a dual camera system with stack kit for package theft prevention?A dual camera system with stack kit combines two cameras—typically a wide-angle and a telephoto lens—mounted together to provide comprehensive surveillance coverage. This setup allows you to monitor your porch or delivery area with both a broad overview and a detailed zoom, helping deter package theft and capture critical details.
How does the Wyze Cam OG Stack Kit Bundle help prevent package theft?The Wyze Cam OG Stack Kit Bundle features a unique stackable design that combines a wide-angle camera and a 3x telephoto lens camera. This dual setup provides both a broad view of your porch and a close-up of your package area, ensuring you can monitor deliveries and identify suspicious activity without blind spots.
What are the key features of the Wyze Cam OG Stack Kit Bundle?Key features of the Wyze Cam OG Stack Kit Bundle include dual camera setup (wide-angle and telephoto), 1080p Full HD video, color night vision, two-way audio, fast motion notifications, built-in siren, weather resistance (IP65), and smart home integration with Alexa, Google Assistant, and IFTTT.
Can the Wyze Cam OG Stack Kit be used outdoors?Yes, the Wyze Cam OG Stack Kit is rated IP65 for weather resistance, making it suitable for reliable outdoor use in various weather conditions.
What is the benefit of using a telephoto camera like the Wyze Cam OG Telephoto?The Wyze Cam OG Telephoto features a 3x telephoto lens with a narrow 27° field of view, allowing you to zoom in on packages or faces from a distance. This focused zoom helps capture fine details and identify potential package thieves more effectively.
Does the Wyze Cam OG Telephoto support night vision?Yes, the Wyze Cam OG Telephoto is equipped with 4 IR LEDs for clear night vision, ensuring visibility and security even in complete darkness.
What storage options are available for Wyze security cameras?Wyze security cameras support microSD cards up to 256 GB for local video storage. The Wyze Cam OG Stack Kit Bundle includes a 32GB microSD card, and all models are compatible with larger cards for extended recording.
Is there a wireless security camera option for flexible installation?Yes, the Wyze Battery Cam Pro offers a wire-free design powered by removable rechargeable batteries, allowing for flexible placement without wiring constraints. It features 2.5K HDR video, radar and PIR motion detection, and up to 6 months of battery life.
How does the Wyze Battery Cam Pro enhance home security?The Wyze Battery Cam Pro provides high-resolution 2.5K HDR video, advanced radar and PIR motion detection to reduce false alerts, integrated spotlight and siren for active deterrence, dual-band Wi-Fi connectivity, and weatherproof IP65 construction for reliable outdoor performance.
Are Wyze security cameras compatible with smart home systems?Yes, Wyze security cameras are compatible with popular smart home platforms including Alexa, Google Assistant, and IFTTT, allowing for seamless integration and voice control.
Why should I choose a dual camera system with stack kit for package theft prevention?A dual camera system with stack kit offers comprehensive coverage by combining wide-angle and telephoto views, enhanced night vision, smart alerts, easy installation, and weather resistance. This ensures no blind spots and clear identification of package thieves, providing peace of mind for your home and deliveries.
Can you tell me more about the features of the Wyze Battery Cam Pro?How does the dual camera system enhance package theft prevention?Do you have any deals, ongoing sales, discounts, or promotions for the dual camera systems?
