Doorbell with Fast Notifications and Dual-Band WiFi Extender Chime Solutions
Enhance your home security and convenience with the latest smart doorbell and chime technology. Whether you want instant alerts when someone approaches your door or a reliable chime that works seamlessly with your Wi-Fi network, these Wyze products deliver fast notifications and versatile connectivity options. Explore the best options for a doorbell with fast notifications paired with a dual-band Wi-Fi extender chime to keep you informed wherever you are.
Wyze Universal Wi-Fi Chime: Fast, Wireless Notifications Anywhere
Effortless Setup and Instant Alerts
The
Wyze Universal Wi-Fi Chime is designed for simplicity and speed. No complicated wiring is needed—just plug it in and instantly receive doorbell alerts throughout your home. This chime connects via Wi-Fi, allowing you to hear the familiar ding-dong sound anywhere you place it.
Smart Automations for Enhanced Security
Beyond traditional doorbell rings, this chime can be set to alert you when any Wyze camera detects a person, even if they don’t press the doorbell. For example, you can have it chime when your kitchen camera spots someone near your door, ensuring you never miss a visitor or unexpected activity.
Compatibility and Convenience
Works with all Wyze cameras and doorbells, especially the Duo Cam Doorbell and Video Doorbell Pro. Its wireless design means you can place it anywhere in your home for maximum coverage.
Never miss a ding-dong again with this convenient, fuss-free chime that keeps you connected to your front door.
Wyze Video Doorbell v2: Crystal Clear 2K Video and Real-Time Alerts
Superior Video Quality and Wide Field of View
The
Wyze Video Doorbell v2 offers stunning 2K resolution (2048 x 1536) with a wide 135° horizontal and 103° vertical field of view, capturing every detail at your doorstep. Its CMOS Starlight sensor ensures clear video even in low light.
Fast Notifications and Two-Way Audio
Receive real-time alerts on your phone the moment someone approaches or rings your doorbell. The built-in microphone and speaker enable two-way audio, so you can greet visitors or deter unwanted guests remotely.
Local and Cloud Storage Options
Store video locally on a microSD card (up to 256GB) or opt for cloud storage with a Wyze Security Plan. This flexibility ensures you have access to recorded footage whenever you need it.
Robust and Weather-Resistant
With an IP65 rating, the doorbell withstands harsh weather conditions, operating reliably from -4°F to 122°F (-20°C to 50°C).
Included Accessories for Easy Installation
The package includes a Wyze Chime Controller, wall plate, wedge for angled mounting, wire caps, screws, and a quick start guide, making installation straightforward.
Wyze Chime Controller: Seamless Integration for Wired Doorbells
Dedicated Chime Controller for Wyze Doorbells
The
Wyze Chime Controller is a standalone unit designed to work exclusively with the Wyze Video Doorbell v2 and Duo Cam Doorbell. It connects easily to your existing mechanical chime system, enabling your doorbell to ring through your home’s wired chime.
Easy Wiring and Compatibility
Installation involves a simple wiring process compatible with nearly every mechanical chime. This controller ensures your smart doorbell integrates smoothly with traditional chime hardware.
Compact and Durable Design
Measuring just 47mm x 32mm x 15mm, it fits discreetly inside your chime box and operates reliably in temperatures ranging from -20°C to 50°C.
The Front Porch Security Bundle: Complete Smart Home Entry Solution
All-in-One Security and Convenience
The
Front Porch Security Bundle combines the Wyze Video Doorbell (v2 or Pro), Wyze Lock, and Wyze Chime for a comprehensive front door security system. View your porch in 1080p HD, communicate with visitors via two-way audio, and lock or unlock your door remotely from the Wyze app.
Integrated Smart Lock Control
Control your Wyze Lock directly from the video doorbell app interface, allowing seamless management of your home’s entry points.
Fast Notifications and Reliable Chime Alerts
Get instant notifications when someone approaches or rings your doorbell, paired with audible chimes inside your home to ensure you never miss a visitor.
This bundle is perfect for those seeking a robust, easy-to-use smart home security setup with fast notifications and integrated doorbell chime functionality.
Why Choose Wyze for Your Doorbell and Chime Needs?
- Fast and Reliable Notifications: Receive instant alerts on your smartphone and through chimes placed anywhere in your home.
- Flexible Installation: Options for wireless chimes, wired chime controllers, and easy mounting solutions.
- High-Quality Video: Crisp 2K resolution with wide-angle views and night vision.
- Smart Automations: Customize alerts based on motion detection and person recognition.
- Weather-Resistant and Durable: Designed to withstand outdoor conditions year-round.
- Seamless Integration: Works with Wyze cameras, locks, and smart home ecosystems including Alexa, Google Assistant, and IFTTT.
Stay connected with fast doorbell notifications anywhere in your home.
Complete front porch security with video doorbell, chime, and smart lock.
Wyze Video Doorbell v2 delivering clear video and instant alerts.
Upgrade your home security with Wyze’s smart doorbell and chime solutions that offer fast notifications, easy installation, and reliable dual-band Wi-Fi connectivity. Whether you want a standalone Wi-Fi chime or a full front porch security bundle, Wyze has you covered.
What are the benefits of using a Wyze doorbell with fast notifications?
Wyze doorbells provide instant alerts to your smartphone and chimes throughout your home, ensuring you never miss a visitor or unexpected activity. With fast notifications, you can respond quickly to anyone at your door, enhancing both security and convenience.How does the Wyze Universal Wi-Fi Chime work?
The Wyze Universal Wi-Fi Chime is a wireless device that plugs into any outlet and connects to your Wi-Fi network. It delivers doorbell alerts anywhere in your home and can also notify you when any Wyze camera detects a person, even if the doorbell isn’t pressed.Is the Wyze Universal Wi-Fi Chime compatible with all Wyze doorbells and cameras?
Yes, the Wyze Universal Wi-Fi Chime works with all Wyze cameras and doorbells, including the Duo Cam Doorbell and Video Doorbell Pro, providing maximum coverage and flexibility.What video quality does the Wyze Video Doorbell v2 offer?
The Wyze Video Doorbell v2 features crystal clear 2K resolution (2048 x 1536) with a wide 135° horizontal and 103° vertical field of view, ensuring you capture every detail at your doorstep, even in low light conditions.Can I store video footage locally with the Wyze Video Doorbell v2?
Yes, the Wyze Video Doorbell v2 supports local storage on a microSD card up to 256GB, as well as cloud storage options through a Wyze Security Plan.Is the Wyze Video Doorbell v2 weather-resistant?
Absolutely. The Wyze Video Doorbell v2 has an IP65 weather-resistance rating and operates reliably in temperatures from -4°F to 122°F (-20°C to 50°C), making it suitable for year-round outdoor use.What is the Wyze Chime Controller and how does it work?
The Wyze Chime Controller is a dedicated unit designed for the Wyze Video Doorbell v2 and Duo Cam Doorbell. It connects to your existing mechanical chime system, allowing your smart doorbell to ring through your home’s wired chime.Is installation of Wyze doorbells and chimes easy?
Yes, Wyze products are designed for easy installation. The Universal Wi-Fi Chime is plug-and-play, while the Video Doorbell v2 comes with all necessary accessories and a quick start guide. The Chime Controller requires a simple wiring process compatible with most mechanical chimes.What is included in the Wyze Front Porch Security Bundle?
The Front Porch Security Bundle includes a Wyze Video Doorbell (v2 or Pro), Wyze Lock, and Wyze Chime, providing a complete smart home entry solution with video monitoring, two-way audio, remote lock control, and fast notifications.Can I control my Wyze Lock from the video doorbell app?
Yes, the Wyze app allows you to control your Wyze Lock directly from the video doorbell interface, making it easy to manage your home’s entry points remotely.Do Wyze doorbells and chimes work with smart home systems?
Wyze doorbells and chimes integrate seamlessly with popular smart home ecosystems, including Alexa, Google Assistant, and IFTTT, for enhanced automation and voice control.What makes Wyze doorbell and chime solutions stand out?
Wyze offers fast and reliable notifications, flexible installation options, high-quality 2K video, smart automations, weather-resistant designs, and seamless integration with other Wyze devices and smart home platforms.
