Top Doorbells with Chime for Smart Home Security
Best Doorbells with Chime for Your Smart Home
When it comes to enhancing your home security and convenience, a doorbell with a chime is an essential device. Whether you want to hear a clear alert when someone is at your door or integrate your doorbell with smart home features, the right doorbell and chime setup can make all the difference. Below, we explore top products designed to provide reliable chimes and smart functionalities for your home.
Wyze Universal Wi-Fi Chime: Simple Setup, Smart Alerts
Key Features
  • Easy Plug-In Installation: No complicated wiring needed; just plug it in and start receiving alerts.
  • Smart Notifications: Get notified instantly when someone rings your doorbell or if suspicious activity is detected.
  • Automation Ready: Connect with your Wyze cameras to trigger chimes when motion or person detection occurs, such as your kitchen’s cookie cam.
  • Compact and Sleek Design: Comes in a stylish black finish that fits any home décor.
The Wyze Universal Wi-Fi Chime is perfect for those who want a fuss-free chime solution that integrates seamlessly with existing Wyze cameras and doorbells. It ensures you never miss a visitor or delivery with clear, timely alerts.
Wyze Video Doorbell v2 with Chime Controller: Crystal Clear 2K Video and Sound
Why Choose Wyze Video Doorbell v2?
  • High-Resolution 2K Video: Capture every detail with sharp, clear video quality.
  • Local MicroSD Storage: Save footage locally for easy access and privacy.
  • Two-Way Audio: Communicate with visitors directly through your smartphone.
  • Motion-Activated Voice Deterrence: Automatically warn unwanted guests with a pre-recorded message.
  • Includes Chime Controller: The chime controller unit ensures your doorbell rings inside your home, compatible only with Wyze Video Doorbell v2 and Duo Cam Doorbell.
This wired video doorbell is ideal for homeowners who want advanced video capabilities combined with a reliable chime system. The chime controller adds convenience by providing audible alerts indoors.
The Front Porch Security Bundle: Complete Smart Home Entry Solution
Bundle Highlights
  • Wyze Video Doorbell with Chime: View your front porch in 1080p HD with two-way audio and receive chime alerts.
  • Wyze Lock Integration: Lock or unlock your door remotely and monitor lock history via the Wyze app.
  • Smart Assistant Compatibility: Works seamlessly with Alexa and Google Assistant for voice control.
  • Comprehensive Security: Monitor motion events and control access all from one app.
This all-in-one bundle is perfect for those looking to upgrade their front porch security with a video doorbell and chime, plus smart lock capabilities for enhanced convenience and safety.
Additional Chime Accessories for Wyze Doorbells
Wyze Chime Controller
  • Standalone Unit: Designed exclusively for Wyze Video Doorbell v2 and Duo Cam Doorbell.
  • Easy Wiring: Simple installation process to connect your doorbell to an indoor chime.
  • Compact Size: Fits discreetly inside your home.
Wyze Chime (Standalone)
  • Compatibility: Works only with Wyze Video Doorbell (Wired) versions, not compatible with Pro or v2 models.
  • Affordable Option: Provides a basic chime solution for older Wyze wired doorbells.
These accessories allow you to customize your doorbell chime setup depending on your specific Wyze doorbell model and installation preferences.
Why Choose a Doorbell with Chime?
A doorbell with a chime not only alerts you when visitors arrive but also enhances your home’s security by integrating with smart cameras and automation systems. Whether you prefer a simple plug-in chime or a full smart home bundle, these products offer flexibility, ease of use, and peace of mind.
Smart Home Doorbell in Use Alt text: Family using smart doorbell with chime at home entrance Front Porch Security Setup Alt text: Front porch with video doorbell and smart lock installed Wyze Video Doorbell v2 Installation Alt text: Installing Wyze Video Doorbell v2 with chime controller
Enhance your home’s security and convenience today with these top-rated doorbells with chime options from Wyze. Whether you want a simple chime or a full smart home security bundle, these products deliver reliable performance and smart features tailored to your needs.
FeatureWyze Universal Wi-Fi ChimeThe Front Porch Security BundleWyze Video Doorbell v2Wyze Chime ControllerWyze Chime
TypeAccessoryBundleCameraAccessoryAccessory
Price$19.98$123.99 - $173.97 (varies by variant)$44.98$17.99$13.99
DescriptionPlug-in Wi-Fi chime, no wiring needed, smart automations with Wyze camsIncludes Wyze Video Doorbell, Wyze Lock, and Chime for front porch securityWired video doorbell with 2K video, two-way audio, local microSD storageStandalone chime controller, compatible with Wyze Video Doorbell v2 and Duo Cam DoorbellStandalone chime, only works with Wyze Video Doorbell (Wired)
CompatibilityWorks with all Wyze cameras and doorbellsIncludes Wyze Video Doorbell and Chime, Wyze LockCompatible with Wyze Chime ControllerCompatible with Wyze Video Doorbell v2 and Duo Cam DoorbellCompatible with Wyze Video Doorbell (Wired) only
InstallationPlug-in, no wiringBundle includes devices with various installation methodsWired (16V-24V AC), screw mountingEasy wiring installationMechanical chime compatibility, standalone
PowerPlug-inVaries by included devicesWired (16V-24V AC, ≥10VA)AC16V/AC24V, ≥10VAStandard US power outlet (100V-240V, 0.1A, 50/60Hz)
AlertsChime alerts for doorbell rings and person detection via automationVideo alerts, two-way audio, lock control via appReal-time alerts, two-way audio, motion-activated voice deterrenceTriggers chime alerts for doorbell eventsMechanical chime sounds only
Video ResolutionN/A1080p HD (Wyze Video Doorbell included)2K (2048 x 1536)N/AN/A
Included Items1x Wyze Universal Wi-Fi ChimeWyze Video Doorbell, Wyze Lock, Wyze Chime1x Wyze Video Doorbell v2, 1x Chime Controller, Wall Plate, Wedge, Installation Kit, Wire Caps, Screws, Quick Start Guide1x Chime Controller Unit1x Standalone Chime
Special FeaturesSmart Automations, chimes on person detectionRemote lock/unlock, lock history, two-way audio on doorbellLocal microSD storage up to 256GB, IP65 weather resistanceCompatible with nearly every mechanical chimeMultiple chime sounds: modern, classic, animal, automation, intruder alarm
Weather ResistanceNot specifiedIncluded devices weather resistantIP65--
WarrantyNot specifiedNot specified1 YearNot specifiedNot specified
What are the best doorbells with chime for smart homes?The best doorbells with chime for smart homes include the Wyze Universal Wi-Fi Chime, Wyze Video Doorbell v2 with Chime Controller, and the Front Porch Security Bundle. These options offer reliable chime alerts, smart home integration, and advanced security features.
How does the Wyze Universal Wi-Fi Chime work?The Wyze Universal Wi-Fi Chime is a plug-in device that provides instant alerts when someone rings your doorbell or when motion is detected by connected Wyze cameras. It features easy installation, smart notifications, and a compact design that fits any home décor.
What features does the Wyze Video Doorbell v2 with Chime Controller offer?The Wyze Video Doorbell v2 with Chime Controller offers 2K high-resolution video, local microSD storage, two-way audio, motion-activated voice deterrence, and an included chime controller for reliable indoor alerts. It is ideal for homeowners seeking advanced video and audio capabilities.
What is included in the Front Porch Security Bundle?The Front Porch Security Bundle includes a Wyze Video Doorbell with Chime, Wyze Lock integration for remote locking and unlocking, smart assistant compatibility with Alexa and Google Assistant, and comprehensive security features managed through the Wyze app.
Are there additional chime accessories available for Wyze doorbells?Yes, Wyze offers additional chime accessories such as the Wyze Chime Controller, designed for the Wyze Video Doorbell v2 and Duo Cam Doorbell, and the Wyze Chime (Standalone), which is compatible with older Wyze Video Doorbell (Wired) models.
Why should I choose a doorbell with a chime for my home?A doorbell with a chime provides clear alerts when visitors arrive and enhances home security by integrating with smart cameras and automation systems. It offers convenience, flexibility, and peace of mind for homeowners.
Is the Wyze Chime Controller compatible with all Wyze doorbells?No, the Wyze Chime Controller is designed exclusively for the Wyze Video Doorbell v2 and Duo Cam Doorbell. It is not compatible with other Wyze doorbell models.
Can I use the Wyze Chime (Standalone) with the latest Wyze doorbells?The Wyze Chime (Standalone) is only compatible with Wyze Video Doorbell (Wired) versions and is not compatible with the Pro or v2 models.
Do Wyze doorbells with chime support smart home integration?Yes, Wyze doorbells with chime support smart home integration, including compatibility with Alexa and Google Assistant, as well as automation with Wyze cameras and other smart devices.
How do I install a Wyze doorbell with chime?Installation varies by model. The Wyze Universal Wi-Fi Chime offers simple plug-in installation with no wiring required, while the Wyze Video Doorbell v2 with Chime Controller requires wired installation. Both come with user-friendly instructions for setup.
Can you tell me more about the features of the Wyze Universal Wi-Fi Chime?How does the Wyze Video Doorbell v2 compare to other doorbells on the market?Do you have any ongoing sales or promotions for doorbells with chimes?
