DIY IP65 Weather-Resistant Wyze Cam v4 Security System Kits
DIY Security System with IP65 Weather Resistant Wyze Cam v4 Kit
When it comes to securing your home or business with a reliable DIY security system, the Wyze Cam v4 series stands out as a top choice. Designed with IP65 weather resistance, these cameras are built to withstand rain, snow, and harsh outdoor conditions, making them perfect for any environment. Whether you want crystal-clear video, color night vision, or smart home integration, the Wyze Cam v4 kits offer everything you need for a comprehensive security setup.
Why Choose Wyze Cam v4 for Your DIY Security System?
Wyze Cam v4 is engineered to deliver unmatched security performance with advanced features that make installation and daily use simple and effective.
Key Features of Wyze Cam v4
  • 2.5K Quad High Definition (QHD) Resolution: Capture every detail with stunning clarity, four times the resolution of 1080p HD.
  • IP65 Weather Resistance: Rated to operate flawlessly in rain, snow, and dust, perfect for outdoor use.
  • Enhanced Color Night Vision: See vibrant colors even in low-light conditions, surpassing traditional black-and-white night vision.
  • Motion-Activated Spotlight & Siren: Deter intruders with a bright spotlight and a loud 99 dB siren.
  • Wide Dynamic Range (WDR): Enjoy rich, vibrant colors and balanced lighting in every shot.
  • Advanced Two-Way Talk: Clear, echo-canceled audio lets you communicate through the camera.
  • Wi-Fi 6 Support: Maintain a stronger, more reliable connection at greater distances.
  • Local Storage & Cloud Options: Record continuously to a microSD card (up to 512GB) or opt for cloud storage with subscription plans.
  • Smart Home Integration: Compatible with Alexa, Google Assistant, and IFTTT for seamless automation.
  • Easy Setup & Mounting: Screw-free magnetic mount and Bluetooth® setup make installation hassle-free.
Wyze Cam v4 Product Variants and Kits
Wyze Cam v4 Outdoor Bundle
The Wyze Cam v4 Outdoor Bundle is an excellent all-in-one package for those looking to secure outdoor spaces with ease. This bundle includes:
  • Wyze Cam v4 camera (available in White, Grey, or Black)
  • Wyze Outdoor Power Adapter for continuous outdoor power
  • 128GB Wyze MicroSD Card for 24/7 local recording
This bundle offers the same premium 2.5K QHD resolution, enhanced color night vision, and IP65 weather resistance, plus the convenience of a power adapter designed specifically for outdoor use.
Perfect for front yards, backyards, and entryways, this bundle ensures your camera stays powered and protected no matter the weather.
Outdoor security camera mounted on house exterior Wyze Cam v4 Outdoor Bundle in action, providing clear night vision and weather resistance.
For those wanting to cover multiple areas or set up a more comprehensive system, the Wyze Cam v4 Home Security Bundle includes multiple cameras with all the features of the single unit plus:
  • Four Wyze Cam v4 cameras with IP65 rating
  • 128GB microSD cards included for each camera
  • Motion-activated spotlight and siren on every unit
  • Person detection and advanced motion zones for smarter alerts
This bundle is ideal for indoor and outdoor use, providing full coverage with easy mounting options including wall, ceiling, and magnetic mounts.
Wyze Cam v4 + FREE 32GB MicroSD Card
If you want to start with a single camera but still enjoy local recording, the Wyze Cam v4 + FREE 32GB MicroSD Card package is a great choice. It includes:
  • Wyze Cam v4 with all core features
  • A free 32GB microSD card for continuous local recording
  • IP65 weather resistance for outdoor durability
  • Motion-activated spotlight and person detection
This option is perfect for those who want to test the waters with a single camera but still benefit from robust features and weatherproof design.
Enhance Your Wyze Cam v3 with the Spotlight Kit
If you already own a Wyze Cam v3 and want to upgrade its night-time security, the Wyze Cam v3 Spotlight Kit is a smart accessory. It features:
  • Motion-activated 70-lumen spotlight with a 130-degree beam angle
  • IP65 weather resistance for outdoor use
  • Easy USB-powered connection
  • Extends night vision capabilities with bright, natural light
This kit is a cost-effective way to add a spotlight to your existing Wyze Cam v3, enhancing visibility and deterrence during nighttime hours.
Installation and Setup Tips for Your DIY Security System
  • Placement: Thanks to IP65 rating, place your Wyze Cam v4 anywhere outdoors—porches, driveways, gardens, or garages.
  • Mounting: Use the magnetic mount for quick installation without tools or opt for wall/ceiling mounts for permanent setups.
  • Power: For outdoor use, pair your camera with the Wyze Outdoor Power Adapter to ensure continuous power.
  • Connectivity: Use Wi-Fi 6 routers for the best connection stability and range.
  • Storage: Insert a microSD card for local 24/7 recording or subscribe to Wyze Cam Plus for cloud storage and AI-powered alerts.
Conclusion
The Wyze Cam v4 kits provide a powerful, weather-resistant, and easy-to-install DIY security solution. Whether you choose the single camera with free microSD, the outdoor bundle, or the home security multi-camera bundle, you get crystal-clear 2.5K video, enhanced color night vision, and smart features that keep your property safe day and night. Invest in a Wyze Cam v4 kit today and enjoy peace of mind with a professional-grade security system you can set up yourself. Family enjoying secure home environment Wyze Cam v4 keeps your home safe and secure, indoors and outdoors.
Product Summary
Product NameKey FeaturesPrice Range
Wyze Cam v42.5K QHD, IP65, Color Night Vision, SpotlightFrom $35.98
Wyze Cam v4 Outdoor BundleIncludes Outdoor Power Adapter & 128GB microSD$69.99
Wyze Cam v4 Home Security Bundle4 Cameras, 128GB microSD each, Spotlight, Siren$169.99
Wyze Cam v4 + FREE 32GB microSDSingle camera with free 32GB microSD card$35.98
Wyze Cam v3 Spotlight KitMotion-activated spotlight, IP65 rated$16.98
Secure your property with the best DIY IP65 weather-resistant security cameras from Wyze. Experience superior video quality, smart alerts, and reliable outdoor performance with Wyze Cam v4 kits.
FeatureWyze Cam v4Wyze Cam v4 Outdoor BundleWyze Cam v4 Home Security BundleWyze Cam v4 + FREE 32GB MicroSD CardWyze Cam v3 Spotlight Kit
Price$35.98 (1 Pack)$69.99$169.99$35.98$16.98
Color OptionsBlack, Clear (sold out), Grey, WhiteBlack, Grey, WhiteNot specifiedBlack, Grey, WhiteN/A
Resolution2.5K QHD (2560x1440)2.5K QHD2.5K QHD (2560x1440)2.5K QHDN/A
Night VisionEnhanced Color Night VisionEnhanced Color Night VisionColor Night Vision + IR LEDsEnhanced Color Night VisionN/A
SpotlightMotion-activated spotlightMotion-activated spotlightMotion-activated spotlightMotion-activated spotlightMotion-activated spotlight (for v3)
SirenYes (99 dB)YesYes (99 dB)YesN/A
AudioEnhanced Two-Way TalkEnhanced Two-Way TalkImproved 2-way audioEnhanced Two-Way TalkN/A
Weather ResistanceIP65IP65IP65IP65IP65
Wi-Fi SupportWi-Fi 6Wi-Fi 6Wi-Fi 6Wi-Fi 6N/A
Local RecordingmicroSD card up to 512GB (sold separately)Includes 128GB microSD cardIncludes 128GB microSD cardRequires microSD card (included 32GB)N/A
Continuous 24/7 RecordingYesYesYesYesN/A
Motion & Sound DetectionYesYesYesYesN/A
Motion Detection ZonesYesYesYesYesN/A
Smoke & CO AlertsYesYesYesYesN/A
Field of View (FOV)115.8° (D), 98.5° (H), 53.1° (V)115.8° (D), 98.5° (H), 53.1° (V)115.8° (D), 98.5° (H), 53.1° (V)115.8° (D), 98.5° (H), 53.1° (V)N/A
Mounting OptionsStand, Wall, Ceiling, MagneticNot specifiedStand, Wall, Ceiling, MagneticNot specifiedN/A
Included AccessoriesWall Mount Plate, Tape, Screw Kit, USB Power Adapter, USB CableOutdoor Power Adapter, 128GB microSD CardNot specifiedNot specifiedSpotlight, USB cable splitter
Video FPS20 FPS (day), 15 FPS (night)20 FPS (day), 15 FPS (night)20 FPS (day), 15 FPS (night)Not specifiedN/A
Digital Zoom8x8x8xNot specifiedN/A
Wide Dynamic Range (WDR)YesYesYesYesN/A
AI Features (Person Detection, Smart Focus)YesYesYesYesN/A
Bluetooth Version5.2Not specifiedNot specifiedNot specifiedN/A
Warranty1 Year1 Year1 YearNot specified1 Year
What makes the Wyze Cam v4 a good choice for a DIY security system?The Wyze Cam v4 is an excellent choice for DIY security systems due to its 2.5K Quad High Definition (QHD) resolution, IP65 weather resistance for outdoor durability, enhanced color night vision, motion-activated spotlight and siren, Wi-Fi 6 support, and easy installation with a magnetic mount. It also offers local and cloud storage options and integrates with Alexa, Google Assistant, and IFTTT for smart home automation.
Is the Wyze Cam v4 weatherproof for outdoor use?Yes, the Wyze Cam v4 is rated IP65 weather resistant, making it suitable for outdoor use in rain, snow, and dusty environments. It is designed to operate reliably in harsh weather conditions, ensuring year-round security for your property.
What is included in the Wyze Cam v4 Outdoor Bundle?The Wyze Cam v4 Outdoor Bundle includes a Wyze Cam v4 camera (available in White, Grey, or Black), a Wyze Outdoor Power Adapter for continuous outdoor power, and a 128GB Wyze MicroSD Card for 24/7 local recording. This bundle is ideal for securing outdoor spaces like front yards, backyards, and entryways.
What features are available in the Wyze Cam v4 Home Security Bundle?The Wyze Cam v4 Home Security Bundle includes four Wyze Cam v4 cameras, each with IP65 weather resistance, 128GB microSD cards, motion-activated spotlight and siren, person detection, and advanced motion zones. It provides comprehensive indoor and outdoor coverage with flexible mounting options.
Does the Wyze Cam v4 support local and cloud storage?Yes, the Wyze Cam v4 supports both local and cloud storage. You can record continuously to a microSD card (up to 512GB supported) for local storage, or subscribe to Wyze Cam Plus for cloud storage and AI-powered alerts.
How easy is it to install the Wyze Cam v4?The Wyze Cam v4 is designed for easy DIY installation. It features a screw-free magnetic mount and Bluetooth® setup, allowing for quick and hassle-free mounting on walls, ceilings, or metal surfaces. No special tools are required.
What is the difference between the Wyze Cam v4 and the Wyze Cam v3 Spotlight Kit?The Wyze Cam v4 is a standalone security camera with advanced features like 2.5K QHD resolution, color night vision, and IP65 weather resistance. The Wyze Cam v3 Spotlight Kit is an accessory for the Wyze Cam v3, adding a motion-activated 70-lumen spotlight to enhance night vision and deterrence. The spotlight kit is USB-powered and also IP65 rated for outdoor use.
Can I use the Wyze Cam v4 with smart home devices?Yes, the Wyze Cam v4 is compatible with popular smart home platforms including Alexa, Google Assistant, and IFTTT. This allows you to integrate the camera into your smart home routines and control it with voice commands or automation.
What storage options are available with Wyze Cam v4 kits?Wyze Cam v4 kits offer both local and cloud storage options. You can use a microSD card (up to 512GB) for continuous local recording, or subscribe to Wyze Cam Plus for cloud storage, which provides additional features like AI-powered alerts and event recording.
What is the price range for Wyze Cam v4 security kits?The Wyze Cam v4 starts at $35.98 for a single camera with a free 32GB microSD card. The Outdoor Bundle is priced at $69.99 and includes an outdoor power adapter and 128GB microSD card. The Home Security Bundle, which includes four cameras and accessories, is available for $169.99.
How does the Wyze Cam v4 enhance night vision?The Wyze Cam v4 features enhanced color night vision, allowing you to see vibrant colors even in low-light conditions. It also includes a motion-activated spotlight to illuminate dark areas and improve visibility, surpassing traditional black-and-white night vision.
What mounting options are available for Wyze Cam v4?Wyze Cam v4 offers flexible mounting options, including a screw-free magnetic mount for quick installation and wall or ceiling mounts for more permanent setups. This makes it easy to place the camera wherever you need security coverage.
Does the Wyze Cam v4 support two-way audio?Yes, the Wyze Cam v4 features advanced two-way talk with clear, echo-canceled audio, allowing you to communicate through the camera from your smartphone or smart device.
What is the benefit of Wi-Fi 6 support in Wyze Cam v4?Wi-Fi 6 support in the Wyze Cam v4 ensures a stronger, more reliable wireless connection, even at greater distances from your router. This results in smoother video streaming and more stable connectivity for your security system.
What are the key features of the Wyze Cam v4?Can you tell me more about the Wyze Cam v4 Outdoor Bundle?Are there any ongoing sales or discounts for the Wyze Cam products?
