DIY Wi-Fi Sprinkler Controller with Zone Moisture Monitoring
DIY Installation Wi-Fi Sprinkler Controller with Zone Moisture Monitoring
Upgrade your lawn irrigation system with a smart, easy-to-install Wi-Fi sprinkler controller that offers precise zone moisture monitoring and weather-based watering. Whether you want to save water, protect your plants, or simply automate your garden care, the Wyze Sprinkler Controller ecosystem provides an affordable and efficient solution tailored for DIY enthusiasts.
Wyze Sprinkler Controller: Smarter, Simpler, Greener Lawn Care
The Wyze Sprinkler Controller is designed for homeowners who want full control over their irrigation system from anywhere using Wi-Fi. With a quick DIY installation that takes less than 20 minutes, this controller replaces your existing system and immediately starts optimizing your watering schedule.
Key Features:
  • 8 Customizable Irrigation Zones: Manage up to 8 different zones with unique names and photos for easy identification in the Wyze app.
  • Remote Control via App: Start, stop, or adjust watering schedules from your smartphone, no matter where you are.
  • WeatherSense Certified: Uses EPA WaterSense certification standards to ensure water-efficient irrigation by adapting watering schedules based on real-time weather data.
  • Sprinkler Plus Integration: Comes with a free 1-year subscription to Sprinkler Plus, unlocking advanced weather-based watering features and moisture level insights.
  • Intelligent Weather Skips: Automatically skips watering during rain or unfavorable weather conditions to conserve water and protect your plants.
  • Peace of Mind with Wyze Cam: Integrate with Wyze Cam to monitor your lawn watering in real-time and receive notifications if your sprinklers are running.
Technical Specs:
  • Supports up to 8 zones
  • Wi-Fi enabled for remote access
  • Compatible with most residential irrigation systems
  • Easy app-based setup and control
"Affordably priced smart sprinkler controller" - DigitalTrends
"#1 Affordable Smart Sprinkler Controller" - ZDNet
Smartphone app controlling sprinklers outdoors Control your sprinkler system remotely with the Wyze app
Wyze Sprinkler Plus: Unlock Weather-Based Watering and Moisture Monitoring
Wyze Sprinkler Plus is a subscription service that enhances your sprinkler controller with smart weather-based features to keep your yard green and healthy while saving water.
Benefits of Sprinkler Plus:
  • Advanced Moisture Insights: View historical, current, and forecasted moisture levels for each irrigation zone.
  • Hyper-Localized Weather Data: Receive watering recommendations based on precise local weather conditions.
  • Watering Activity Forecast: Plan your watering schedule with upcoming weather and moisture data directly in the app.
  • Water Conservation: Intelligent watering skips prevent unnecessary irrigation during rain or high humidity.
This service is included free for one year with the purchase of the Wyze Sprinkler Controller, making it a cost-effective way to optimize your lawn care. Weather-based watering with Wyze app Smart weather-based watering powered by Sprinkler Plus
Wyze Weatherproof Sprinkler Controller Box: Durable Outdoor Protection
For outdoor installations, the Wyze Weatherproof Sprinkler Controller Box offers a rugged, IP65-rated enclosure to protect your sprinkler controller from the elements.
Features:
  • IP65 Weatherproof Rating: Fully protects against dust and water jets, ideal for outdoor use.
  • Durable Design: Equipped with 4 secure clasps and a gridded cover for extra strength and longevity.
  • Flexible Power Options: Supports hardwiring or connection to an outdoor outlet.
  • Compatibility: Designed exclusively for the Wyze Sprinkler Controller.
This accessory ensures your smart sprinkler controller stays safe and functional in any weather, extending the life of your investment.
Why Choose Wyze for Your DIY Wi-Fi Sprinkler Controller?
Wyze offers a comprehensive, user-friendly solution for smart irrigation that combines affordability, ease of installation, and advanced technology. With the Wyze Sprinkler Controller and Sprinkler Plus subscription, you get:
  • Quick DIY setup in under 20 minutes
  • Precise zone control with moisture monitoring
  • WaterSense certification for eco-friendly watering
  • Integration with Wyze Cam for added security and monitoring
  • Durable weatherproof housing for outdoor protection
Optimize your lawn watering routine, save water, and enjoy a greener, healthier yard with Wyze’s smart sprinkler solutions.
Feature/SpecificationWyze Sprinkler ControllerWyze Sprinkler PlusWyze Weatherproof Sprinkler Controller Box
TypeConnected HomeService SubscriptionAccessories
Price$59.99 (Controller), $99.98 (Controller + Box)$9.99 (Annual License)$39.99
DescriptionSmart zoned control for lawn irrigationUnlocks smart weather-based watering featuresWeatherproof box to mount Wyze Sprinkler Controller
ControlRemote control via appWeather intelligence and advanced insightsN/A
Irrigation ZonesUp to 8 customizable zonesN/AN/A
Weather-Based WateringIncluded 1 year with Sprinkler Plus subscriptionWeather intelligence, smart weather skipsN/A
WaterSense CertificationYes, EPA WaterSense certifiedN/AN/A
Installation Time20 minutes20 minutes (digital license)N/A
CompatibilityMost residential irrigation systems in North AmericaUS onlyCompatible only with Wyze Sprinkler Controller
Weatherproof RatingNoN/AIP65 fully weatherproof
Power OptionsRequires power to operate irrigation systemN/AHardwire or outdoor outlet power
Additional FeaturesPersonalized schedules, peace of mind with Wyze Cam, advanced yard insights, intelligent weather skipsZone moisture info, advanced insights4 clasps and gridded cover for extra durability
Subscription Included1 Year Sprinkler Plus Weather Service includedNo subscription requiredN/A
What is the Wyze Wi-Fi Sprinkler Controller?The Wyze Wi-Fi Sprinkler Controller is a smart irrigation device that allows homeowners to control and automate their lawn watering system remotely using a smartphone app. It supports up to 8 customizable zones, offers weather-based watering, and features zone moisture monitoring for efficient and eco-friendly lawn care.
How easy is it to install the Wyze Sprinkler Controller?The Wyze Sprinkler Controller is designed for DIY installation and can typically be set up in under 20 minutes. It replaces your existing irrigation controller and comes with an easy app-based setup process.
How many irrigation zones does the Wyze Sprinkler Controller support?The Wyze Sprinkler Controller supports up to 8 customizable irrigation zones, allowing you to manage different areas of your lawn or garden with unique names and photos for easy identification in the Wyze app.
Can I control my sprinklers remotely with the Wyze Sprinkler Controller?Yes, you can start, stop, or adjust your watering schedules from anywhere using the Wyze app on your smartphone, thanks to the controller’s Wi-Fi connectivity.
What is Wyze Sprinkler Plus and what features does it offer?Wyze Sprinkler Plus is a subscription service that enhances your sprinkler controller with advanced weather-based watering features, including historical, current, and forecasted moisture insights for each zone, hyper-localized weather data, watering activity forecasts, and intelligent watering skips to conserve water.
Is Sprinkler Plus included with the Wyze Sprinkler Controller?Yes, a free 1-year subscription to Sprinkler Plus is included with the purchase of the Wyze Sprinkler Controller, giving you access to advanced weather-based and moisture monitoring features.
How does the Wyze Sprinkler Controller help save water?The Wyze Sprinkler Controller uses EPA WaterSense certification standards and real-time weather data to optimize watering schedules. It automatically skips watering during rain or high humidity, ensuring efficient water use and helping you conserve water.
Can I monitor my lawn watering in real-time?Yes, you can integrate the Wyze Sprinkler Controller with Wyze Cam to monitor your lawn watering in real-time and receive notifications when your sprinklers are running.
Is the Wyze Sprinkler Controller compatible with most irrigation systems?Yes, the Wyze Sprinkler Controller is compatible with most residential irrigation systems, making it a versatile choice for homeowners looking to upgrade their lawn care.
What is the Wyze Weatherproof Sprinkler Controller Box?The Wyze Weatherproof Sprinkler Controller Box is a durable, IP65-rated enclosure designed to protect your Wyze Sprinkler Controller from dust and water, making it ideal for outdoor installations. It features a rugged design with secure clasps and flexible power options.
Why should I choose Wyze for my smart sprinkler controller?Wyze offers an affordable, user-friendly smart sprinkler solution with quick DIY installation, precise zone control, advanced moisture monitoring, WaterSense certification, Wyze Cam integration, and durable weatherproof housing for outdoor protection.
How does the Wyze Sprinkler Controller integrate with the Wyze app for remote control?What are the benefits of using the Wyze Sprinkler Plus subscription?Are there any ongoing promotions or discounts available for the Wyze Sprinkler Controller?
