Cordless Stick Vacuum with Powerful Suction for Small Apartments: Wyze Cordless Vacuum S
When it comes to keeping small apartments spotless, a lightweight yet powerful vacuum is essential. The
Wyze Cordless Vacuum S stands out as a top choice for those seeking a cordless stick vacuum with exceptional suction power, long battery life, and smart features tailored for compact living spaces.
Why Choose Wyze Cordless Vacuum S for Small Apartments?
The Wyze Cordless Vacuum S is designed to deliver professional-grade cleaning performance without the bulk. Its compact size and featherlight weight make it ideal for maneuvering around furniture and tight corners common in small apartments.
Experience the freedom of cordless cleaning with up to 20,000 Pa suction power in Turbo Mode, ensuring even the tiniest dust and debris are effortlessly removed.
Key Features at a Glance
Suction Power:
- Turbo Mode: 20,000 Pa
- Medium Mode: 9,000 Pa
- ECO Mode: 6,000 Pa
Weight:
- Main Unit: 2.8 lbs
- Assembled Unit: 4.9 lbs
Battery Life:
- ECO Mode: 40 minutes
- Medium Mode: 23 minutes
- Turbo Mode: 10 minutes
- Battery Type: 6-cell lithium-ion, 2,000mAh*6
- Dust Cup Volume: 0.7 L
- Noise Level: 65 dBA in Turbo Mode
Dimensions:
- Main Unit: 12.4 x 4.5 x 8.7 inches
- Assembled Unit: 41.1 inches
- Color: Steel grey with Wyze green accents
Advanced Cleaning Technology
Equipped with
two powerful motors and a
3-stage filtration system, the Wyze Cordless Vacuum S ensures thorough cleaning and improved air quality by trapping fine dust and allergens. The brush head features
6 daylight-bright LED lights to illuminate dark corners and under furniture, making it easier to spot hidden dirt.
Versatile Attachments Included
- Crevice Tool for narrow spaces
- Floor Brush for hard floors and carpets
- HEPA Filter and Filter Housing for clean air
- Dust Cap and Standard Tube for easy handling
- Quick Start Guide for hassle-free setup
Effortless vacuuming in small spaces with pets
Enhance Your Cleaning Experience with Wyze Accessories
To maximize the performance and convenience of your Wyze Cordless Vacuum S, consider these compatible accessories designed specifically for this model:
Wyze Cordless Vacuum S - Battery Pack
- Price: $59.99
- Extend your cleaning sessions with an additional battery pack designed exclusively for the Wyze Cordless Vacuum S. Perfect for larger cleaning tasks or multiple rooms without waiting for a recharge.
- 30-day hassle-free returns
Wyze Cordless Vacuum S - Charger
- Price: $4.99
- Keep your vacuum powered up with a replacement charger compatible with the Wyze Cordless Vacuum S.
- Price: $15.99 (compare at $29.99)
- This foldable tube bends for easier reach under furniture and awkward spaces, reducing strain during cleaning.
Wyze Cordless Vacuum - HEPA Filter (2 Pack)
- Price: $15.99
- Replace filters regularly to maintain optimal suction and air quality. Designed only for Wyze Cordless Vacuum.
Wyze Cordless Vacuum - Mini Motorized Brush Head
- Price: $29.99
- Ideal for cleaning car seats, sofas, and upholstery, this mini brush head is a perfect companion for detailed cleaning jobs.
Pet-friendly vacuuming made easy in small apartments
Perfect for Small Apartments and Busy Lifestyles
The Wyze Cordless Vacuum S combines
powerful suction,
lightweight design, and
smart features to make cleaning quick and efficient. Its long battery life and interchangeable battery system allow you to clean your entire apartment without interruption. The compact size and included attachments make it easy to clean floors, upholstery, and hard-to-reach areas.
Whether you live in a cozy studio or a one-bedroom apartment, the Wyze Cordless Vacuum S is engineered to keep your space spotless with minimal effort.
Ideal for hardwood floors and small living spaces
Summary
The
Wyze Cordless Vacuum S is the ultimate cordless stick vacuum for small apartments, offering:
- Exceptional suction power up to 20,000 Pa
- Lightweight and easy to maneuver (2.8 lbs main unit)
- Long-lasting battery with quick recharge
- Smart LED display and bright brush head lights
- Multiple attachments for versatile cleaning
- Affordable accessories to extend functionality
Make your cleaning routine effortless and efficient with the Wyze Cordless Vacuum S — the smart choice for small apartment living.
What makes the Wyze Cordless Vacuum S ideal for small apartments?
The Wyze Cordless Vacuum S is specifically designed for small apartments with its lightweight build (main unit weighs only 2.8 lbs), compact size, and powerful suction up to 20,000 Pa. Its maneuverability allows easy cleaning around furniture and tight spaces, making it perfect for compact living areas.How powerful is the suction on the Wyze Cordless Vacuum S?
The Wyze Cordless Vacuum S offers exceptional suction power with three modes: Turbo Mode at 20,000 Pa, Medium Mode at 9,000 Pa, and ECO Mode at 6,000 Pa. This ensures effective cleaning of dust, debris, and pet hair from various surfaces.What is the battery life of the Wyze Cordless Vacuum S?
The Wyze Cordless Vacuum S features a 6-cell lithium-ion battery, providing up to 40 minutes of cleaning in ECO Mode, 23 minutes in Medium Mode, and 10 minutes in Turbo Mode. You can also purchase an additional battery pack to extend your cleaning sessions.What attachments are included with the Wyze Cordless Vacuum S?
The Wyze Cordless Vacuum S comes with a crevice tool for narrow spaces, a floor brush for hard floors and carpets, a HEPA filter and filter housing, a dust cap, a standard tube, and a quick start guide for easy setup.Does the Wyze Cordless Vacuum S have a HEPA filter?
Yes, the Wyze Cordless Vacuum S is equipped with a HEPA filter as part of its 3-stage filtration system, which helps trap fine dust and allergens, improving air quality in your home.Are there any accessories available for the Wyze Cordless Vacuum S?
Yes, several accessories are available for the Wyze Cordless Vacuum S, including an additional battery pack, replacement charger, foldable vacuum tube for reaching under furniture, HEPA filter (2 pack), and a mini motorized brush head for upholstery and car interiors.How loud is the Wyze Cordless Vacuum S during operation?
The Wyze Cordless Vacuum S operates at a noise level of 65 dBA in Turbo Mode, making it relatively quiet and suitable for apartment living.Can the Wyze Cordless Vacuum S clean both hard floors and carpets?
Yes, the Wyze Cordless Vacuum S is designed to clean both hard floors and carpets effectively, thanks to its powerful suction and versatile floor brush attachment.What are the dimensions and weight of the Wyze Cordless Vacuum S?
The main unit of the Wyze Cordless Vacuum S measures 12.4 x 4.5 x 8.7 inches and weighs 2.8 lbs. When fully assembled, it is 41.1 inches long and weighs 4.9 lbs.Is the Wyze Cordless Vacuum S suitable for homes with pets?
Yes, the Wyze Cordless Vacuum S is pet-friendly, offering strong suction and a mini motorized brush head (sold separately) that is ideal for removing pet hair from upholstery, car seats, and other surfaces.How do the LED lights on the Wyze Cordless Vacuum S help with cleaning?
The Wyze Cordless Vacuum S features 6 daylight-bright LED lights on the brush head, which illuminate dark corners and areas under furniture, making it easier to spot and clean hidden dirt and debris.How large is the dust cup on the Wyze Cordless Vacuum S?
The Wyze Cordless Vacuum S has a dust cup volume of 0.7 liters, allowing you to clean multiple rooms before needing to empty it.
