Wyze Motion-Activated Cameras Behind Bars & Glass: Best Window Mount
Combining Motion Activation with Camera Behind Security Bars and Glass: The Perfect Wyze Setup
When it comes to securing your home with a camera mounted behind security bars and glass, combining motion activation technology with the right mounting accessories is essential. Wyze offers a smart solution with its Wyze Window Mount accessory paired with advanced motion-activated cameras like the Wyze Cam v4 Home Security Bundle and the Wyze Cam Floodlight v2. This combination ensures clear, glare-free views through glass, reliable motion detection, and enhanced security lighting.
Wyze Window Mount: Clear Views Through Glass with Security Bars
Designed for Glass Surfaces and Security Bars
The Wyze Window Mount is specifically engineered to attach Wyze cameras such as the Cam v3, v3 Pro, v4, and OG series directly to your window. This is ideal for mounting cameras behind security bars and glass, providing a clear, glare-free view without reflections that typically hinder camera performance.
  • Compatible with multiple Wyze camera models
  • Easy installation on glass surfaces
  • Eliminates glare and reflection for crystal-clear footage
  • Perfect for homes with security bars on windows
This mount upgrades your exterior security by allowing your camera to monitor through windows safely and effectively, maintaining the integrity of your security bars while capturing high-quality video.
Wyze Cam v4 Home Security Bundle: Motion-Activated Spotlight and Superior Video Quality
Advanced Motion Detection Behind Glass
The Wyze Cam v4 Home Security Bundle is a top choice for motion-activated security behind glass and bars. It features:
  • 2.5K QHD (2560x1440) resolution for crystal-clear video
  • Enhanced Color Night Vision for vivid nighttime footage
  • Motion-activated spotlight to illuminate and deter intruders
  • Wide field of view (115.8° diagonal) to cover large areas
  • IP65 weather resistance for outdoor durability
  • 24/7 local recording with microSD support up to 128GB
  • Wi-Fi 6 support for faster, more reliable connectivity
  • Compatibility with Alexa and Google Assistant for smart home integration
This camera’s motion-activated spotlight is especially useful when mounted behind security bars and glass, as it lights up the area only when motion is detected, saving energy while enhancing security.
Wyze Cam Floodlight v2: Powerful Lighting Meets Smart Motion Detection
Illuminate and Secure Your Property
For those looking to combine motion activation with robust lighting, the Wyze Cam Floodlight v2 is an excellent choice. It offers:
  • 2800 lumens of bright, dimmable LED light panels
  • 2K video with Color Night Vision and a 160° wide-angle lens
  • AI-powered light control and ambient light mode
  • Dusk-to-dawn automation for hands-free operation
  • IP65 weather resistance for all-season outdoor use
  • Built-in 105dB siren for audible deterrence
  • Two-way audio for communication through the camera
  • Supports local storage up to 256GB microSD card
Mounted behind security bars or glass, this floodlight camera not only detects motion but also floods the area with bright light, making it ideal for driveways, porches, and yards. Wyze Cam Floodlight v2 in action illuminating a driveway at night Bright, motion-activated floodlight camera for outdoor security
Why Combine Wyze Window Mount with Motion-Activated Cameras?
Mounting your Wyze camera behind security bars and glass can often cause glare and reduce image clarity. The Wyze Window Mount solves this by securely attaching the camera to the glass surface, eliminating reflections and providing a clear view.
By pairing this mount with motion-activated cameras like the Wyze Cam v4 or Wyze Cam Floodlight v2, you get:
  • Enhanced security with motion-triggered alerts and lighting
  • Clear, uninterrupted video through glass and bars
  • Flexible mounting options for windows and outdoor walls
  • Smart home compatibility for seamless control and monitoring
Additional Features to Consider
  • Two-Way Audio: Communicate with visitors or deter intruders directly through your camera.
  • Local and Cloud Storage: Choose between local microSD storage or cloud options for video recordings.
  • Smart Assistant Integration: Use Alexa or Google Assistant to control your cameras and lights with voice commands.
  • Weather Resistance: Both cameras and mounts are rated IP65, ensuring durability in various weather conditions.
Wyze Cam v4 mounted on a window with security bars, showing clear video feed on smartphone Clear, motion-activated security camera mounted behind glass and bars
Conclusion
For homeowners seeking to combine motion activation with cameras mounted behind security bars and glass, the Wyze Window Mount paired with the Wyze Cam v4 Home Security Bundle or the Wyze Cam Floodlight v2 offers an unbeatable combination of clarity, security, and smart features. These products ensure your home is monitored effectively without compromising on video quality or mounting flexibility. Secure your home with Wyze’s innovative mounting and motion-activated camera technology today.
FeatureWyze Window MountWyze Cam v4 Home Security BundleWyze Cam Floodlight v2
TypeAccessoryCamera BundleCamera
Compatible CamerasWyze Cam v3, v3 Pro, v4, Wyze Cam OG seriesWyze Cam v4Wyze Cam Floodlight v2
Price$9.98$169.99$89.98
Mounting SurfaceGlass (window)N/AWall or Ceiling
Video ResolutionN/A2.5K QHD (2560x1440)2K (2304 x 1296)
Night VisionReduces glare (mount accessory)Enhanced Color Night VisionColor Night Vision
Field of ViewN/A115.8° DFOV, 98.5° HFOV, 53.1° VFOV160° Diagonal
AudioN/A2-way audio, built-in speaker, 99dB speakerBuilt-in speaker and microphone; 2-way audio
LightingN/A2 white spotlight LEDs (72 lumens)2800 Lumens, 2 dimmable LED light panels
Power SupplyN/AWired (Indoor USB Power Adapter included)Hardwired 110-120V AC
ConnectivityN/AWi-Fi 6, 2.4 GHz Wi-Fi802.11 b/g/n, 2.4 GHz Wi-Fi
StorageN/AmicroSD card up to 512 GB (included 128GB in bundle)Supports up to 256 GB microSD in ExFAT format
Weather ResistanceN/AIP65IP65
DimensionsN/A2in x 2in x 2 3/8in9.5in x 7.7in x 7.0in
WeightN/A0.49 lb (222 g)2.76 lbs (1.25 kg)
Additional FeaturesReduces glare and reflection on glass surfacesMotion-activated spotlight, smoke & CO alerts, WDR105dB siren, AI-Powered Light Control, dusk-to-dawn automation
WarrantyNot specified1 Year1 Year
Included ItemsMount only4x Wyze Cam v4, 4x 128GB MicroSD CardsCamera only
Can Wyze cameras be mounted behind security bars and glass?Yes, Wyze cameras can be effectively mounted behind security bars and glass using the Wyze Window Mount. This accessory is designed to attach Wyze cameras directly to glass surfaces, providing a clear, glare-free view while maintaining the integrity of your security bars.
What is the Wyze Window Mount and how does it improve camera performance?The Wyze Window Mount is an accessory engineered to attach Wyze cameras such as the Cam v3, v3 Pro, v4, and OG series directly to your window. It eliminates glare and reflections that typically hinder camera performance, ensuring crystal-clear footage even when mounted behind glass and security bars.
Which Wyze cameras are compatible with the Wyze Window Mount?The Wyze Window Mount is compatible with multiple Wyze camera models, including the Cam v3, v3 Pro, v4, and OG series, making it versatile for various home security setups.
How does motion detection work with Wyze cameras behind glass?Wyze cameras like the Cam v4 Home Security Bundle and Cam Floodlight v2 feature advanced motion detection that works effectively behind glass when paired with the Wyze Window Mount. The mount ensures a clear view, allowing the camera’s sensors to detect motion accurately and trigger alerts or lighting as needed.
What are the benefits of using the Wyze Cam v4 Home Security Bundle behind security bars and glass?The Wyze Cam v4 Home Security Bundle offers 2.5K QHD resolution, enhanced color night vision, a motion-activated spotlight, wide field of view, and IP65 weather resistance. When mounted behind security bars and glass with the Wyze Window Mount, it provides clear, motion-activated video and lighting for superior home security.
How does the Wyze Cam Floodlight v2 enhance outdoor security?The Wyze Cam Floodlight v2 combines a powerful 2800-lumen, dimmable LED floodlight with 2K video, color night vision, AI-powered light control, and a 160° wide-angle lens. It also features a built-in 105dB siren and two-way audio, making it ideal for illuminating and securing driveways, porches, and yards, even when mounted behind security bars or glass.
Does mounting a Wyze camera behind glass affect video quality?Mounting a Wyze camera behind glass can cause glare and reduce image clarity. However, the Wyze Window Mount is specifically designed to eliminate these issues, providing clear, uninterrupted video footage through glass and security bars.
Can Wyze cameras be integrated with smart home systems?Yes, Wyze cameras are compatible with Alexa and Google Assistant, allowing you to control your cameras and lights with voice commands and integrate them seamlessly into your smart home ecosystem.
What storage options are available for Wyze cameras?Wyze cameras support both local and cloud storage. You can use a microSD card (up to 128GB for Cam v4 and up to 256GB for Floodlight v2) for continuous local recording, or opt for cloud storage for additional backup and remote access.
Are Wyze cameras and mounts weather resistant?Yes, both Wyze cameras and the Wyze Window Mount are rated IP65 for weather resistance, ensuring reliable performance and durability in various outdoor conditions.
What additional features do Wyze cameras offer for home security?Wyze cameras offer two-way audio for communication, motion-activated lighting, AI-powered detection, dusk-to-dawn automation, and smart assistant integration, providing a comprehensive and flexible home security solution.
What are the installation steps for the Wyze Window Mount?Can the Wyze Window Mount be used with all Wyze camera models?Do you have any deals, ongoing sales, discounts, or promotions?
