Cheap Home Security Cameras: Affordable Protection for Your Home
Looking for reliable yet cheap home security cameras? Wyze offers a range of budget-friendly smart cameras that deliver excellent video quality, smart features, and easy installation without breaking the bank. Whether you want indoor monitoring, outdoor surveillance, or a video doorbell, Wyze has you covered with versatile options designed to keep your home safe day and night.
Wyze Cam v4: Crystal-Clear 2.5K QHD Security Camera
Experience unmatched security with the Wyze Cam v4, a top choice for affordable home protection. This camera boasts a stunning 2.5K QHD resolution that captures every detail with clarity. Its enhanced color night vision ensures you can see clearly even in low light, while the motion-activated spotlight adds an extra layer of security by illuminating suspicious activity.
- Resolution: 2.5K QHD for sharp, detailed video
- Night Vision: Enhanced color night vision for clear images in the dark
- Field of View: Wide 115.8° diagonal view to cover more area
- Connectivity: Supports Wi-Fi 6 for faster, more reliable streaming
- Smart Home Integration: Compatible with Alexa and Google Assistant
- Recording: 24/7 local recording keeps your footage safe without subscription fees
- Variants: Available in Black, Clear, Grey, and White; sold in packs of 1, 2, or 3
This camera is perfect for both indoor and outdoor use, made with durable polycarbonate and glass/plastic lenses to withstand the elements.
Wyze Cam Pan v3: 360° Pan and 180° Tilt for Full Coverage
For those who want to monitor every corner of their home, the Wyze Cam Pan v3 offers a dynamic 360° pan and 180° tilt feature. This indoor/outdoor camera is fully IP65 weather resistant, making it ideal for outdoor use when paired with the Wyze Outdoor Power Adapter.
- Pan & Tilt: 360° horizontal and 180° vertical movement for full room coverage
- Weatherproof: IP65 rating ensures durability in rain and snow
- Video Quality: Crisp HD video with motion tracking
- Colors: Available in Black and White
- Packs: Sold in 1, 2, or 3 packs for flexible coverage
<img src="https://www.wyze.com/cdn/shop/files/IMG_4216-5_1.jpg?v=1670422469&width=1500" alt="Wyze Cam Pan v3 in snowy outdoor setting">
Wyze Cam Pan v3 offers weather-resistant, 360° surveillance for your home.
Wyze Bulb Cam: 2-in-1 Outdoor Security Camera and Smart LED Light
The Wyze Bulb Cam is a unique and affordable solution combining a smart LED light bulb with a 2K HD security camera. It fits into most standard light fixtures, making installation a breeze without extra wiring.
- Video Resolution: 2K HD with color night vision
- Dual Function: Acts as both a security camera and a smart light bulb
- Motion Alerts: Instant notifications to your phone when motion is detected
- Local Storage: Supports local video storage with no subscription required
- Weatherproof: IP65 certified for outdoor use
- Price: Very budget-friendly at under $50
<img src="https://www.wyze.com/cdn/shop/files/Wyze_Bulb_Cam_Shopify-07.jpg?v=1746478547&width=1500" alt="Wyze Bulb Cam installed in outdoor light fixture">
Wyze Bulb Cam blends security and lighting seamlessly for outdoor protection.
Wyze Battery Cam Pro: Wire-Free, Weatherproof, and Powerful
If you prefer a wireless option, the Wyze Battery Cam Pro offers 2.5K HDR video quality with no hub required. Its removable rechargeable battery packs provide flexibility and convenience, while integrated spotlight and siren enhance security.
- Resolution: 2.5K HDR for crystal-clear video
- Wireless: Completely wire-free with rechargeable batteries
- Motion Detection: Radar + PIR sensors for accurate alerts
- Weatherproof: IP65 rating for all-weather use
- Connectivity: Supports both 2.4 GHz and 5 GHz Wi-Fi
This camera is ideal for users who want easy installation and powerful features without the hassle of wires.
Wyze Video Doorbell v2: Affordable 2K Wired Doorbell Camera
Keep an eye on your front door with the Wyze Video Doorbell v2, offering 2K video resolution and local microSD storage. It includes essential features like two-way audio, real-time alerts, and motion-activated voice deterrence to help you manage visitors and deter unwanted guests.
- Video Quality: 2K resolution for clear, detailed footage
- Two-Way Audio: Communicate with visitors from anywhere
- Alerts: Real-time motion and doorbell notifications
- Storage: Local microSD storage, no subscription needed
- Price: Very affordable at under $50
Wyze Cam OG: Budget-Friendly 1080p Camera with Spotlight
For those on a tight budget, the Wyze Cam OG delivers solid 1080p video quality with a built-in spotlight and improved two-way audio. It offers quick live streaming and faster notifications, suitable for both indoor and outdoor use.
- Resolution: 1080p HD video
- Field of View: Wide 120° angle
- Spotlight: Built-in for added security at night
- Audio: Enhanced two-way communication
- Price: Starting at just under $30
<img src="https://www.wyze.com/cdn/shop/files/2_way_talk-03.png?v=1670674480&width=1500" alt="Wyze Cam OG indoor with two-way audio">
Wyze Cam OG offers budget-friendly indoor/outdoor security with two-way audio.
Why Choose Wyze for Cheap Home Security Cameras?
Wyze cameras combine affordability with advanced features like high-resolution video, smart home compatibility, weather resistance, and flexible installation options. Whether you want wired or wireless, indoor or outdoor, or even a video doorbell, Wyze provides reliable security solutions that fit any budget.
Protect your home without compromise — choose Wyze for cheap, smart, and effective home security cameras.
Summary of Featured Cheap Home Security Cameras
Product | Resolution | Key Features | Price Range |
Wyze Cam v4 | 2.5K QHD | Color night vision, spotlight, Wi-Fi 6 | $35.98 - $107.94 |
Wyze Cam Pan v3 | HD | 360° pan/180° tilt, weatherproof | $39.98 - $114.94 |
Wyze Bulb Cam | 2K HD | 2-in-1 light & camera, easy install | $49.98 |
Wyze Battery Cam Pro | 2.5K HDR | Wireless, battery-powered, spotlight | $89.98 - $219.98 |
Wyze Video Doorbell v2 | 2K | Two-way audio, alerts, wired | $44.98 |
Wyze Cam OG | 1080p | Spotlight, two-way audio, budget | $29.98 - $89.94 |
Secure your home affordably with Wyze’s lineup of cheap home security cameras designed to fit your needs and budget.
What are the best cheap home security cameras from Wyze?
Wyze offers a variety of affordable home security cameras, including the Wyze Cam v4, Wyze Cam Pan v3, Wyze Bulb Cam, Wyze Battery Cam Pro, Wyze Video Doorbell v2, and Wyze Cam OG. These cameras provide high-quality video, smart features, and easy installation at budget-friendly prices.Does Wyze offer home security cameras with night vision?
Yes, several Wyze cameras feature enhanced color night vision, including the Wyze Cam v4 and Wyze Bulb Cam. These cameras ensure clear images even in low-light conditions, providing reliable security day and night.Are Wyze security cameras suitable for outdoor use?
Many Wyze cameras are designed for outdoor use, such as the Wyze Cam v4, Wyze Cam Pan v3, Wyze Bulb Cam, and Wyze Battery Cam Pro. These models are IP65 weatherproof, making them durable and reliable in rain, snow, and other harsh conditions.Do Wyze home security cameras require a subscription for video storage?
No, most Wyze cameras support local video storage via microSD cards, allowing you to record and access footage without a subscription. This includes models like the Wyze Cam v4, Wyze Bulb Cam, and Wyze Video Doorbell v2.What is the video resolution of Wyze security cameras?
Wyze cameras offer various video resolutions: Wyze Cam v4 and Wyze Battery Cam Pro provide 2.5K QHD/HDR, Wyze Bulb Cam and Wyze Video Doorbell v2 offer 2K HD, and Wyze Cam OG delivers 1080p HD video.Are Wyze security cameras compatible with smart home systems?
Yes, Wyze cameras are compatible with popular smart home platforms such as Amazon Alexa and Google Assistant, allowing for easy integration and voice control.Which Wyze camera is best for full-room or wide-area coverage?
The Wyze Cam Pan v3 is ideal for full-room or wide-area coverage, featuring 360° pan and 180° tilt capabilities, along with motion tracking for comprehensive surveillance.Is there a wireless, battery-powered security camera option from Wyze?
Yes, the Wyze Battery Cam Pro is a completely wire-free, battery-powered security camera. It features 2.5K HDR video, radar and PIR motion detection, and is weatherproof for outdoor use.What is the most budget-friendly Wyze security camera?
The Wyze Cam OG is the most budget-friendly option, starting at just under $30. It offers 1080p HD video, a built-in spotlight, and enhanced two-way audio for both indoor and outdoor security.Does Wyze offer a video doorbell camera?
Yes, the Wyze Video Doorbell v2 is an affordable wired doorbell camera with 2K video resolution, two-way audio, real-time alerts, and local microSD storage, all for under $50.How easy is it to install Wyze home security cameras?
Wyze cameras are designed for easy installation. For example, the Wyze Bulb Cam fits into standard light fixtures with no extra wiring required, and the Wyze Battery Cam Pro is wire-free for flexible placement.What colors and pack sizes are available for Wyze security cameras?
Wyze cameras come in various colors such as Black, White, Clear, and Grey, and are available in single, double, or triple packs to suit different coverage needs.
