Camera with Rotating Lens to Follow Kids Around the Playroom: Wyze Cam Pan v3 Series
When it comes to monitoring your kids as they play around the room, having a camera that can rotate and follow their movements without blind spots is essential. The
Wyze Cam Pan v3 and its related bundles offer an ideal solution with advanced pan and tilt capabilities, crystal-clear video, and smart features designed to keep an eye on your little ones safely and conveniently.
Wyze Cam Pan v3: The Ultimate Rotating Lens Camera
360° Pan and 180° Tilt for Full Coverage
The Wyze Cam Pan v3 features a
360-degree horizontal pan and
180-degree vertical tilt, ensuring no corner of the playroom is left unseen. With a rotation speed of up to
110° per second, it smoothly follows movement, making it perfect for tracking active kids as they move around.
Crisp 1080p HD Video with Night Vision
Equipped with a
1/2.9" CMOS image sensor and
1920 x 1080 (1080p) resolution, the camera delivers sharp, clear video both day and night. The
4 IR LEDs (850 nm) provide reliable night vision, so you can monitor your children even in low light or at bedtime.
Two-Way Audio with Noise & Echo Cancellation
Stay connected with your kids through the built-in speaker and microphone. The
2-way audio feature allows you to listen and talk back, while noise and echo cancellation ensure clear communication.
Smart Alerts and Easy Connectivity
Receive
push notifications on your phone whenever motion is detected. The camera supports
802.11 b/g/n 2.4GHz Wi-Fi and integrates seamlessly with
Alexa, Google Assistant, and IFTTT for smart home compatibility.
Durable and Stylish Design
The Wyze Cam Pan v3 comes in
matte black or white with a polycarbonate body and glass + plastic lens. Its compact size (124mm x 60mm x 63mm) and lightweight design (11.29 oz) make it easy to place anywhere in your home.
The Wyze Cam Pan v3 is not only perfect for indoor use but also weather resistant with an IP65 rating, making it versatile for outdoor monitoring with the optional outdoor power adapter.
Wyze Cam Pan v3 - Weather resistant and versatile
Wyze Cam Pan v3 + 30-Day Cam Plus Bundle: Enhanced Monitoring Experience
All Features of Wyze Cam Pan v3 Plus Cam Plus Trial
This bundle includes the Wyze Cam Pan v3 with all its pan, tilt, and video features, plus a
30-day trial of Cam Plus. Cam Plus unlocks advanced AI detection, longer event video storage, and person detection, making it easier to focus on your kids’ activities without false alerts.
Complete Setup Included
The bundle comes with a power adapter, micro USB cable, mounting kit, and quick start guide, so you can get your camera up and running quickly.
Color Night Vision
Unlike the standard model, this bundle offers
color night vision, providing more vivid and detailed nighttime footage.
Pan v3 Outdoor Bundle: For Playrooms with Outdoor Access
If your kids often play in areas that extend outdoors, the
Pan v3 Outdoor Bundle is an excellent choice. It includes the Wyze Cam Pan v3 with an
IP67 weather resistance rating, making it even more durable against the elements.
Extended Cable Length for Flexible Placement
With a total cable length of
12.5 feet (3.8 m), this bundle allows you to position the camera in optimal locations both inside and outside the playroom.
High-Capacity Storage
Supports
128GB microSD cards for local storage, enabling you to save hours of HD video footage without worrying about running out of space.
Pan v3 Security Bundle: Double the Coverage for Peace of Mind
For larger play areas or multiple rooms, the
Pan v3 Security Bundle includes two Wyze Cam Pan v3 cameras, doubling your coverage.
Dual Cameras with Full Accessories
Each camera comes with its own power adapter, micro USB cable, mounting kit, and 32GB microSD card, so you can monitor multiple zones simultaneously.
Smart Features and Compatibility
Enjoy all the smart integrations, two-way audio, and push notifications that come with the single Wyze Cam Pan v3, now expanded to cover more ground.
Why Choose Wyze Cam Pan v3 for Monitoring Kids?
The Wyze Cam Pan v3 series stands out for its rotating lens technology that eliminates blind spots, making it ideal for active kids who move quickly around the playroom. Its high-definition video, two-way audio, and smart alerts provide parents with peace of mind and real-time interaction.
Stay connected with two-way audio
Summary of Wyze Cam Pan v3 Key Specifications
Feature | Specification |
Pan Range | 360° horizontal |
Tilt Range | 180° vertical |
Video Resolution | 1920 x 1080 (1080p) |
Night Vision | 4 IR LEDs (850 nm), Color Night Vision (bundle) |
Rotation Speed | Up to 110° per second |
Audio | Built-in speaker & microphone, 2-way audio, noise & echo cancellation |
Connectivity | 802.11 b/g/n 2.4GHz Wi-Fi |
Storage | Supports up to 256GB microSD (ExFAT) |
Weather Resistance | IP65 (standard), IP67 (outdoor bundle) |
Dimensions | 124mm x 60mm x 63mm |
Weight | 11.29 oz (320 g) |
Integrations | Alexa, Google Assistant, IFTTT |
Warranty | 1 Year |
Conclusion
For parents seeking a reliable, smart camera with a rotating lens to follow kids around the playroom without blind spots, the
Wyze Cam Pan v3 and its bundles offer unmatched value. Whether you want a single camera with advanced features, a bundle with extended storage and AI detection, or multiple cameras for broader coverage, Wyze has you covered with high-quality, weather-resistant, and easy-to-use solutions.
Capture every moment, stay connected, and ensure your children’s safety with Wyze Cam Pan v3.
What is the Wyze Cam Pan v3 and how does it help monitor kids in the playroom?
The Wyze Cam Pan v3 is a smart security camera with a rotating lens that offers 360° horizontal pan and 180° vertical tilt. This allows it to follow kids around the playroom, eliminating blind spots and ensuring you can monitor your children’s activities from anywhere.Does the Wyze Cam Pan v3 have night vision for monitoring kids at night?
Yes, the Wyze Cam Pan v3 features 4 IR LEDs for reliable night vision, allowing you to monitor your children even in low light or at bedtime. The Cam Plus bundle also offers color night vision for more vivid nighttime footage.Can I talk to my kids through the Wyze Cam Pan v3?
Absolutely. The Wyze Cam Pan v3 includes two-way audio with noise and echo cancellation, so you can listen and speak to your kids directly through the camera using the Wyze app.What smart home integrations does the Wyze Cam Pan v3 support?
The Wyze Cam Pan v3 is compatible with Alexa, Google Assistant, and IFTTT, making it easy to integrate into your existing smart home setup.Is the Wyze Cam Pan v3 weather resistant for outdoor use?
Yes, the standard Wyze Cam Pan v3 has an IP65 weather resistance rating, and the Pan v3 Outdoor Bundle offers an even higher IP67 rating, making it suitable for both indoor and outdoor monitoring.What video quality does the Wyze Cam Pan v3 provide?
The Wyze Cam Pan v3 delivers crisp 1080p HD video with a 1/2.9" CMOS image sensor, ensuring clear and detailed footage of your kids’ activities.How does the Wyze Cam Pan v3 detect and alert me to movement?
The camera features motion detection and sends push notifications to your phone whenever movement is detected, so you can stay informed about your kids’ activities in real time.What storage options are available with the Wyze Cam Pan v3?
The Wyze Cam Pan v3 supports microSD cards up to 256GB (ExFAT), allowing for extensive local video storage. Bundles may include microSD cards of various capacities, such as 32GB or 128GB.What is included in the Wyze Cam Pan v3 + 30-Day Cam Plus Bundle?
This bundle includes the Wyze Cam Pan v3 camera, a 30-day trial of Cam Plus for advanced AI detection and longer event storage, a power adapter, micro USB cable, mounting kit, and a quick start guide.What are the benefits of the Pan v3 Security Bundle?
The Pan v3 Security Bundle includes two Wyze Cam Pan v3 cameras, each with its own accessories and 32GB microSD card, providing double the coverage for larger playrooms or multiple rooms.How fast can the Wyze Cam Pan v3 rotate to follow movement?
The Wyze Cam Pan v3 can rotate at speeds up to 110° per second, allowing it to smoothly and quickly follow your kids as they move around the playroom.What warranty does the Wyze Cam Pan v3 come with?
The Wyze Cam Pan v3 comes with a 1-year warranty, ensuring peace of mind with your purchase.Is the Wyze Cam Pan v3 easy to set up?
Yes, the Wyze Cam Pan v3 and its bundles come with a quick start guide and all necessary accessories, making setup fast and straightforward.
