Buy Motion Tracking Cameras with Local MicroSD Recording
Buy Cameras with Motion Tracking and Micro SD Card Local Recording
Looking for reliable security cameras that offer advanced motion tracking and local recording via microSD cards? Discover the best Wyze cameras designed to keep your home safe with smart features like AI-powered motion tracking, crisp video quality, and convenient local storage options. Whether you want wired or wireless solutions, indoor or outdoor coverage, or integrated lighting, these cameras have you covered.
Wyze Cam v4 – The Ultimate Wired Security Camera
Experience unmatched home security with the Wyze Cam v4, the clearest Wyze Cam ever made. This wired camera offers:
  • 2.5K QHD Resolution: Capture crystal-clear video with vibrant colors and wide dynamic range (WDR) for detailed images day and night.
  • Enhanced Color Night Vision: See in full color even in low-light conditions, thanks to advanced hardware.
  • Motion-Activated Spotlight & Siren: Deter intruders with a bright spotlight and a loud 99 dB siren.
  • 24/7 Local Recording: Supports continuous recording to a microSD card up to 256GB with no subscription required.
  • AI Auto-Zoom with Smart Focus: Automatically tracks motion to keep the subject in focus while showing the bigger picture.
  • Wi-Fi 6 Support: Enjoy a stronger, more reliable connection.
  • Compatibility: Works seamlessly with Alexa, Google Assistant, and IFTTT for smart home integration.
  • Weather Resistant (IP65): Perfect for indoor or outdoor use.
This camera is easy to mount with a magnetic base and metal plate, and setup is hassle-free with Bluetooth.
"The clearest Wyze Cam ever made with smart motion tracking and local storage."
Wyze Bulb Cam – Security Meets Smart Lighting
Transform any outdoor light fixture into a smart security camera with the Wyze Bulb Cam. This innovative 2-in-1 device combines a security camera and an LED light bulb, offering:
  • 2K HD Video with Color Night Vision: Clear video footage day and night.
  • 160° Wide Field of View: Covers a broad area for enhanced security.
  • Local MicroSD Card Recording: Supports up to 256GB microSD for continuous local storage without monthly fees.
  • Motion Alerts & AI Notifications: Receive instant alerts on your phone when motion is detected.
  • Dimmable 800 Lumen LED Bulb: Customize brightness and set schedules for your outdoor lighting.
  • Easy Installation: Fits most standard light fixtures with simple twist-in setup.
  • Two-Way Audio & Siren: Communicate remotely and scare off unwanted visitors.
  • Smart Home Integration: Compatible with Alexa, Google Assistant, and IFTTT.
This camera is perfect for porch, garage, or backyard security with the added benefit of smart lighting control. Wyze Bulb Cam installed in outdoor light fixture Wyze Bulb Cam: Smart outdoor security and lighting
Wyze Cam Floodlight v2 – Powerful Outdoor Security Lighting
Illuminate and secure your property with the Wyze Cam Floodlight v2, designed for maximum visibility and protection:
  • 2K Video Resolution with Color Night Vision: See every detail clearly, even in the dark.
  • 2800 Lumens Brightness: Two dimmable LED light panels provide powerful illumination.
  • 160° Wide-Angle View: Covers large outdoor areas like driveways and yards.
  • 24/7 Local Recording: Supports microSD cards up to 256GB for continuous local video storage.
  • AI-Powered Light Control & Dusk-to-Dawn Automation: Lights adjust automatically based on ambient light and motion.
  • Two-Way Talk & 105 dB Siren: Communicate and deter intruders effectively.
  • IP65 Weather Resistance: Built to withstand harsh outdoor conditions.
  • Smart Assistant Compatibility: Works with Alexa, Google Assistant, and IFTTT.
This hardwired floodlight camera is ideal for front porches, garages, and other outdoor spaces needing bright security lighting. Wyze Cam Floodlight v2 illuminating driveway at night Wyze Cam Floodlight v2 lighting and securing your driveway
Wyze Battery Cam Pro – Wire-Free Motion Tracking Anywhere
For flexible placement without wiring hassles, the Wyze Battery Cam Pro offers:
  • 2.5K HDR Video Quality: High-resolution video with excellent clarity.
  • Radar + PIR Motion Detection: Advanced motion tracking with radar technology for precise alerts.
  • Integrated Spotlight & Siren: Built-in lighting and a 100 dB siren for security.
  • Removable, Rechargeable Battery Packs: Up to 6 months of battery life per charge.
  • Supports 2.4 & 5 GHz Wi-Fi: Reliable wireless connectivity.
  • Local MicroSD Card Storage: Save recordings locally on microSD cards up to 256GB.
  • IP65 Weatherproof: Durable for outdoor use.
  • Two-Way Audio: Talk to visitors or pets remotely.
Ideal for areas without power outlets or for portable security needs.
Wyze Cam Pan v3 – 360° Pan and Tilt with Motion Tracking
Cover every angle with the Wyze Cam Pan v3, a versatile indoor/outdoor camera featuring:
  • 360° Horizontal and 180° Vertical Rotation: Pan and tilt to track motion across wide areas.
  • 1080p Full HD Video: Clear video with 4 IR LEDs for night vision.
  • Supports MicroSD Cards up to 256GB: Continuous local recording without subscription.
  • IP65 Weather Resistant: Suitable for outdoor use with optional power adapter.
  • Two-Way Audio with Noise & Echo Cancellation: Clear communication.
  • Smart Motion Tracking: Automatically follows moving subjects.
Perfect for monitoring large rooms, garages, or outdoor spaces with dynamic motion tracking. Wyze Cam Pan v3 in snowy outdoor setting Wyze Cam Pan v3 weather resistant with full motion tracking
Why Choose Wyze Cameras with Motion Tracking and Local microSD Recording?
Wyze cameras combine cutting-edge motion tracking technology with the convenience of local microSD card recording, eliminating the need for costly subscriptions. With options ranging from wired to wireless, indoor to outdoor, and integrated lighting solutions, Wyze offers versatile security cameras tailored to your needs. Enjoy crisp video quality, smart alerts, and seamless smart home integration for comprehensive peace of mind.
Summary of Features
Camera ModelResolutionMotion TrackingLocal microSD RecordingPower TypeWeather ResistanceSpecial Features
Wyze Cam v42.5K QHDAI Auto-ZoomUp to 256GBWiredIP65Spotlight, Siren, Wi-Fi 6
Wyze Bulb Cam2K HDMotion AlertsUp to 256GBWired (Light Fixture)IP65Smart LED Bulb, Dimmable, Siren
Wyze Cam Floodlight v22KAI Light ControlUp to 256GBHardwiredIP652800 Lumens Floodlight, Siren
Wyze Battery Cam Pro2.5K HDRRadar + PIRUp to 256GBBattery PoweredIP65Rechargeable Battery, Spotlight, Siren
Wyze Cam Pan v31080p HDPan & Tilt TrackUp to 256GBWiredIP65360° Pan, 180° Tilt, Noise Cancellation
Choose the Wyze camera that fits your security needs and enjoy smart, reliable protection with local recording and advanced motion tracking.
FeatureWyze Cam v4Wyze Bulb CamWyze Cam Floodlight v2Wyze Battery Cam ProWyze Cam Pan v3
Video Resolution2.5K QHD (2560x1440)2K HD2K (2304x1296)2.5K HDR (2560x1440)1080p (1920x1080)
Field of View115.8° (D) / 98.5° (H) / 53.1° (V)160°160° Diagonal134° (DFOV) / 108° (HFOV) / 56° (VFOV)120° FOV
Night VisionEnhanced Color Night Vision (4 IR LEDs + 2 white spotlight LEDs)Color Night VisionColor Night VisionIR LEDs + White LEDs4 IR LEDs (850 nm)
Audio2-way talk, 99dB waterproof speaker, noise & echo cancellation2-way audio2-way audio, built-in speaker & mic2-way audio, built-in speaker & mic2-way audio, noise & echo cancellation
SirenYes, built-inYes, built-in siren + flashing lights105 dB siren100 dB sirenNo
SpotlightMotion-activated spotlight (2 white LEDs)No2 dimmable LED light panels (2800 lumens)Integrated spotlightNo
Power SourceWired (Indoor USB power adapter included; outdoor adapter sold separately)Powered by light fixture (screw-in bulb)Hardwired (110-120V AC)Removable, rechargeable batteryWired (USB power adapter)
Weather ResistanceIP65IP65IP65IP65IP65
Wireless ConnectivityWi-Fi 6 (2.4 GHz & Wi-Fi 6)Wi-Fi (2.4 GHz)Wi-Fi 2.4 GHzWi-Fi 2.4 & 5 GHzWi-Fi 2.4 GHz (5 GHz not supported)
Local StoragemicroSD card up to 512 GB (required)microSD card up to 256 GBmicroSD card up to 256 GBmicroSD card up to 256 GBmicroSD card up to 256 GB
Cloud StorageSubscription availableSubscription availableSubscription availableSubscription availableSubscription available
Motion DetectionYes, with detection zonesYes, with detection zonesYesRadar + PIR motion detectionYes, with detection zones
Additional DetectionSmoke & CO alertsAI notifications & descriptive alertsAI-Powered Light ControlRadar + PIRNo
Dimensions2in x 2in x 2 3/8in (51 x 51 x 60 mm)Bulb size (not specified)9.5in x 7.7in x 7.0in (24.13 x 19.56 x 17.78 cm)2.5 x 1.8 x 3.5 inches124mm x 60mm x 63mm
Weight0.49 lb (222 g)Not specified2.76 lbs (1.25 kg)0.94 lbs11.29 oz (320 g)
Mounting OptionsStand, wall, ceiling, magnetic mountFits most light fixturesWall or ceiling mountWall mount includedScrew mount (1/4"-20)
Smart Assistant IntegrationAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTT
Operating Temperature-4°F to 122°F (-20°C to 50°C)Not specified-4°F to 140°F (-20°C to 60°C)-4°F to 122°F (-20°C to 50°C)-4°F to 122°F (-20°C to 50°C)
Warranty1 YearNot specified1 YearNot specified1 Year
What are the best Wyze cameras with motion tracking and microSD card local recording?Wyze offers several top-rated cameras with advanced motion tracking and local microSD card recording, including the Wyze Cam v4, Wyze Bulb Cam, Wyze Cam Floodlight v2, Wyze Battery Cam Pro, and Wyze Cam Pan v3. Each model supports up to 256GB microSD cards for continuous local storage and features smart motion tracking technology.
How does motion tracking work on Wyze security cameras?Wyze cameras use AI-powered motion tracking to automatically detect and follow movement within their field of view. Features like AI auto-zoom, radar and PIR detection, and pan-and-tilt tracking ensure that moving subjects are kept in focus and recorded for enhanced security.
Do Wyze cameras require a subscription for local video recording?No, Wyze cameras do not require a subscription for local video recording. All featured models support continuous or event-based recording directly to a microSD card (up to 256GB), allowing you to store footage locally without monthly fees.
Which Wyze camera is best for outdoor use with local storage?Several Wyze cameras are ideal for outdoor use with local microSD card storage, including the Wyze Cam v4, Wyze Bulb Cam, Wyze Cam Floodlight v2, Wyze Battery Cam Pro, and Wyze Cam Pan v3. All are IP65 weather resistant and support up to 256GB microSD cards for reliable outdoor security.
Can I use Wyze cameras with Alexa or Google Assistant?Yes, all the featured Wyze cameras are compatible with Alexa, Google Assistant, and IFTTT. This allows you to integrate your security cameras with your smart home system for voice control and automation.
What is the video quality of Wyze cameras with motion tracking?Wyze cameras offer high-definition video quality, ranging from 1080p Full HD (Wyze Cam Pan v3) to 2.5K QHD (Wyze Cam v4 and Wyze Battery Cam Pro) and 2K HD (Wyze Bulb Cam and Wyze Cam Floodlight v2). All models provide clear, detailed footage with color night vision for day and night monitoring.
How much local storage do Wyze cameras support?All featured Wyze cameras support microSD cards up to 256GB, enabling continuous or event-based local video recording without the need for cloud storage or subscriptions.
Are there wireless Wyze cameras with motion tracking and local recording?Yes, the Wyze Battery Cam Pro is a wire-free security camera with advanced radar and PIR motion tracking, local microSD card recording, and up to 6 months of battery life per charge. It is ideal for flexible placement where power outlets are not available.
What special features do Wyze cameras offer for home security?Wyze cameras offer a range of smart security features, including AI-powered motion tracking, color night vision, integrated spotlights and sirens, two-way audio, smart lighting, and compatibility with smart home assistants. These features help deter intruders, provide clear footage, and allow for remote communication.
How easy is it to install Wyze cameras with motion tracking?Wyze cameras are designed for easy installation. Models like the Wyze Cam v4 feature a magnetic base and Bluetooth setup, while the Wyze Bulb Cam simply twists into standard light fixtures. The Wyze Battery Cam Pro is wire-free for flexible placement, and all models come with straightforward setup instructions.
What are the key features of the Wyze Cam v4?Can you tell me more about the local recording capabilities of the Wyze cameras?What is the warranty policy for Wyze cameras?
