Affordable Refurbished Security Cameras with MicroSD Recording
Affordable Refurbished Home Security Cameras with MicroSD Continuous Local Recording
Protecting your home doesn’t have to break the bank. If you’re searching for affordable refurbished home security cameras that offer continuous local recording via microSD cards, you’ve come to the right place. Below, we highlight some of the best Wyze security cameras designed to provide reliable, high-quality surveillance with local storage options—perfect for keeping an eye on your property 24/7 without costly subscriptions.
Wyze Cam v4: The Ultimate Plug-In Security Camera
Crystal-Clear 2.5K QHD Resolution & Enhanced Color Night Vision
Wyze Cam v4 delivers stunning 2.5K Quad HD video quality, ensuring every detail is captured with clarity. Its enhanced color night vision technology allows you to see vibrant colors even in low-light conditions, giving you superhero-like vision after dark.
Continuous 24/7 Local Recording with MicroSD Support
One of the standout features of the Wyze Cam v4 is its ability to record continuously to a microSD card (up to 256GB), enabling you to store days of footage locally without any monthly fees or cloud subscription requirements.
Weather-Resistant & Versatile Placement
Rated IP65 for weather resistance, this camera is perfect for both indoor and outdoor use. Whether mounted on your porch or inside your living room, it withstands rain, snow, and dust.
Smart Features & Easy Setup
With Wi-Fi 6 support, Bluetooth setup, and compatibility with Alexa, Google Assistant, and IFTTT, the Wyze Cam v4 integrates seamlessly into your smart home ecosystem. Its magnetic mount makes installation quick and tool-free.
“Focus on what matters” with AI-powered auto-zoom and motion tracking, ensuring you never miss important activity.
Wyze Cam v4 mounted outdoors Wyze Cam v4 providing reliable outdoor security
Wyze Cam Floodlight v2: Brighten and Secure Your Outdoor Spaces
Powerful 2800 Lumens LED Floodlight with 2K Video
The Wyze Cam Floodlight v2 combines a bright, motion-activated floodlight with a 2K resolution camera featuring color night vision. Illuminate your driveway, backyard, or garage while capturing crisp video footage.
Wide 160° Field of View & AI-Powered Light Control
Cover a broad area with a 160° diagonal view and enjoy smart light automation that adjusts brightness based on ambient light and detected motion.
Continuous Local Recording & MicroSD Support
Like the Wyze Cam v4, this floodlight camera supports continuous 24/7 recording to microSD cards up to 256GB, ensuring you have local access to all your footage without subscription fees.
Weatherproof & Smart Home Integration
With an IP65 rating, it’s built to withstand harsh weather conditions. It also supports Alexa, Google Assistant, and IFTTT for voice control and automation.
The built-in 105dB siren and two-way audio add extra layers of security and communication.
Wyze Cam Floodlight v2 illuminating driveway Wyze Cam Floodlight v2 lighting up a driveway with smart security
Wyze Bulb Cam: Discreet Security with Smart Lighting
2-in-1 Security Camera and LED Light Bulb
The Wyze Bulb Cam fits into any standard E26 light socket, doubling as a smart LED bulb and a 2K HD security camera with color night vision.
Continuous Local Storage with MicroSD Cards
Supports local video storage on microSD cards up to 256GB, allowing continuous recording without monthly fees.
Motion-Activated Lighting & Alerts
Automatically lights up when motion is detected, providing both illumination and instant alerts to your phone.
Easy Installation & Weather Resistance
Ideal for outdoor fixtures, the Bulb Cam is IP65 rated and simple to install, making it a perfect affordable option for porch or garage security.
Control your lighting and monitor your home seamlessly with the Wyze app.
Wyze Bulb Cam installed in outdoor light fixture Wyze Bulb Cam providing smart lighting and security
Why Choose Wyze Refurbished Cameras for Home Security?
  • Affordable Pricing: Get premium features without the premium price tag.
  • Continuous Local Recording: Store your footage securely on microSD cards with no subscription required.
  • Smart Home Compatibility: Works with Alexa, Google Assistant, and IFTTT for easy integration.
  • Weather-Resistant Designs: Suitable for indoor and outdoor use.
  • Easy Setup & Use: Bluetooth and magnetic mounts simplify installation.
Investing in refurbished Wyze cameras is a smart way to enhance your home security affordably while enjoying advanced features like continuous local recording and color night vision.
Summary of Recommended Cameras
Product NameVideo ResolutionNight Vision TypeMicroSD SupportWeather ResistancePrice Range (Refurbished)
Wyze Cam v42.5K QHDEnhanced Color NightUp to 256GBIP65$35.98+
Wyze Cam Floodlight v22KColor Night VisionUp to 256GBIP65$89.98
Wyze Bulb Cam2KColor Night VisionUp to 256GBIP65$49.98
Protect your home affordably with Wyze’s refurbished security cameras that offer continuous local recording via microSD cards. Whether you want a versatile plug-in camera, a powerful floodlight camera, or a discreet bulb cam, Wyze has you covered with smart, reliable, and budget-friendly options.
FeatureWyze Cam v4Wyze Video Doorbell v2Wyze Bulb CamWyze Cam Floodlight v2
Video Resolution2.5K QHD (2560x1440)2K (1920x1080 approx.)2K (2304x1296)2K (2304x1296)
Field of View115.9° (D) x 98.5° (H) x 53.1° (V)Not specified160° diagonal (166° diag. FOV)160° diagonal
Night VisionEnhanced Color Night VisionColor Night Vision (Starlight sensor)Color Night Vision + IR Night VisionColor Night Vision
AudioTwo-way talk, 99dB sirenTwo-way talkTwo-way audio, 95 dB sirenTwo-way talk, 105 dB siren
Local StoragemicroSD up to 512 GBmicroSD slot for 24/7 local recordingmicroSD up to 256 GB (exFAT)microSD up to 256 GB (exFAT)
Cloud StorageSubscription requiredSubscription optional (Cam Plus)AWS Cloud storageSubscription optional (Cam Plus)
Power SourceWired (USB power adapter included)WiredStandard E26 socket (120V AC)Hardwired (110-120V AC)
Weather ResistanceIP65IP65IP65IP65
Smart Assistant CompatibilityAlexa, Google Assistant, IFTTTAlexa, Google AssistantNot specifiedAlexa, Google Assistant, IFTTT
Special FeaturesMotion-activated spotlight, AI auto-zoom, Smoke & CO alerts, Wi-Fi 6 supportMotion-activated voice deterrence, pre-roll recording, chime compatibility2-in-1 camera and smart LED bulb, motion-activated light, up to 800 lumens brightness2800 lumens LED floodlight, AI-powered light control, dusk-to-dawn automation
Dimensions2in x 2in x 2 3/8inNot specifiedNot specified9.5in x 7.7in x 7.0in
Weight0.49 lb (222 g)Not specifiedNot specified2.76 lbs (1.25 kg)
Operating Temperature-4°F to 122°F (-20°C to 50°C)Not specified-4°F to 122°F (-20°C to 50°C)-4°F to 140°F (-20°C to 60°C)
Release Year2024Not specifiedNot specifiedNot specified
Price (approx.)$35.98 (1 pack)$44.98$49.98$89.98
What are the benefits of choosing refurbished Wyze home security cameras?Refurbished Wyze home security cameras offer premium features like continuous local recording, color night vision, and smart home compatibility at a more affordable price. They are thoroughly tested to ensure reliability and come with weather-resistant designs suitable for both indoor and outdoor use.
Do Wyze refurbished security cameras support continuous local recording?Yes, all featured Wyze refurbished security cameras, including the Wyze Cam v4, Wyze Cam Floodlight v2, and Wyze Bulb Cam, support continuous 24/7 local recording to microSD cards up to 256GB. This allows you to store days of footage locally without any monthly subscription fees.
Which Wyze refurbished cameras offer color night vision?The Wyze Cam v4, Wyze Cam Floodlight v2, and Wyze Bulb Cam all feature enhanced color night vision, allowing you to see clear, vibrant footage even in low-light conditions.
Are Wyze refurbished security cameras weather-resistant?Yes, all recommended Wyze refurbished cameras are rated IP65 for weather resistance, making them suitable for both indoor and outdoor installation. They can withstand rain, snow, and dust.
What smart home platforms are Wyze refurbished cameras compatible with?Wyze refurbished cameras work with Alexa, Google Assistant, and IFTTT, allowing for easy integration into your existing smart home ecosystem and enabling voice control and automation.
How easy is it to install Wyze refurbished security cameras?Wyze refurbished cameras are designed for easy installation. Features like Bluetooth setup, magnetic mounts, and compatibility with standard E26 light sockets (for the Bulb Cam) make the process quick and tool-free.
What is the video resolution of Wyze refurbished security cameras?The Wyze Cam v4 offers 2.5K QHD resolution, while the Wyze Cam Floodlight v2 and Wyze Bulb Cam both provide 2K HD video quality, ensuring clear and detailed surveillance footage.
Do Wyze refurbished cameras require a subscription for video storage?No, Wyze refurbished cameras do not require a subscription for video storage. You can use a microSD card (up to 256GB) for continuous local recording and access your footage anytime without monthly fees.
What additional security features do Wyze refurbished cameras offer?Wyze refurbished cameras include advanced features such as AI-powered auto-zoom and motion tracking, motion-activated lighting, instant alerts, two-way audio, and a built-in 105dB siren (on the Floodlight v2) for enhanced security and communication.
What are the price ranges for Wyze refurbished security cameras?Refurbished Wyze Cam v4 starts at $35.98, Wyze Cam Floodlight v2 is priced at $89.98, and Wyze Bulb Cam is available for $49.98, making them budget-friendly options for home security.
Can you tell me more about the Wyze Cam v4's features?How does the Wyze Cam Floodlight v2 compare to the Wyze Cam v4?Do you have any deals, ongoing sales, discounts, or promotions?
