Budget Smart White LED Bulbs with Adjustable Brightness
Budget-Friendly Smart White LED Bulbs with Adjustable Brightness
Looking for an affordable smart white LED bulb that offers adjustable brightness and smart features? Wyze offers a range of smart bulbs designed to fit your budget without compromising on quality or functionality. Whether you want simple white lighting or vibrant color options with full dimming control, these bulbs bring smart lighting to your home with ease and affordability.
Wyze Bulb White: Affordable Smart White LED with Dimmable Control
Wyze Bulb White in Cozy Home Setting Alt: Warm white smart bulb lighting in a cozy home interior Wyze Bulb White is the perfect budget-friendly smart bulb if you want reliable white light with adjustable brightness. It offers:
  • Brightness Range: 30 to 800 lumens, ideal for creating the perfect ambiance from soft night light to bright task lighting.
  • Color Temperature: Adjustable between 2700K (warm white) and 6500K (cool daylight), allowing you to customize lighting for relaxation or focus.
  • Dimmable: Easily dim the light to your preferred level using the Wyze app or voice commands.
  • Compatibility: Works seamlessly with Alexa, Google Assistant, and IFTTT for hands-free control.
  • Connectivity: Supports 2.4 GHz Wi-Fi and Bluetooth for stable and easy setup.
  • Durability: Long life expectancy of 25,000 hours ensures years of use.
  • Suitable for Damp Locations: Safe for use in bathrooms or covered outdoor fixtures.
  • Multiple Pack Options: Available in 2, 4, or 6 packs to fit your home lighting needs.
This bulb is ideal for those who want simple, smart white lighting with dimming capabilities at a very accessible price point.
Wyze Bulb Color: Smart LED Bulb with Adjustable Brightness and Vibrant Colors
Wyze Bulb Color in Living Room Ambiance Alt: Color-changing smart bulb creating vibrant living room lighting If you want to add a splash of color to your smart lighting setup while still having adjustable white light, the Wyze Bulb Color is a fantastic choice:
  • Brightness: Adjustable from 30 lumens up to 1100 lumens, brighter than most color bulbs on the market.
  • Color Options: Choose from 16 million colors to set the perfect mood for any occasion.
  • White Light Temperature Control: Tune from warm to cool white light (1800K to 6500K) for versatile lighting.
  • CRI 90+: High Color Rendering Index means colors appear more vivid and true to life.
  • Smart Features: Create custom presets, automate lighting scenes, and sync lights to music with Music Mode.
  • Voice Control: Compatible with Alexa and Google Assistant for easy voice commands.
  • Vacation Mode & Sleep Routines: Automate lighting to simulate presence or gently wake you up.
  • Pack Sizes: Available in 2, 4, or 6 packs for flexible home coverage.
This bulb is perfect for users who want both adjustable white light and the ability to transform their space with vibrant colors, all while staying budget-conscious.
Wyze Bulb Color BR30: Dimmable Smart Bulb for Recessed Lighting
For recessed lighting fixtures, the Wyze Bulb Color BR30 offers a smart, dimmable LED solution with color control:
  • Brightness: 30 to 950 lumens, providing ample light for recessed fixtures.
  • Color Range: 16 million colors plus tunable white light from 1800K to 6500K.
  • Dimmable: Smooth dimming without flicker for perfect ambiance.
  • Smart Controls: Use the Wyze app or voice assistants to adjust brightness, color, and set schedules.
  • Special Features: Sleep routines, vacation mode, and music sync enhance your smart home experience.
  • Compatibility: Works with Alexa, Google Assistant, and IFTTT.
  • Long Life: 25,000 hours of reliable use.
  • Suitable for Damp Locations: Safe for bathrooms and covered outdoor areas.
  • Note: Not compatible with traditional dimmer switches.
This bulb is ideal for those wanting smart, adjustable brightness lighting in recessed fixtures without breaking the bank.
Why Choose Wyze Smart Bulbs for Your Budget-Friendly Smart Lighting?
Wyze smart bulbs combine affordability with advanced features, making smart lighting accessible to everyone. From simple white bulbs with dimming to full-color bulbs with millions of hues, Wyze offers versatile options that fit any home and budget.
  • Easy Setup & Control: Manage all bulbs from the Wyze app on Android or iOS.
  • Voice Assistant Integration: Hands-free control with Alexa and Google Assistant.
  • Energy Efficient: Low wattage with high lumen output saves on electricity bills.
  • Customizable Scenes: Create lighting moods for work, relaxation, parties, and more.
  • Reliable Connectivity: Uses 2.4 GHz Wi-Fi and Bluetooth for stable performance.
  • Durability: Long-lasting bulbs reduce replacement costs.
Summary of Budget-Friendly Smart White LED Bulbs with Adjustable Brightness
ProductBrightness (Lumens)Color OptionsDimmableVoice ControlPrice Range (Approx.)Pack Sizes Available
Wyze Bulb White30 - 800White (2700K-6500K)YesYes$23.99+2, 4, 6 packs
Wyze Bulb Color30 - 110016 million colors + whiteYesYes$26.26+2, 4, 6 packs
Wyze Bulb Color BR3030 - 95016 million colors + whiteYesYes$27.98+2, 4 packs
Experience smart lighting that fits your budget and lifestyle with Wyze’s range of smart white LED bulbs featuring adjustable brightness and smart home integration.
FeatureWyze Bulb WhiteWyze Bulb ColorWyze Bulb Color BR30
TypeConnected HomeSmart LightingConnected Home
Pack Variants & Price2 Pack ($23.99), 4 Pack ($39.99), 6 Pack ($59.99)2 Pack ($26.26), 4 Pack ($44.44), 6 Pack ($64.98)2 Pack ($27.98), 4 Pack ($49.98)
Brightness (Lumens)800 lm30 lm - 1100 lm30 lm - 950 lm
Color OptionsTunable White (2700K - 6500K)16 million colors + white temp control16 million colors (1800K - 6500K)
Color Temperature Range2700K - 6500KWhite light temperature control1800K - 6500K
Color Rendering Index (CRI)90+90+90+
DimmableYesYesYes
Smart FeaturesSun Match, Sleep Routines, Voice Control, Vacation Mode, GroupingCustom presets, Brilliant notifications, Sleep Routines, Music Mode, Voice Control, Vacation Mode, GroupingCustom lighting scenes, Voice Control, Sleep Routines, Vacation Mode, Music Mode
ConnectivityBluetooth, no hub requiredBluetooth, no hub requiredWi-Fi (802.11 b/g/n 2.4GHz), Bluetooth
Bulb ShapeA19A19BR30
Wattage EquivalentNot specified75W75W
Power ConsumptionNot specifiedNot specified11.5W
Base TypeE26E26E26
Suitable ForIndoorIndoorDamp locations, not for dimmer switches
Life ExpectancyNot specifiedNot specified25,000 hours
DimensionsNot specifiedNot specified3.74in x 3.74in x 5.24in
Voice Assistant IntegrationAlexa, Google AssistantAlexa, Google AssistantAlexa, Google Assistant
What are the main features of Wyze Bulb White smart LED bulbs?Wyze Bulb White offers adjustable brightness from 30 to 800 lumens, tunable white color temperature (2700K to 6500K), dimmable control via the Wyze app or voice commands, compatibility with Alexa, Google Assistant, and IFTTT, and a long lifespan of 25,000 hours. It is also suitable for damp locations and available in 2, 4, or 6 packs.
How do Wyze Bulb Color smart bulbs enhance home lighting?Wyze Bulb Color provides adjustable brightness up to 1100 lumens, 16 million color options, tunable white light (1800K to 6500K), high color rendering (CRI 90+), and smart features like custom presets, music sync, vacation mode, and sleep routines. It works with Alexa and Google Assistant for voice control and is available in multiple pack sizes.
What is the Wyze Bulb Color BR30 and where can it be used?The Wyze Bulb Color BR30 is a smart, dimmable LED bulb designed for recessed lighting fixtures. It offers 16 million colors, tunable white light (1800K to 6500K), smooth dimming, and smart controls via the Wyze app or voice assistants. It is suitable for damp locations like bathrooms and covered outdoor areas, but is not compatible with traditional dimmer switches.
Are Wyze smart bulbs compatible with voice assistants?Yes, all Wyze smart bulbs, including Wyze Bulb White, Wyze Bulb Color, and Wyze Bulb Color BR30, are compatible with Alexa and Google Assistant for hands-free voice control. They also support IFTTT for additional smart home automation.
Can I control Wyze smart bulbs remotely?Yes, you can control Wyze smart bulbs remotely using the Wyze app on Android or iOS devices. The app allows you to adjust brightness, color, set schedules, create scenes, and automate routines from anywhere.
Are Wyze smart bulbs energy efficient?Wyze smart bulbs are designed to be energy efficient, offering high lumen output with low wattage. This helps save on electricity bills while providing bright and customizable lighting.
What pack sizes are available for Wyze smart bulbs?Wyze Bulb White and Wyze Bulb Color are available in 2, 4, or 6 packs, while Wyze Bulb Color BR30 is available in 2 or 4 packs. This allows you to choose the right quantity for your home lighting needs.
Are Wyze smart bulbs suitable for bathrooms or outdoor use?Yes, Wyze Bulb White and Wyze Bulb Color BR30 are suitable for damp locations, making them safe for use in bathrooms or covered outdoor fixtures.
How long do Wyze smart bulbs last?Wyze smart bulbs have a long life expectancy of 25,000 hours, ensuring years of reliable use and reducing the need for frequent replacements.
Do Wyze smart bulbs require a hub for setup?No, Wyze smart bulbs connect directly to your 2.4 GHz Wi-Fi network and Bluetooth, so no additional hub is required for setup or operation.
Can I use Wyze smart bulbs with traditional dimmer switches?Wyze Bulb Color BR30 is not compatible with traditional dimmer switches. Dimming should be controlled through the Wyze app or compatible voice assistants for all Wyze smart bulbs.
What makes Wyze smart bulbs a budget-friendly choice?Wyze smart bulbs combine affordable pricing with advanced smart features like adjustable brightness, color control, voice assistant compatibility, and energy efficiency, making smart lighting accessible to everyone without compromising on quality.
What are the different pack sizes available for the Wyze Bulb White?Can the Wyze Bulb Color be used in damp locations?Is there a warranty for the Wyze smart bulbs?
