Wyze Duo Cam: Budget Doorbell Camera with Advanced Security
Budget Doorbell Camera with High-Level Security Features: Wyze Duo Cam Doorbell
When searching for a budget-friendly doorbell camera that doesn't compromise on security, the Wyze Video Doorbell v2 stands out as an excellent choice. Designed to deliver crystal-clear video, robust security features, and seamless smart home integration, this doorbell camera offers everything you need to keep your home safe without breaking the bank.
Wyze Video Doorbell v2: Affordable Security with Advanced Features
Crisp 2K Video Quality & Wide Field of View
The Wyze Video Doorbell v2 captures your front porch in stunning 2K resolution (2048 x 1536), providing sharp and detailed video footage. Its wide 166.8° diagonal field of view ensures you won’t miss any activity at your doorstep, covering both horizontal and vertical angles effectively.
Smart Motion Detection & Voice Deterrence
Equipped with a CMOS Starlight Sensor and 6 infrared LEDs, this doorbell camera offers excellent night vision capabilities. It sends real-time alerts to your phone when motion is detected, and features motion-activated voice deterrence to warn off unwanted visitors.
Two-Way Audio & Easy Installation
Communicate directly with visitors through the built-in microphone and speaker with noise and echo cancellation. The doorbell supports wired installation with power requirements of 16V-24V AC, making it compatible with most existing doorbell wiring setups.
Local & Cloud Storage Options
Store your video recordings locally on a microSD card (up to 256GB) or opt for cloud storage with the Wyze Security Plan. This flexibility ensures your footage is always accessible and secure.
Weather-Resistant & Smart Home Compatible
With an IP65 rating, the Wyze Video Doorbell v2 is built to withstand harsh weather conditions. It integrates smoothly with Alexa, Google Assistant, and IFTTT, allowing you to control and monitor your doorbell hands-free.
Enhance Your Doorbell Experience with Wyze Universal Wi-Fi Chime
Wireless Convenience & Multiple Tones
Pair your Wyze Video Doorbell with the Wyze Universal Wi-Fi Chime to hear alerts anywhere in your home without complicated wiring. The chime offers 17 different tones, so you can customize your doorbell sound to fit your style.
Easy Setup & Smart Automations
Simply plug in the chime and connect it to your Wyze devices. It can even chime when other Wyze cameras detect people, such as your kitchen camera spotting a visitor, ensuring you never miss a notification.
Compact & Compatible
Measuring just 81 x 53 x 38 mm, this sleek black chime fits discreetly in any room. It works with all Wyze Cams and doorbells, making it a versatile accessory for your smart home security system.
The Front Porch Security Bundle: Complete Smart Home Protection
For those looking to maximize security and convenience, the Front Porch Security Bundle combines the Wyze Video Doorbell with Wyze Lock and Wyze Chime, offering a comprehensive solution for your entryway.
Key Features of the Bundle
  • 1080p HD Video Doorbell with two-way audio and motion alerts
  • Remote Lock/Unlock capabilities with Wyze Lock, view lock history anytime
  • Multiple Alert Sounds and smart automations with Wyze Chime
  • Works seamlessly with Alexa and Google Assistant for voice control
Advanced Data Security
The bundle employs end-to-end encryption, HTTPS secure transfer, and AES 128-bit encryption to protect your data and privacy.
All-Inclusive Kit
Includes everything needed for installation: doorbell, chime, lock, mounting hardware, and quick start guides, making setup straightforward and hassle-free.
Why Choose Wyze for Your Doorbell Camera Needs?
Wyze offers a perfect balance of affordability, advanced technology, and user-friendly design. Whether you want a standalone doorbell camera or a full smart home security system, Wyze products provide:
  • High-resolution video with night vision
  • Reliable motion detection and alerts
  • Easy installation and setup
  • Compatibility with popular smart home platforms
  • Durable, weather-resistant construction
Wyze Cam Floodlight Pro in Action Bright and smart security lighting enhances home safety
Additional Wyze Security Cameras to Complement Your Doorbell
While the Wyze Video Doorbell v2 is ideal for your front door, consider expanding your home security with these Wyze cameras:
  • 2.5K QHD video with 180° wide-angle lens
  • 3,000 lumens of adjustable LED lighting
  • AI-powered motion detection for people and vehicles
  • IP65 weather resistance for outdoor use
Wyze Cam Pan v3
  • 360° horizontal and 180° vertical coverage
  • 1080p HD video with 8x digital zoom
  • Two-way audio and night vision
  • Weather-resistant design for indoor/outdoor use
Wyze Bulb Cam
  • 2-in-1 outdoor security camera and smart LED bulb
  • 2K HD video with color night vision
  • Motion-activated lighting and alerts
  • Fits standard E26 sockets for easy installation
These cameras integrate seamlessly with your Wyze Video Doorbell and chime, creating a robust and connected home security network.
Protect your home affordably with Wyze’s budget-friendly doorbell camera and smart accessories. Experience peace of mind with high-quality video, smart alerts, and easy installation.
FeatureWyze Video Doorbell v2Wyze Universal Wi-Fi ChimeThe Front Porch Security Bundle
TypeWired Video DoorbellWi-Fi Chime AccessoryBundle: Video Doorbell + Chime + Wyze Lock
Video Resolution2K (2048 x 1536)N/A1080p HD (Doorbell)
Field of View135° Horizontal x 103° VerticalN/A120° Vertical x 88° Horizontal (Doorbell)
Local StoragemicroSD card slot, up to 256GBN/AIncluded (Doorbell supports microSD)
Cloud StorageOptional with Cam Plus subscriptionN/AOptional (via Wyze Security Plan)
Two-Way AudioYesN/AYes (Doorbell)
Motion-Activated Voice DeterrenceYes (requires Cam Plus or Cam Protect subscription)N/AYes (Doorbell)
Pre-roll Motion Recording3-6 secondsN/AYes (Doorbell)
Weather ResistanceIP65Indoor useIP65 (Doorbell)
PowerWired (16V-24V AC, ≥10VA)Plug-in (Standard US Power Outlet)Wired (Doorbell), Standard US Power Outlet (Chime)
Chime CompatibilityWorks with existing mechanical chime (includes chime controller)Works with all Wyze cameras and doorbells via Wi-FiIncludes Wyze Chime compatible with Doorbell
InstallationScrew mountingPlug-in, 3M adhesive or screw mountingIncludes installation kits for all devices
Smart Home IntegrationAlexa, Google HomeAlexa, Google AssistantAlexa, Google Assistant
Additional FeaturesNight Color Vision, AI detections with Cam Plus, Custom Detection Zones, Quick ResponsesSmart Automations, chimes on person detectionRemote lock/unlock, lock history, motion events
Price$44.98$19.98From $123.99 (varies by variant)
Included ItemsDoorbell + Chime ControllerWi-Fi ChimeWyze Lock, Wyze Lock Gateway, Wyze Video Doorbell, Wyze Chime, accessories
Warranty1 yearNot specifiedNot specified
What is the Wyze Video Doorbell v2 and what features does it offer?The Wyze Video Doorbell v2 is a budget-friendly smart doorbell camera that provides 2K video resolution, a wide 166.8° field of view, smart motion detection, night vision, two-way audio, and seamless integration with Alexa, Google Assistant, and IFTTT. It also offers both local and cloud storage options and is weather-resistant with an IP65 rating.
How does the Wyze Video Doorbell v2 enhance home security?The Wyze Video Doorbell v2 enhances home security with features like real-time motion alerts, motion-activated voice deterrence, night vision with a CMOS Starlight Sensor, and two-way audio for direct communication with visitors. It also supports secure data transfer with end-to-end encryption and AES 128-bit encryption.
Is the Wyze Video Doorbell v2 easy to install?Yes, the Wyze Video Doorbell v2 is designed for easy installation. It supports wired installation with 16V-24V AC power, making it compatible with most existing doorbell wiring setups. The package includes all necessary mounting hardware and a quick start guide.
What storage options are available for the Wyze Video Doorbell v2?The Wyze Video Doorbell v2 offers flexible storage options. You can store video recordings locally on a microSD card (up to 256GB) or choose cloud storage with the Wyze Security Plan, ensuring your footage is always accessible and secure.
Is the Wyze Video Doorbell v2 weather-resistant?Yes, the Wyze Video Doorbell v2 is IP65 weather-resistant, making it suitable for use in harsh outdoor conditions and ensuring reliable performance year-round.
Can the Wyze Video Doorbell v2 be integrated with smart home systems?Absolutely. The Wyze Video Doorbell v2 integrates seamlessly with popular smart home platforms, including Alexa, Google Assistant, and IFTTT, allowing for hands-free control and automation.
What is the Wyze Universal Wi-Fi Chime and how does it work?The Wyze Universal Wi-Fi Chime is a wireless accessory that pairs with your Wyze Video Doorbell or Wyze Cams to provide customizable alert tones throughout your home. It offers 17 different tones, easy plug-in setup, and can chime when any connected Wyze camera detects people.
What is included in the Wyze Front Porch Security Bundle?The Wyze Front Porch Security Bundle includes a 1080p HD Video Doorbell with two-way audio and motion alerts, a Wyze Lock for remote lock/unlock and viewing lock history, a Wyze Chime with multiple alert sounds, and all necessary installation hardware and guides. It also features advanced data security with end-to-end encryption.
What additional Wyze security cameras can complement the Wyze Video Doorbell v2?Wyze offers several cameras to complement the Video Doorbell v2, including the Wyze Cam Floodlight Pro (2.5K QHD video, 180° lens, 3,000 lumens lighting), Wyze Cam Pan v3 (360° horizontal, 180° vertical coverage, 1080p HD), and Wyze Bulb Cam (2K HD video, color night vision, motion-activated lighting). All integrate seamlessly with Wyze doorbells and chimes.
Why should I choose Wyze for my doorbell camera and home security needs?Wyze offers a perfect balance of affordability, advanced technology, and user-friendly design. Their products provide high-resolution video, reliable motion detection, easy installation, compatibility with major smart home platforms, and durable, weather-resistant construction, making them an excellent choice for comprehensive home security.
Can you tell me more about the features of the Wyze Video Doorbell v2?How does the Wyze Universal Wi-Fi Chime work with the doorbell?Do you have any ongoing sales or discounts for the Wyze Video Doorbell v2?
