Bluetooth LED Curtain Lights: 16 Million Colors & App Control
Bluetooth Controlled LED Curtain Lights with 16 Million Colors
Transform your living space with vibrant, customizable lighting that you can control right from your smartphone. If you're searching for Bluetooth controlled LED curtain lights boasting an impressive palette of 16 million colors, the Wyze Light Strip is the perfect choice to bring your vision to life. This page highlights the best smart lighting solutions that offer rich color options, easy app control, and seamless integration into your smart home ecosystem.
Wyze Light Strip: Brilliant LED Accent Lighting with 16 Million Colors
Endless Color Possibilities
The Wyze Light Strip offers a stunning 16 million colors, allowing you to customize every corner of your home. Whether you want to backlight your favorite screen, frame your headboard, or brighten up dark corners, this LED strip delivers vibrant, dynamic lighting that fits your mood and style.
Bluetooth and App Control
Control your Wyze Light Strip effortlessly via Bluetooth or Wi-Fi through the Wyze app. Change colors, adjust brightness, and create lighting scenes with just a few taps. The Bluetooth connectivity ensures quick setup and responsive control without complicated wiring.
Music Mode for Dynamic Ambiance
Bring your parties and daily routines to life with Music Mode. The built-in microphone syncs the lights to the beat of your favorite songs, turning any room into a lively dance floor or a relaxing vibe zone.
Natural Light Sync with Sun Match
Wyze Light Strip automatically adjusts its color temperature to match the natural light cycle of the day. This feature helps you wake up gently, stay focused during work, and wind down peacefully at night by mimicking natural sunlight patterns.
Voice Control and Automation
Compatible with Alexa and Google Assistant, you can control your lights hands-free. Set timers, schedules, and automations to have your lights turn on or off automatically, or activate Vacation Mode to make it look like someone’s home when you’re away. Wyze Light Strip in Living Room Alt text: Wyze Light Strip illuminating a cozy living room with colorful LED lighting
Enhance Your Smart Home Lighting Experience
While the Wyze Light Strip is ideal for colorful accent lighting, pairing it with other Wyze smart home devices can elevate your home automation experience.
Wyze Plug and Wyze Plug Outdoor: Smart Power Control
Use the Wyze Plug or Wyze Plug Outdoor to power your LED curtain lights and control them remotely. These smart plugs support scheduling, voice commands, and energy monitoring, making it easy to automate your lighting setup indoors or outdoors.
  • Wyze Plug is perfect for indoor use with 2.4GHz Wi-Fi connectivity and compatibility with Alexa, Google Assistant, and IFTTT.
  • Wyze Plug Outdoor offers weather-resistant design (IP64 rating) for reliable outdoor use, Bluetooth and Wi-Fi connectivity, and energy monitoring features.
Wyze Bulb White: Complementary Smart Lighting
For areas where you prefer warm or cool white lighting instead of colorful LEDs, the Wyze Bulb White offers dimmable brightness with easy app and voice control. It’s perfect for bedrooms, kitchens, or any space needing adjustable white light.
Why Choose Wyze for Your Bluetooth Controlled LED Curtain Lights?
Wyze products combine affordability, smart technology, and user-friendly design to bring you the best in connected home lighting.
  • Vibrant 16 million colors with smooth transitions and dynamic effects.
  • Bluetooth and Wi-Fi control for flexible and fast setup.
  • Seamless integration with voice assistants and smart home ecosystems.
  • Customizable routines and automations to fit your lifestyle.
  • Reliable and weather-resistant options for both indoor and outdoor use.
Wyze Plug Indoor Lifestyle Alt text: Smart home lifestyle showing Wyze Plug controlling home devices
Get Creative with Your Lighting Setup
Whether you want to create a cozy ambiance, a festive atmosphere, or a vibrant party scene, Wyze Light Strip’s Bluetooth controlled LED curtain lights with 16 million colors offer endless possibilities. Pair with Wyze smart plugs and bulbs to build a fully automated, voice-controlled lighting environment that adapts to your needs. Wyze Cam Floodlight Pro Outdoor Alt text: Outdoor home security with bright LED floodlight and smart camera
Product Summary
Product NameKey FeaturesUse Case
Wyze Light Strip16 million colors, Bluetooth & Wi-Fi control, Music Mode, Sun Match, Voice ControlLED curtain lights, accent lighting
Wyze PlugSmart plug, app & voice control, scheduling, energy monitoringIndoor smart power control
Wyze Plug OutdoorWeather-resistant, Bluetooth & Wi-Fi, energy monitoringOutdoor smart power control
Wyze Bulb WhiteDimmable white light, app & voice controlComplementary white lighting
Conclusion
For Bluetooth controlled LED curtain lights with 16 million colors, the Wyze Light Strip stands out as a versatile, easy-to-use, and feature-rich solution. Enhance your smart home lighting with Wyze plugs and bulbs to create a fully integrated, customizable lighting experience that fits any mood or occasion.
FeatureWyze Light StripWyze PlugWyze Plug OutdoorWyze Bulb WhiteWyze Switch
TypeConnected Home LightingConnected Home PowerConnected Home Power (Outdoor)Connected Home LightingConnected Home Power
Variants / Sizes16.4 ft, 32.8 ft2 Pack, 4 Pack1 Pack, 2 Pack2 Pack, 4 Pack, 6 Pack1 Pack, 3 Pack
Price Range (USD)$19.99 - $35.99$24.98 - $39.98$15.99 - $34.98$23.99 - $59.99$14.99 - $41.98
ControlWyze app, Voice (Alexa, Google)Wyze app, Voice (Alexa, Google)Wyze app, Voice (Alexa)Wyze app, Voice (Alexa, Google)Wyze app, Voice (Alexa, Google)
ConnectivityWi-Fi (2.4 GHz), BluetoothWi-Fi (2.4 GHz)Wi-Fi (2.4 GHz)Wi-Fi (2.4 GHz), BluetoothWi-Fi (2.4 GHz)
Power SourceCorded ElectricPlug-inPlug-inStandard bulb socket (E26)In-wall switch
Weather ResistanceNoNoIP64 Weather ResistantSuitable for damp locationsNo
Features16 million colors, cuttable, adhesive mounting, music syncRemote on/off, scheduling, vacation mode, no hub requiredOutdoor rated, 2 outlets with independent control, energy monitoring, overload protectionDimmable white light, 2700K-6500K, 30-800 lumens, 25,000 hrs lifeMulti-tap control, automations, vacation mode, power loss recovery
UsageIndoor onlyIndoorOutdoorIndoor, damp locationsIndoor
Dimensions / Weight10.8 oz - 1.01 lbsNot specifiedNot specified4.6 in x 2.4 in x 2.4 in, 0.31 lbsNot specified
Life Expectancy25,000 hoursNot specifiedNot specified25,000 hoursNot specified
Scheduling & AutomationYesYesYesYesYes
Voice Assistant SupportAlexa, Google AssistantAlexa, Google AssistantAlexaAlexa, Google AssistantAlexa, Google Assistant
What are Bluetooth controlled LED curtain lights with 16 million colors?Bluetooth controlled LED curtain lights with 16 million colors, such as the Wyze Light Strip, are smart lighting solutions that allow you to customize your lighting experience with a vast palette of colors. You can control these lights directly from your smartphone via Bluetooth or Wi-Fi, making it easy to change colors, adjust brightness, and set scenes to match your mood or occasion.
How do I control the Wyze Light Strip?You can control the Wyze Light Strip using the Wyze app on your smartphone via Bluetooth or Wi-Fi. The app allows you to change colors, adjust brightness, create lighting scenes, and set schedules. The Wyze Light Strip is also compatible with voice assistants like Alexa and Google Assistant for hands-free control.
What features does the Wyze Light Strip offer?The Wyze Light Strip offers 16 million color options, Bluetooth and Wi-Fi control, Music Mode for syncing lights to music, Sun Match for natural light syncing, voice control compatibility with Alexa and Google Assistant, and customizable routines and automations.
What is Music Mode on the Wyze Light Strip?Music Mode is a feature on the Wyze Light Strip that uses a built-in microphone to sync the LED lights to the beat of your favorite songs. This creates a dynamic and lively atmosphere, perfect for parties or relaxing at home.
How does Sun Match work on the Wyze Light Strip?Sun Match automatically adjusts the color temperature of your Wyze Light Strip to mimic the natural light cycle throughout the day. This helps you wake up gently, stay focused during work, and wind down peacefully at night by aligning your lighting with natural sunlight patterns.
Can I integrate Wyze Light Strip with other smart home devices?Yes, the Wyze Light Strip seamlessly integrates with other Wyze smart home devices, such as Wyze Plug, Wyze Plug Outdoor, and Wyze Bulb White. This allows you to automate your lighting setup, control devices remotely, and create a fully connected smart home environment.
What are the benefits of using Wyze Plug and Wyze Plug Outdoor with LED curtain lights?Wyze Plug and Wyze Plug Outdoor allow you to power your LED curtain lights and control them remotely. They support scheduling, voice commands, and energy monitoring. Wyze Plug is ideal for indoor use, while Wyze Plug Outdoor is weather-resistant and suitable for outdoor environments.
Is the Wyze Light Strip compatible with voice assistants?Yes, the Wyze Light Strip is compatible with popular voice assistants like Amazon Alexa and Google Assistant. This enables you to control your lights hands-free using simple voice commands.
Can I use Wyze Bulb White with my smart lighting setup?Absolutely. Wyze Bulb White is a smart bulb that offers dimmable white light with easy app and voice control. It’s perfect for areas where you prefer adjustable white lighting instead of colorful LEDs, such as bedrooms or kitchens.
Why should I choose Wyze for Bluetooth controlled LED curtain lights?Wyze offers affordable, feature-rich smart lighting products with 16 million colors, Bluetooth and Wi-Fi control, seamless integration with voice assistants, customizable routines, and reliable options for both indoor and outdoor use. Wyze products are designed to be user-friendly and enhance your smart home experience.
Can you tell me more about the Music Mode feature for the Wyze Light Strip?How does the Sun Match feature work with the Wyze Light Strip?Do you have any deals, ongoing sales, discounts, or promotions for the Wyze Light Strip?
