App Controlled LED Curtain Lights with Over 170 Preset Patterns
Transform your living space with vibrant, customizable LED lighting that you can control right from your smartphone. Whether you're looking to create a cozy ambiance, energize your party, or add a splash of color to your home decor, these smart lighting solutions offer over 170 preset patterns and millions of colors to suit every mood and occasion.
Explore the top Wyze smart lighting products designed to bring your LED curtain lights to life with seamless app control and dazzling effects.
Wyze Bulb Color: The Ultimate Smart Color Bulb
Brilliant 16 Million Colors & Custom Presets
Wyze Bulb Color stands out as one of the brightest and most versatile smart bulbs on the market. With access to 16 million colors, you can easily set the perfect tone for any event—from festive Mardi Gras vibes to relaxing evenings at home. The Wyze app lets you create and save custom presets, enabling instant scene changes with a single tap.
Wide Lumen Range & Dimmable Control
Unlike typical bulbs capped at 800 lumens, Wyze Bulb Color offers a wide brightness range from 30 lumens to 1100 lumens, allowing you to dim or brighten your space exactly as you want. Whether you need subtle mood lighting or a bright spotlight, this bulb adapts effortlessly.
Advanced Features for Smart Living
- White Light Temperature Control: Adjust from cool to warm white light to match your activity or time of day.
- Sleep Routines: Wake up or fall asleep gently with lighting that gradually brightens or dims.
- Music Mode: Sync your lights to the beat of your favorite songs when grouped with Wyze Light Strip or Light Strip Pro.
- Voice Control: Compatible with Alexa and Google Assistant for hands-free operation.
- Vacation Mode: Simulate occupancy when you're away for added security.
Wyze Bulb Color is perfect for creating dynamic LED curtain light effects with over 170 preset patterns available through the app, making your home lighting truly personalized.
Experience vibrant color-changing smart lighting in your living room.
Wyze Light Strip: Flexible LED Accent Lighting
Endless Color Possibilities & Easy Installation
The Wyze Light Strip offers 16 million colors to brighten up any corner of your home. Its flexible design allows you to peel, stick, and plug it in anywhere—from backlighting your TV to framing your bedroom headboard or illuminating dark shelves.
Music Mode & Sun Match
- Music Mode: Built-in microphone syncs the light strip to your music, turning any room into a party zone.
- Sun Match: Automatically adjusts color temperature to mimic natural daylight cycles, helping you wake, work, and relax naturally.
Smart Features & App Control
Control brightness, color, and patterns directly from the Wyze app. Set timers, automations, and vacation mode to keep your home lively and secure even when you're away.
With over 170 preset patterns accessible via the app, Wyze Light Strip is ideal for creating stunning LED curtain light displays that respond to your lifestyle.
Add brilliant LED accent lighting to your home with Wyze Light Strip.
Wyze Light Strip Pro: Multi-Color Segment Control for Custom Vibes
Advanced Lighting Effects & Segment Control
Take your LED curtain lights to the next level with Wyze Light Strip Pro. This smart strip features 16 customizable color segments, allowing you to create complex, multi-color patterns and effects that flow seamlessly across the strip.
Features Tailored for Creative Lighting
- 16 Million Colors RGB + Tunable White: Mix and match colors with precision.
- Music Mode: Lights dance to your favorite beats.
- Trimmable Design: Cut the strip to fit any space perfectly.
- Voice Control & Automations: Use Alexa or Google Assistant and set timers or routines for effortless control.
Durable & Long-Lasting
Designed for indoor use with a life expectancy of 25,000 hours, the Light Strip Pro is perfect for vibrant, long-lasting LED curtain light installations.
Perfect for users who want over 170 preset patterns and the ability to customize each segment of their LED curtain lights for a truly unique lighting experience.
Create custom multi-color lighting effects with Wyze Light Strip Pro.
Why Choose Wyze for Your LED Curtain Lights?
Wyze smart lighting products combine cutting-edge technology with user-friendly app control, offering:
- Extensive Preset Patterns: Over 170 dynamic lighting scenes to match any mood or event.
- Seamless App Integration: Control all your lights from one intuitive app.
- Voice Assistant Compatibility: Hands-free control with Alexa and Google Assistant.
- Music Sync: Lights that move to your favorite tunes for parties or relaxation.
- Customizable Brightness & Colors: From subtle glows to vibrant displays, tailor your lighting perfectly.
Whether you want to brighten your home, create a festive atmosphere, or add smart automation, Wyze’s app-controlled LED curtain lights deliver unmatched versatility and style.
Summary of Featured Products
Product Name | Key Features | Ideal For |
Wyze Bulb Color | 16 million colors, dimmable, music sync | General smart lighting & accents |
Wyze Light Strip | Flexible, 16 million colors, music mode | LED curtain lights & accent walls |
Wyze Light Strip Pro | Multi-segment color control, trimmable, music | Advanced custom LED displays |
Enhance your home lighting with Wyze’s app-controlled LED curtain lights and enjoy over 170 preset patterns that bring your space to life with color, rhythm, and smart convenience.
What are app-controlled LED curtain lights?
App-controlled LED curtain lights are smart lighting solutions that allow you to customize and control your lighting directly from your smartphone. With Wyze products, you can access over 170 preset patterns, millions of colors, and various effects to create the perfect ambiance for any occasion.How many preset patterns do Wyze LED curtain lights offer?
Wyze LED curtain lights offer over 170 preset patterns, giving you a wide variety of dynamic lighting scenes to match any mood, event, or decor style.Which Wyze products are best for LED curtain lights?
The best Wyze products for LED curtain lights include the Wyze Bulb Color, Wyze Light Strip, and Wyze Light Strip Pro. Each offers unique features such as millions of color options, music sync, segment control, and easy app integration for personalized lighting effects.Can I control Wyze LED curtain lights with my smartphone?
Yes, all Wyze smart lighting products can be controlled through the Wyze app on your smartphone. The app allows you to adjust colors, brightness, patterns, set timers, and create custom scenes with ease.Are Wyze LED curtain lights compatible with voice assistants?
Yes, Wyze LED curtain lights are compatible with popular voice assistants like Amazon Alexa and Google Assistant, enabling hands-free control of your lighting.What is the difference between Wyze Light Strip and Wyze Light Strip Pro?
Wyze Light Strip offers flexible, easy-to-install accent lighting with 16 million colors and music sync. Wyze Light Strip Pro adds advanced features like 16 customizable color segments, multi-color effects, and a trimmable design for more creative and complex lighting displays.Can Wyze LED curtain lights sync with music?
Yes, Wyze LED curtain lights feature Music Mode, which allows the lights to sync and dance to the beat of your favorite songs, creating a lively atmosphere for parties or relaxation.How customizable are Wyze LED curtain lights?
Wyze LED curtain lights are highly customizable. You can choose from millions of colors, adjust brightness, set white light temperature, create and save custom presets, and even control individual segments with the Light Strip Pro.Do Wyze LED curtain lights have automation features?
Yes, Wyze smart lighting products support automation features such as timers, sleep routines, vacation mode, and sun match, allowing your lights to adjust automatically based on your schedule or natural daylight cycles.Are Wyze LED curtain lights easy to install?
Yes, Wyze Light Strips are designed for easy installation. Simply peel, stick, and plug them in to add vibrant accent lighting anywhere in your home. The Light Strip Pro is also trimmable for a perfect fit.How long do Wyze LED curtain lights last?
Wyze Light Strip Pro, for example, is designed for indoor use and has a life expectancy of up to 25,000 hours, ensuring long-lasting and reliable performance.Can I use Wyze LED curtain lights for home security?
Yes, Wyze smart lighting products include features like vacation mode, which simulates occupancy by turning lights on and off while you're away, helping to enhance your home security.
