Best microSD Cards for Wyze Cam v3 Motion Event Storage
Best microSD Storage for Capturing Motion Events on Wyze Cam v3 and Wyze MicroSD Card
When it comes to capturing motion events on your Wyze Cam v3, choosing the right microSD card is essential for reliable, continuous local recording. Wyze offers a dedicated Wyze MicroSD Card designed specifically to unlock powerful features such as continuous recording, time lapses, and easy playback without monthly fees. This page highlights the best microSD storage options and compatible Wyze cameras optimized for motion event capture.
Wyze MicroSD Card: Perfect Storage for Wyze Cams
Reliable Local Storage for Continuous Recording
The Wyze MicroSD Card is engineered to provide seamless local storage for your Wyze cameras, including the Wyze Cam v3. With sizes ranging from 32GB to 256GB, it supports continuous 24/7 recording and motion-triggered event capture without any subscription fees.
  • Available Sizes: 32GB, 128GB, 256GB
  • Price Range: $8.99 - $29.99
  • Supports: Continuous local recording, time lapse videos, and event playback
  • Compatibility: Works flawlessly with Wyze Cam v3, Wyze Cam v4, and other Wyze cameras with microSD slots
Key Benefits
  • No Monthly Fees: Store your footage locally without recurring costs.
  • Easy Playback: Access recorded videos directly through the Wyze app or by removing the card.
  • Motion Event Highlighting: The timeline in the Wyze app highlights motion events for quick review.
  • Durability: Designed to handle the demands of continuous video recording.
Unlock the full potential of your Wyze Cam v3 by pairing it with the Wyze MicroSD Card for reliable, hassle-free storage.
Wyze Cam v3 and MicroSD Card: Ideal for Motion Event Capture
Wyze Cam v3 Overview
The Wyze Cam v3 is a versatile indoor/outdoor security camera that excels at capturing motion events with high-quality video and smart features.
  • Video Resolution: 1080p Full HD with color night vision
  • Weather Resistance: IP65 rating for outdoor durability
  • Field of View: 120° wide-angle lens
  • Night Vision: 4 IR LEDs for clear night footage
  • Storage: Supports microSD cards up to 512GB (Wyze MicroSD Card recommended)
  • Audio: Two-way audio with noise and echo cancellation
  • Motion Detection: Customizable zones and push notifications
Why Wyze Cam v3 + Wyze MicroSD Card is a Winning Combo
Pairing the Wyze Cam v3 with the Wyze MicroSD Card ensures you never miss a motion event. The camera records continuously or on motion triggers directly to the microSD card, allowing you to review footage anytime without relying on cloud subscriptions.
"Capture every motion event with crystal-clear 1080p video and store it locally for free."
Wyze Cam v3 in snowy outdoor setting Wyze Cam v3: Weather-resistant and ready for outdoor motion capture
Wyze Cam v4 + FREE 32GB MicroSD Card: Enhanced Security and Storage
Advanced Features of Wyze Cam v4
The Wyze Cam v4 is the clearest Wyze camera yet, offering 2.5K QHD resolution and enhanced color night vision, making it perfect for detailed motion event capture.
  • Resolution: 2.5K Quad HD (2560x1440)
  • Color Night Vision: Enhanced hardware for vivid low-light footage
  • Wide Dynamic Range (WDR): Better image quality in varied lighting
  • Wi-Fi 6 Support: Stronger, more reliable connection
  • Motion & Sound Detection: Alerts on motion or sound events
  • Local Storage: Includes a FREE 32GB Wyze MicroSD Card for local recording
  • Smart Home Integration: Works with Alexa and Google Assistant
Why Choose Wyze Cam v4 for Motion Events?
With its superior resolution and color night vision, the Wyze Cam v4 captures motion events with exceptional clarity, day or night. The included 32GB microSD card ensures you can start recording locally right out of the box.
Wyze Cam Pan v3: 360° Coverage with microSD Storage Support
Features Tailored for Motion Event Capture
The Wyze Cam Pan v3 offers a 360° horizontal and 180° vertical field of view with pan and tilt capabilities, making it ideal for monitoring large areas and capturing motion events from every angle.
  • Field of View: 120° FOV with 360° pan and 180° tilt
  • Weather Resistance: IP65 rated for outdoor use (requires outdoor power adapter)
  • Storage: Supports up to 256GB microSD cards in ExFAT format
  • Motion Alerts: Push notifications on detected motion
Perfect for Dynamic Motion Monitoring
The Pan v3’s ability to rotate and tilt combined with local microSD storage means you can capture and review motion events from multiple angles without missing a beat.
"Experience full-area coverage and reliable local storage for all your motion events."
Wyze Cam Pan v3 outdoor lifestyle Wyze Cam Pan v3: 360° pan and tilt for comprehensive motion capture
Wyze Cam v3 Security System Bundle: Complete Solution with microSD Cards
Build Your Own Security System
The Wyze Cam v3 Security System Bundle combines multiple Wyze Cam v3 units with Wyze MicroSD Cards, providing a comprehensive solution for motion event capture across your home or business.
  • Includes: Multiple Wyze Cam v3 cameras + 32GB or 128GB Wyze MicroSD Cards
  • Features: 1080p color night vision, IP65 weather resistance, person detection, motion zones
  • Storage: Supports continuous 24/7 recording on included microSD cards
  • Mounting: Magnetic, screw, and adjustable table stand options
  • Use Case: Indoor and outdoor security with smart home integration
Why Choose the Bundle?
This bundle is perfect for users who want to cover multiple areas with reliable cameras and local storage, ensuring all motion events are captured and stored without monthly fees.
Conclusion: Best microSD Storage for Wyze Motion Event Capture
For capturing motion events on your Wyze Cam v3 or other Wyze cameras, the Wyze MicroSD Card is the best choice. It offers reliable, continuous local recording with no subscription fees and seamless integration with Wyze devices. Pair it with the Wyze Cam v3, Wyze Cam v4, or Wyze Cam Pan v3 to maximize your home security and never miss a moment.
Choose Wyze MicroSD Cards for hassle-free, high-performance local storage tailored for Wyze cameras.
Two-way audio with Wyze Cam Stay connected with two-way audio while capturing motion events
Summary of Products Mentioned
Wyze MicroSD Card Wyze Cam v4 + FREE 32GB MicroSD Card Wyze Cam v4 Wyze Cam Pan v3 Wyze Cam v3 Security System Bundle
FeatureWyze MicroSD CardWyze Cam v4 + FREE 32GB MicroSD CardWyze Cam v4Wyze Cam Pan v3Wyze Cam v3 Security System Bundle
TypeAccessory (MicroSD Card)Camera + 32GB MicroSD Card BundleCameraCameraBundle (Cameras + microSD Cards)
Storage Options32GB, 128GB, 256GB microSD Cards32GB MicroSD Card includedSupports microSD card up to 512GBSupports microSD up to 256GB ExFATIncludes 32GB, 128GB, or 256GB microSD Cards
Price$8.99 (32GB), $16.99 (128GB), $29.99 (256GB)$35.98$25.98 - $71.96 (varies by pack/color)$39.98 (single)$109.99 - $147.92 (depending on bundle variant)
Video ResolutionN/A2.5K QHD (2560x1440)2.5K QHD (2560x1440)1080p (1920x1080)1080p (1920x1080)
Night VisionN/AEnhanced Color Night VisionEnhanced Color Night Vision4 IR LEDs (850 nm)1080p Color Night Vision
Continuous Local RecordingYes (with Wyze Cam)YesYesYesYes
Motion DetectionN/AYesYesYesYes
AudioN/A2-way audio2-way audioBuilt-in speaker & microphone, 2-way audio2-way audio
Field of View (FOV)N/ADFOV 115.8°, HFOV 98.5°, VFOV 53.1°DFOV 115.8°, HFOV 98.5°, VFOV 53.1°120° FOVN/A
Weather ResistanceN/AIP65IP65IP65IP65
ConnectivityN/A2.4 GHz Wi-Fi, Wi-Fi 62.4 GHz Wi-Fi, Wi-Fi 62.4 GHz Wi-Fi (no 5 GHz)N/A
Smart Assistant IntegrationN/AAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTN/A
Mounting OptionsN/AStand, Wall mount, Ceiling mount, Magnetic mountStand, Wall mount, Ceiling mount, Magnetic mountScrew mountMagnetic mounting kit, Screw kit, Adjustable stand
Power SourceN/AWired (Indoor USB Power Adapter included)Wired (Indoor USB Power Adapter included)Wired (Power Adapter included)Plug-in
DimensionsN/A2in x 2in x 2 3/8in2in x 2in x 2 3/8in124mm x 60mm x 63mmN/A
WeightN/A0.49 lb (222 g)0.49 lb (222 g)11.29 oz (320 g)N/A
WarrantyN/A1 Year1 Year1 YearN/A
Included ItemsMicroSD Card onlyWyze Cam v4, 32GB MicroSD CardWyze Cam v4, Power Adapter, Mounts, CableWyze Cam Pan v3, Power Adapter, Cable, MountWyze Cam v3 cameras + microSD Cards
What is the best microSD card for Wyze Cam v3 motion event capture?The Wyze MicroSD Card is the best choice for capturing motion events on Wyze Cam v3. It is specifically designed for Wyze cameras, supports continuous 24/7 recording, and is available in 32GB, 128GB, and 256GB sizes.
Does Wyze Cam v3 require a subscription for local video storage?No, Wyze Cam v3 does not require a subscription for local video storage. By using a Wyze MicroSD Card, you can store footage locally and access it anytime without monthly fees.
What microSD card sizes are compatible with Wyze Cam v3?Wyze Cam v3 supports microSD cards up to 512GB, but Wyze recommends using their own Wyze MicroSD Cards, which are available in 32GB, 128GB, and 256GB sizes for optimal performance.
Can I use the Wyze MicroSD Card with other Wyze cameras?Yes, the Wyze MicroSD Card is compatible with Wyze Cam v3, Wyze Cam v4, Wyze Cam Pan v3, and any other Wyze camera that has a microSD slot.
What are the benefits of using a Wyze MicroSD Card for motion event recording?Using a Wyze MicroSD Card allows for continuous local recording, easy playback of motion events, no monthly fees, and reliable performance tailored for Wyze cameras.
Does the Wyze Cam v4 come with a microSD card?Yes, the Wyze Cam v4 includes a FREE 32GB Wyze MicroSD Card, so you can start recording locally right out of the box.
What is the video resolution of Wyze Cam v3 and Wyze Cam v4?Wyze Cam v3 records in 1080p Full HD, while Wyze Cam v4 offers 2.5K Quad HD (2560x1440) resolution for even clearer video.
Can Wyze Cam Pan v3 record motion events to a microSD card?Yes, Wyze Cam Pan v3 supports microSD cards up to 256GB (ExFAT format) for local recording of motion events, providing 360° coverage and easy playback.
Is the Wyze MicroSD Card durable for continuous video recording?Yes, the Wyze MicroSD Card is engineered for durability and can handle the demands of continuous 24/7 video recording.
What is included in the Wyze Cam v3 Security System Bundle?The Wyze Cam v3 Security System Bundle includes multiple Wyze Cam v3 units and Wyze MicroSD Cards (32GB or 128GB), offering a complete solution for motion event capture and local storage across your property.
How do I access recorded motion events on my Wyze camera?You can access recorded motion events directly through the Wyze app or by removing the microSD card and viewing the footage on a computer.
Do Wyze cameras support continuous recording and time lapse features?Yes, with a Wyze MicroSD Card installed, Wyze cameras support continuous 24/7 recording, time lapse videos, and easy event playback.
What are the available sizes for the Wyze MicroSD Card?Can the Wyze MicroSD Card be used with other Wyze cameras besides the Wyze Cam v3?Do you have any deals, ongoing sales, discounts, or promotions for the Wyze MicroSD Card?
