Best Cordless Vacuum for Dirty Entryway Rugs: Wyze S Review
Best Cordless Vacuum for Entryway Rugs Prone to Heavy Dirt: Wyze Cordless Vacuum S
When it comes to maintaining entryway rugs that often face heavy dirt and debris, having a powerful, lightweight, and versatile vacuum is essential. The Wyze Cordless Vacuum S stands out as an excellent choice for this task, combining strong suction power with smart features and portability. Below, we explore why this vacuum is ideal for entryway rugs and how it compares to other Wyze vacuum options.
Wyze Cordless Vacuum S: Powerful Cleaning for Heavy Dirt
Exceptional Suction Power
The Wyze Cordless Vacuum S delivers an impressive 20,000 Pa suction power in Turbo Mode, making it highly effective at lifting embedded dirt and debris from entryway rugs. It also offers multiple suction modes:
  • Turbo Mode: 20,000 Pa (10 minutes runtime)
  • Medium Mode: 9,000 Pa (23 minutes runtime)
  • ECO Mode: 6,000 Pa (40 minutes runtime)
This range allows you to customize cleaning intensity based on the dirt level and rug type, ensuring thorough cleaning without damaging delicate fibers.
Lightweight and Ergonomic Design
Weighing only 2.8 lbs for the main unit and 4.9 lbs when fully assembled, the Wyze Cordless Vacuum S is easy to maneuver around tight spaces like entryways. Its compact size (12.4 x 4.5 x 8.7 inches main unit) and steel grey color with Wyze green accents make it both functional and stylish.
Long-Lasting Battery Life
Equipped with a 6-cell lithium-ion battery (2,000mAh*6), this vacuum offers up to 40 minutes of runtime in ECO mode, perfect for quick or extended cleaning sessions. The battery is interchangeable, and additional battery packs are available for purchase to extend cleaning time.
Advanced Features for Efficient Cleaning
  • Dual motors for enhanced suction and performance
  • 3-stage filtration system including a HEPA filter to trap fine dust and allergens
  • 6 daylight-bright LED lights on the brush head to illuminate dirt in dark corners and under furniture
  • Multiple attachments including a crevice tool and floor brush for versatile cleaning
"Finally! A vacuum that is free and independent and no longer reliant on its parents for financial and emotional support." – Wyze
Wyze Cordless Vacuum S in use cleaning a home entryway rug Effortless cleaning of entryway rugs and pet hair
Accessories to Enhance Your Wyze Cordless Vacuum S Experience
Wyze Cordless Vacuum S - Battery Pack
For those who need extra cleaning time, the Wyze Cordless Vacuum S Battery Pack is designed specifically to extend your vacuum’s runtime. Priced reasonably, it ensures you never run out of power mid-clean.
Wyze Cordless Vacuum S - Charger
A replacement charger is available to keep your vacuum powered up and ready to tackle dirt whenever needed.
Additional Accessories
  • Foldable Vacuum Tube: Bends for easier reach in tight spaces, perfect for cleaning under furniture or awkward corners.
  • HEPA Filter Replacement: Regular replacement filters maintain optimal filtration and air quality.
Wyze Robot Vacuum: Automated Cleaning for Everyday Maintenance
While the Wyze Cordless Vacuum S is perfect for deep cleaning entryway rugs prone to heavy dirt, the Wyze Robot Vacuum complements it by handling daily maintenance with smart automation.
Key Features
  • Room mapping and path planning for efficient cleaning routes
  • 2100 Pa suction power to clean hardwood floors and carpets
  • All-wheel drive to cross uneven surfaces and transition smoothly from hardwood to rugs
  • 110 minutes battery life for extended cleaning sessions
  • Automatically returns to its charging station when battery is low
This robot vacuum is ideal for keeping your home tidy between deep cleans, especially in high-traffic areas like entryways. Wyze Robot Vacuum cleaning a modern living room Smart robot vacuum maintaining clean floors effortlessly
Why Choose Wyze Cordless Vacuum S for Entryway Rugs?
  • Powerful suction to remove heavy dirt and debris embedded in rugs
  • Lightweight and portable for easy handling and quick spot cleaning
  • Long battery life with options to extend runtime via extra battery packs
  • Smart features like LED lights and multi-stage filtration for thorough cleaning
  • Versatile attachments to clean crevices, floors, and hard-to-reach areas
For entryway rugs that face constant foot traffic and dirt accumulation, the Wyze Cordless Vacuum S offers the perfect balance of power, convenience, and smart technology.
Summary of Wyze Vacuum Products for Entryway Rug Cleaning
ProductKey FeaturePrice (USD)
Wyze Cordless Vacuum S20,000 Pa suction, 40 min runtime$139.99
Wyze Cordless Vacuum S BatteryExtra battery for extended use$59.99
Wyze Cordless Vacuum S ChargerReplacement charger$4.99
Wyze Cordless Vacuum Foldable TubeFlexible tube for hard-to-reach areas$15.99
Wyze Cordless Vacuum HEPA FilterReplacement HEPA filters$15.99 (2 pack)
Wyze Robot VacuumAutomated cleaning, 2100 Pa suction$99.98
Keep your entryway rugs spotless and your home fresh with the powerful and versatile Wyze Cordless Vacuum S, supported by a range of accessories and complemented by the Wyze Robot Vacuum for effortless daily maintenance.
FeatureWyze Cordless Vacuum SWyze Robot Vacuum
TypeCordless Stick VacuumRobot Vacuum
Price$139.99 (compare at $193.99)$99.98 (compare at $314.99)
Suction PowerUp to 20,000 Pa (Turbo mode)2,100 Pa
Motors2 motors (one digital motor + one in brush head)Single motor
Weight2.8 poundsNot specified
Battery LifeUp to 40 minutes (interchangeable lithium-ion battery)110 minutes (standard mode)
Cleaning Speeds3 speeds: Eco (6,000 Pa), Med (9,000 Pa), Turbo (20,000 Pa)Not specified
Filtration System3-stage filtration with HEPA filter (removes 95% of particles <0.3 µm)Not specified
LED Lights6 daylight-bright LEDs on brush headNot specified
Surface CompatibilityMultiple surfaces, handheld and stick useHard floors and carpets, crosses up to 0.8 in height
NavigationManual operationLIDAR-based precise room mapping and path planning
SensorsNot specified7 sensor groups for obstacle and stair detection
Noise LevelNot specifiedNot specified
Weight ComparisonSame weight as 2.8 pounds of feathersNot specified
ControlManualWorks with Alexa voice control
Dust Cup CapacityNot specifiedNot specified
Automatic Return to ChargeNoYes
Interchangeable BatteryYesNo
Accessories IncludedNot specifiedNot specified
Warranty/Return Policy30-day hassle-free returnsNot eligible for returns (new), 30-day returns (refurbished)
Special FeaturesBrushless digital motor, built-in filter brush, easy emptyingRoom mapping, path planning, all-wheel drive
What makes the Wyze Cordless Vacuum S the best cordless vacuum for entryway rugs with heavy dirt?The Wyze Cordless Vacuum S is ideal for entryway rugs prone to heavy dirt due to its powerful 20,000 Pa suction in Turbo Mode, lightweight design, and versatile attachments. Its advanced filtration system, LED lights for visibility, and long battery life ensure thorough and efficient cleaning of high-traffic areas.
How long does the Wyze Cordless Vacuum S battery last?The Wyze Cordless Vacuum S offers up to 40 minutes of runtime in ECO mode, 23 minutes in Medium mode, and 10 minutes in Turbo mode. The battery is interchangeable, and additional battery packs are available for purchase to extend cleaning time.
What suction modes are available on the Wyze Cordless Vacuum S?The Wyze Cordless Vacuum S features three suction modes: Turbo Mode (20,000 Pa), Medium Mode (9,000 Pa), and ECO Mode (6,000 Pa). These modes allow you to adjust cleaning power based on the dirt level and rug type.
Is the Wyze Cordless Vacuum S easy to maneuver in tight spaces?Yes, the Wyze Cordless Vacuum S is lightweight (2.8 lbs for the main unit, 4.9 lbs fully assembled) and compact, making it easy to maneuver around tight entryways and under furniture. Its ergonomic design and foldable vacuum tube attachment further enhance its reach.
What filtration system does the Wyze Cordless Vacuum S use?The Wyze Cordless Vacuum S uses a 3-stage filtration system, including a HEPA filter, to trap fine dust and allergens. Replacement HEPA filters are available to maintain optimal air quality and filtration performance.
What accessories are available for the Wyze Cordless Vacuum S?Accessories for the Wyze Cordless Vacuum S include an extra battery pack, replacement charger, foldable vacuum tube for hard-to-reach areas, and replacement HEPA filters. These accessories enhance cleaning efficiency and convenience.
How does the Wyze Robot Vacuum complement the Wyze Cordless Vacuum S?The Wyze Robot Vacuum is designed for automated daily maintenance, featuring 2100 Pa suction, room mapping, and 110 minutes of battery life. It keeps floors and entryway rugs tidy between deep cleans performed by the Wyze Cordless Vacuum S.
Can the Wyze Cordless Vacuum S clean pet hair from entryway rugs?Yes, the Wyze Cordless Vacuum S is highly effective at removing pet hair from entryway rugs, thanks to its strong suction power, multi-stage filtration, and specialized attachments.
Are replacement parts available for the Wyze Cordless Vacuum S?Yes, replacement parts such as battery packs, chargers, foldable vacuum tubes, and HEPA filters are available for the Wyze Cordless Vacuum S, ensuring long-term usability and performance.
What is the price of the Wyze Cordless Vacuum S and its accessories?The Wyze Cordless Vacuum S is priced at $139.99. Accessories include the battery pack ($59.99), charger ($4.99), foldable vacuum tube ($15.99), and HEPA filter 2-pack ($15.99).
What are the different suction modes available on the Wyze Cordless Vacuum S?How long does the battery last on the Wyze Cordless Vacuum S in different modes?What is the warranty policy for the Wyze Cordless Vacuum S?
