Wyze Cordless Vacuum S: Fast Pet Mud Cleanup, Cordless Power
Wyze Cordless Vacuum S: The Ultimate Pet Mud Cleanup Solution
If you’re tired of tracked-in mud from your pets and need a fast, efficient cordless vacuum, the Wyze Cordless Vacuum S is your perfect cleaning companion. Designed for quick cleanups and powerful suction, this vacuum is ideal for pet owners who want to keep their homes spotless without the hassle of cords or heavy equipment.
Experience the freedom of cordless cleaning with 20,000 Pa suction power and a feather-light design that makes tackling muddy paw prints effortless.
Pet-friendly vacuuming lifestyle
Key Features of Wyze Cordless Vacuum S
Powerful Suction for Deep Cleaning
The Wyze Cordless Vacuum S boasts an impressive suction range to handle everything from light dust to stubborn mud:
  • Turbo Mode: 20,000 Pa for heavy-duty messes
  • Medium Mode: 9,000 Pa for everyday cleaning
  • ECO Mode: 6,000 Pa for extended runtime and light debris
  • Air Watts: 100 AW for efficient suction power
This makes it perfect for quickly cleaning up tracked-in mud and pet hair without multiple passes.
Ultra-Lightweight and Ergonomic
Weighing only 2.8 lbs (main unit) and 4.9 lbs (assembled), this vacuum is as light as 2.8 pounds of feathers, making it easy to maneuver around furniture and tight spaces. Its compact size (12.4 x 4.5 x 8.7 inches main unit) ensures you can clean fast without fatigue.
Long-Lasting Battery Life
Equipped with a 6-cell lithium-ion battery (2,000mAh*6), the vacuum offers:
  • 40 minutes runtime in ECO mode
  • 23 minutes in Medium mode
  • 10 minutes in Turbo mode
The battery is interchangeable, so you can extend cleaning sessions with an additional battery pack if needed.
Advanced Cleaning Technology
  • Dual motors for enhanced suction and efficiency
  • 3-stage filtration system including a HEPA filter to trap allergens and fine dust
  • 6 daylight-bright LED lights on the brush head to illuminate dirt in dark corners and under furniture
Versatile Attachments Included
The vacuum comes with essential tools to tackle various surfaces and messes:
  • Crevice Tool for tight spots
  • Floor Brush for hard floors and carpets
  • Dust Cap and HEPA Filter for easy maintenance
  • Standard Tube for extended reach
Enhance Your Cleaning Experience with Wyze Accessories
To keep your Wyze Cordless Vacuum S performing at its best and adapt it to your cleaning needs, consider these compatible accessories:
Wyze Cordless Vacuum S - Battery Pack
Need extra juice for longer cleaning sessions? This battery pack is designed specifically for the Wyze Cordless Vacuum S, allowing you to swap batteries and keep cleaning without waiting for a recharge.
Wyze Cordless Vacuum S - Charger
A replacement charger ensures your vacuum is always ready to go. Compact and compatible, it supports fast AC charging (4-6 hours to full charge).
This accessory bends so you don’t have to, making it easier to clean under furniture or awkward spaces without straining.
Wyze Cordless Vacuum - HEPA Filter
Replace your HEPA filter regularly to maintain optimal filtration and air quality, especially important for pet owners sensitive to allergens.
Wyze Cordless Vacuum - Mini Motorized Brush Head
Perfect for cleaning car seats, sofas, and other upholstery where pet hair and mud tend to accumulate.
Lifestyle vacuuming with dog
Why Choose Wyze Cordless Vacuum S for Pet Mud Cleanup?
  • Cordless convenience means no tangled cords or limited reach
  • Powerful suction handles mud, dirt, and pet hair with ease
  • Lightweight design reduces fatigue during quick cleanups
  • Long battery life supports multiple rooms or quick spot cleaning
  • Pet-friendly features like HEPA filtration and LED lights help maintain a clean, allergen-free home
The Wyze Cordless Vacuum S is the smart choice for pet owners who want fast, effective cleanup of tracked-in mud and everyday messes without the hassle.
Home cleaning lifestyle
Product Summary
FeatureSpecification
Suction PowerUp to 20,000 Pa (Turbo Mode)
Weight2.8 lbs (main unit), 4.9 lbs (assembled)
Battery6-cell lithium-ion, 2,000mAh*6
Runtime40 min (ECO), 23 min (Medium), 10 min (Turbo)
Dust Cup Volume0.7 L
Noise Level65 dBA (Turbo Mode)
Filtration3-stage with HEPA filter
LED Lights6 bright LEDs on brush head
Included AttachmentsCrevice Tool, Floor Brush, HEPA Filter, Dust Cap, Standard Tube
Conclusion
For pet owners dealing with muddy paw prints and fast cleanups, the Wyze Cordless Vacuum S offers a powerful, lightweight, and cordless solution. Its advanced features and versatile accessories make it a top choice for maintaining a clean, pet-friendly home.
ProductTypePrice (USD)Key FeaturesCompatibilityWeight / Dimensions
Wyze Cordless Vacuum SConnected Home139.9920,000 Pa suction, 40-min interchangeable battery, 2 motors, 2.8 lbs, 3-speed settings, LED lights, 3-stage HEPA filtrationWyze Cordless Vacuum S2.8 lbs
Wyze Cordless Vacuum S - Battery PackAccessories59.99Extra interchangeable battery for extended useWyze Cordless Vacuum SNot specified
Wyze Cordless Vacuum S - ChargerReplacement Part4.99Replacement chargerWyze Cordless Vacuum SNot specified
Wyze Cordless Vacuum - Foldable Vacuum TubeAccessories15.99Flexible tube attachment for easier cleaningWyze Cordless VacuumNot specified
Wyze Cordless Vacuum - HEPA FilterAccessories15.992-pack HEPA filters, washable, replace regularlyWyze Cordless VacuumNot specified
Wyze Cordless Vacuum - Mini Motorized Brush HeadAccessories29.99Motorized brush for car seats and sofas, compact sizeWyze Cordless Vacuum6 x 5.5 x 5 inches
What makes the Wyze Cordless Vacuum S ideal for cleaning up pet mud?The Wyze Cordless Vacuum S is designed with powerful suction (up to 20,000 Pa in Turbo Mode), a lightweight build, and cordless convenience, making it perfect for quickly cleaning up tracked-in mud and pet hair. Its HEPA filtration system also helps trap allergens, making it especially suitable for pet owners.
How long does the battery last on the Wyze Cordless Vacuum S?The Wyze Cordless Vacuum S offers up to 40 minutes of runtime in ECO mode, 23 minutes in Medium mode, and 10 minutes in Turbo mode. The battery is interchangeable, so you can extend cleaning sessions by swapping in a spare battery pack.
What attachments are included with the Wyze Cordless Vacuum S?The vacuum comes with a Crevice Tool for tight spaces, a Floor Brush for hard floors and carpets, a Dust Cap, a HEPA Filter, and a Standard Tube for extended reach. Additional accessories like a Mini Motorized Brush Head and Foldable Vacuum Tube are also available.
Does the Wyze Cordless Vacuum S have HEPA filtration?Yes, the Wyze Cordless Vacuum S features a 3-stage filtration system that includes a HEPA filter, which helps trap fine dust and allergens, making it ideal for homes with pets.
How powerful is the suction on the Wyze Cordless Vacuum S?The Wyze Cordless Vacuum S delivers up to 20,000 Pa of suction power in Turbo Mode, 9,000 Pa in Medium Mode, and 6,000 Pa in ECO Mode, ensuring effective cleaning for everything from light dust to stubborn mud.
Is the Wyze Cordless Vacuum S easy to maneuver?Yes, the vacuum is ultra-lightweight, weighing only 2.8 lbs for the main unit and 4.9 lbs when fully assembled. Its compact design makes it easy to clean around furniture and in tight spaces without fatigue.
What is the dust cup capacity of the Wyze Cordless Vacuum S?The Wyze Cordless Vacuum S has a dust cup volume of 0.7 liters, allowing for multiple cleanups before needing to be emptied.
Are there any special features for cleaning in dark areas?Yes, the Wyze Cordless Vacuum S is equipped with 6 daylight-bright LED lights on the brush head, making it easy to spot and clean dirt in dark corners and under furniture.
Can I purchase additional batteries or accessories for the Wyze Cordless Vacuum S?Yes, you can purchase compatible accessories such as extra battery packs, replacement chargers, foldable vacuum tubes, HEPA filters, and a mini motorized brush head to enhance your cleaning experience.
How loud is the Wyze Cordless Vacuum S during operation?The Wyze Cordless Vacuum S operates at a noise level of 65 dBA in Turbo Mode, making it relatively quiet for a high-suction cordless vacuum.
What are the key features of the Wyze Cordless Vacuum S?How long does the battery last on the Wyze Cordless Vacuum S?What is the warranty policy for the Wyze Cordless Vacuum S?
