Best 3x Telephoto Indoor Outdoor Security Camera Bundle
When it comes to securing your home or business both indoors and outdoors, having a versatile camera bundle with powerful zoom capabilities is essential. For those seeking the best 3x telephoto security cameras that perform flawlessly in any environment, this curated bundle offers top-tier options combining advanced zoom, weather resistance, and smart features. This guide highlights the best Wyze cameras featuring 3x telephoto lenses, perfect for indoor and outdoor use, ensuring you never miss a detail.
Wyze Cam OG Telephoto: Precision Zoom with 3x Telephoto Lens
Key Features:
  • 3x Telephoto Lens: Offers a narrow 27° diagonal field of view, allowing you to zoom in on distant subjects with crystal-clear 1080p resolution.
  • Indoor/Outdoor Use: IP65 weather resistance ensures reliable performance in rain, snow, or shine.
  • Night Vision: Equipped with 4 IR LEDs (850 nm) for clear black-and-white night vision.
  • Video Quality: 1920 x 1080 (1080p) at 20 FPS daytime and 10 FPS nighttime.
  • Audio: Built-in speaker and microphone with noise and echo cancellation for crisp two-way communication.
  • Connectivity: Supports 2.4 GHz Wi-Fi with Alexa, Google Assistant, and IFTTT integrations.
  • Storage: Supports up to 256 GB microSD cards in exFAT format for local recording.
  • Compact Design: Small and lightweight (4.1 oz), easy to mount on walls or ceilings.
The Wyze Cam OG Telephoto is ideal for users who want focused zoom capabilities without sacrificing image quality or weather durability.
Wyze Cam Pan v3: 360° Pan and 180° Tilt with Digital Zoom
Key Features:
  • 360° Horizontal & 180° Vertical Coverage: Pan and tilt your camera remotely to cover every angle indoors or outdoors.
  • 8x Digital Zoom: While not optical, the digital zoom enhances the view to complement the telephoto lens cameras in your bundle.
  • Weather Resistant: IP65 rating makes it perfect for outdoor use with the Wyze Outdoor Power Adapter.
  • Video Resolution: Full HD 1080p with smooth 20 FPS daytime and 15 FPS nighttime video.
  • Night Vision: 4 IR LEDs for clear night monitoring.
  • Two-Way Audio: Built-in speaker and microphone with noise and echo cancellation.
  • Smart Integrations: Works with Alexa, Google Assistant, and IFTTT.
  • Storage: Supports up to 256 GB microSD cards.
This camera adds dynamic coverage to your security system, allowing you to track movement across wide areas with pan and tilt controls.
Wyze Cam Pan v3 in snowy outdoor setting Wyze Cam Pan v3 offers weather-resistant 360° coverage for outdoor security.
Wyze Cam v4 Outdoor Bundle: Enhanced Color Night Vision & 2.5K QHD Resolution
Key Features:
  • 3x Telephoto Zoom Capability: While primarily a wide-angle camera, the Wyze Cam v4 supports 8x digital zoom, complementing telephoto cameras in your bundle.
  • 2.5K QHD Video: Crystal-clear video resolution for detailed monitoring day and night.
  • Enhanced Color Night Vision: See vivid colors even in low light, thanks to advanced sensor technology.
  • Motion-Activated Spotlight: Adds an extra layer of security by illuminating detected motion.
  • Weatherproof: IP65 rating for reliable outdoor use.
  • 24/7 Local Recording: Continuous recording with included 128GB microSD card.
  • Smart Home Compatible: Works seamlessly with Alexa and Google Assistant.
  • Wi-Fi 6 Support: Faster and more reliable wireless connectivity.
The Wyze Cam v4 Outdoor Bundle is perfect for users who want high-resolution video and color night vision in a weatherproof package.
Why Choose This Bundle?
Combining the Wyze Cam OG Telephoto with the Wyze Cam Pan v3 and Wyze Cam v4 Outdoor Bundle gives you:
  • Versatile Zoom Options: Optical 3x telephoto zoom plus digital zoom for detailed surveillance.
  • Indoor and Outdoor Coverage: IP65 weather resistance ensures cameras perform in all conditions.
  • Smart Features: Two-way audio, motion detection, and smart assistant compatibility.
  • High-Quality Video: From 1080p Full HD to 2.5K QHD resolution with enhanced night vision.
  • Flexible Storage: Local microSD support up to 256GB for continuous or event-based recording.
This combination ensures comprehensive security coverage with the ability to zoom in on critical details, whether monitoring your front porch, backyard, or indoor spaces.
Additional Recommendations for Enhanced Security
  • Consider adding Wyze Cam Floodlight v2 for powerful 2800 lumens illumination combined with 2K video and color night vision to deter intruders effectively.
  • For wireless flexibility, the Wyze Battery Cam Pro offers 2.5K HDR video with integrated spotlight and siren, perfect for areas without wired power.
Conclusion
For the best 3x telephoto indoor and outdoor security camera bundle, the Wyze lineup offers unmatched value, advanced zoom capabilities, and robust weather resistance. The Wyze Cam OG Telephoto leads with true optical zoom, while the Wyze Cam Pan v3 and Wyze Cam v4 Outdoor Bundle provide comprehensive coverage and high-resolution video. Together, they form a powerful security system tailored for any environment. Secure your home with confidence and clarity using this expertly selected bundle.
Wyze Cam Floodlight v2 illuminating driveway at night Add powerful lighting and 2K color night vision with Wyze Cam Floodlight v2.
FeatureWyze Cam OG TelephotoWyze Cam Pan v3Wyze Cam v4Wyze Cam Floodlight v2Wyze Battery Cam Pro
TypeWired Indoor/OutdoorWired Indoor/Outdoor Pan & TiltWired Indoor/OutdoorWired Outdoor FloodlightWireless Battery-Powered Outdoor
Video ResolutionNot specified (improved live stream)Not specified2.5K QHD (2560x1440)2K (2304x1296)2.5K HDR (2560x1440)
Field of View27° (3x Telephoto lens)360° Pan, 180° TiltDFOV 115.8°, HFOV 98.5°, VFOV 53.1°160° DiagonalDFOV 134°, HFOV 108°, VFOV 56°
Zoom3x TelephotoPan & Tilt (360°/180°)8x Digital ZoomNo zoomNo zoom
Night VisionColor Night VisionColor Night Vision (Starlight Sensor)Enhanced Color Night VisionColor Night VisionIR LEDs + White LEDs (Color Night Vision)
Weather ResistanceIP65IP65 (requires Outdoor Power Adapter)IP65IP65IP65
AudioImproved 2-way audioTwo-way audioTwo-way talk, 99dB waterproof speakerTwo-way audioTwo-way audio with MEMS mic
Siren90 dB user-activated sirenNo built-in sirenBuilt-in siren105 dB siren100 dB siren
Power SourceWiredWired (Outdoor Power Adapter sold separately)WiredHardwiredRechargeable battery packs
Local StorageSupports Wyze microSD cards up to 256GBSupports Wyze microSD cardsmicroSD card up to 512GBSupports up to 256GB microSDSupports up to 256GB microSD
Cloud StorageCam Plus subscription availableCam Plus subscription availableCam Plus subscription availableCam Plus subscription availableCam Plus subscription available
Motion Detection3x faster notificationsMotion tracking, motion & sound detectionMotion detection with zonesMotion detectionRadar + PIR motion detection
Additional Features3x faster live streaming, customizable detection zones, smoke & CO alertsPan Scan™ patrol, Privacy Mode, smoke & CO alertsMotion-activated spotlight, Alexa/Google/IFTTT integrationAI-Powered Light Control, dusk-to-dawn automationIntegrated spotlight, radar motion detection, 6-month battery life
DimensionsNot specifiedNot specified2in x 2in x 2 3/8in9.5in x 7.7in x 7.0in2.5 x 1.8 x 3.5 inches
WeightNot specifiedNot specified0.49 lb (222 g)2.76 lbs (1.25 kg)0.94 lbs
Compatible Phone OSAndroid 9.0+, iOS 15.0+Android 9.0+, iOS 15.0+Android 9.0+, iOS 15.0+Android 9.0+, iOS 15.0+Android 9.0+, iOS 15.0+
IntegrationsNot specifiedAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTT
WarrantyNot specifiedNot specified1 Year1 YearNot specified
What is the best 3x telephoto indoor and outdoor security camera bundle?The best 3x telephoto indoor and outdoor security camera bundle features Wyze cameras, including the Wyze Cam OG Telephoto, Wyze Cam Pan v3, and Wyze Cam v4 Outdoor Bundle. This combination offers advanced optical and digital zoom, weather resistance, high-resolution video, and smart features for comprehensive home or business security.
What are the key features of the Wyze Cam OG Telephoto?The Wyze Cam OG Telephoto offers a 3x telephoto lens with a 27° diagonal field of view, 1080p resolution, IP65 weather resistance for indoor and outdoor use, night vision with 4 IR LEDs, two-way audio with noise and echo cancellation, support for up to 256GB microSD cards, and compatibility with Alexa, Google Assistant, and IFTTT.
Can the Wyze Cam OG Telephoto be used outdoors?Yes, the Wyze Cam OG Telephoto is IP65 weather resistant, making it suitable for both indoor and outdoor use in various weather conditions, including rain and snow.
What makes the Wyze Cam Pan v3 suitable for security coverage?The Wyze Cam Pan v3 provides 360° horizontal and 180° vertical coverage with remote pan and tilt controls, 8x digital zoom, IP65 weather resistance, 1080p HD video, night vision, two-way audio, and compatibility with Alexa, Google Assistant, and IFTTT. It is ideal for tracking movement across wide areas.
Does the Wyze Cam v4 Outdoor Bundle support telephoto zoom?While the Wyze Cam v4 Outdoor Bundle is primarily a wide-angle camera, it supports up to 8x digital zoom, which complements the optical zoom capabilities of other cameras in the bundle. It also features 2.5K QHD video, enhanced color night vision, and weatherproof design.
How much local storage do Wyze security cameras support?Wyze security cameras in this bundle support up to 256GB microSD cards for local recording. The Wyze Cam v4 Outdoor Bundle includes a 128GB microSD card for 24/7 continuous recording.
Are Wyze security cameras compatible with smart home systems?Yes, Wyze security cameras are compatible with popular smart home systems, including Alexa, Google Assistant, and IFTTT, allowing for seamless integration and voice control.
What are the benefits of combining Wyze Cam OG Telephoto, Pan v3, and v4 Outdoor Bundle?Combining these cameras provides versatile zoom options (optical and digital), comprehensive indoor and outdoor coverage, smart features like two-way audio and motion detection, high-quality video from 1080p to 2.5K QHD, and flexible local storage. This ensures you never miss important details in any environment.
What additional Wyze products can enhance my security system?For enhanced security, consider adding the Wyze Cam Floodlight v2, which offers 2800 lumens of illumination, 2K video, and color night vision, or the Wyze Battery Cam Pro for wireless 2.5K HDR video, integrated spotlight, and siren—ideal for areas without wired power.
Do Wyze security cameras offer night vision?Yes, Wyze security cameras feature night vision capabilities. The Wyze Cam OG Telephoto and Pan v3 use IR LEDs for clear black-and-white night vision, while the Wyze Cam v4 Outdoor Bundle offers enhanced color night vision for vivid images even in low light.
What are the key features of the Wyze Cam Pan v3?Can you tell me more about the night vision capabilities of the Wyze Cam OG Telephoto?Do you have any deals, ongoing sales, discounts, or promotions available?
