Wyze Battery Cam Pro: Rugged, Long-Lasting Wireless Security
Long Lasting Security Solution with Rugged Exterior: Wyze Battery Cam Pro Series
When it comes to securing your home or business with a reliable, long-lasting, and rugged security camera, the Wyze Battery Cam Pro lineup stands out as a top choice. Designed for wire-free convenience and built to withstand harsh weather conditions, these cameras offer pro-grade protection with a tough exterior housing that ensures durability and performance.
Wyze Battery Cam Pro: Rugged, Wire-Free Security
Superior Video Quality and Smart Detection
The Wyze Battery Cam Pro delivers stunning 2.5K HDR video resolution, providing crystal-clear images day and night. Thanks to its high dynamic range and color night vision, every detail is captured with vibrant colors and sharp contrast, ensuring you never miss a moment.
Dual Motion Detection Technology
Equipped with both Radar and PIR motion sensors, this camera offers double the detection accuracy. This combination allows for earlier and more precise alerts, reducing false alarms and enhancing your security. Customize detection zones via the Wyze app for tailored monitoring.
Weatherproof and Built to Last
With an IP65 weatherproof rating, the Wyze Battery Cam Pro is designed to endure rain, dust, and extreme temperatures. Its rugged exterior housing protects internal components, making it ideal for outdoor use in any climate.
Flexible Power Options
  • Removable, Rechargeable Battery Packs: Easily swap batteries without taking down the camera, minimizing downtime.
  • Optional Solar Panel: Extend your camera’s runtime by converting sunlight into power, perfect for remote or hard-to-reach locations.
  • Dual-Band Wi-Fi Support: Connect seamlessly to 2.4 GHz or 5 GHz networks for faster and more reliable streaming.
Additional Features
  • Integrated 150-lumen spotlight and siren for active deterrence.
  • Two-way audio to communicate through the camera.
  • Local recording via microSD card (up to 256GB) for continuous capture without subscription.
  • Instant Bluetooth setup for quick installation.
“No wires. No hubs. Just rugged, reliable security wherever you need it.”
Wyze Battery Cam Pro in outdoor lifestyle setting Wyze Battery Cam Pro installed outdoors for seamless home security.
Wyze Battery Cam Pro + Solar Panel: Continuous Power, Endless Protection
Solar-Powered Security for Ultimate Convenience
The Wyze Battery Cam Pro + Solar Panel bundle combines the rugged, wire-free camera with a dedicated solar panel to keep your security system powered continuously. This eco-friendly solution reduces the need for frequent battery charging, making it perfect for long-term outdoor monitoring.
Key Benefits
  • Same 2.5K HDR video quality and dual motion detection as the standalone camera.
  • IP65 weatherproof rating ensures durability in all weather conditions.
  • Solar panel converts sunlight into energy, extending battery life and reducing maintenance.
  • Compatible with all Wyze Battery Cam Pro accessories, including removable batteries and charging docks.
Easy Installation and Setup
No electrician or power outlet needed. Simply mount the camera and solar panel where they get optimal sunlight, and enjoy uninterrupted security coverage.
“Harness the power of the sun for a greener, longer-lasting security solution.”
Accessories to Enhance Your Wyze Battery Cam Pro Experience
Wyze Removable Battery Pack
Keep your cameras running without interruption by swapping in fully charged battery packs. Each pack offers 6200mAh capacity, lasting up to 6 months on a single charge under typical usage.
Wyze Battery Charging Dock
Charge two battery packs simultaneously with this compact dock, ensuring you always have a backup ready to go.
Wyze Universal Mount (Long)
For flexible mounting options, especially on ceilings or under eaves, this durable mount with an extended stem provides the perfect solution.
Why Choose Wyze Battery Cam Pro for Your Security Needs?
  • Rugged Exterior Housing: Built tough to withstand outdoor elements.
  • Long Battery Life: Rechargeable packs and solar options for extended use.
  • Wireless Freedom: No hubs or complicated wiring required.
  • Advanced Detection: Radar + PIR sensors for smart, accurate alerts.
  • High-Quality Video: 2.5K HDR with color night vision for clear monitoring.
  • Easy Setup: Bluetooth-enabled installation in minutes.
Protect your property with a security camera that combines rugged durability, long-lasting power, and smart technology — the Wyze Battery Cam Pro series is your ultimate security solution.
Product Summary
Product NameKey FeaturesPrice Range
Wyze Battery Cam Pro2.5K HDR, Radar + PIR, IP65, Rechargeable Battery$89.98 - $219.98
Wyze Battery Cam Pro + Solar PanelAll above + Solar Panel for continuous power$109.98
Wyze Removable Battery Pack6200mAh rechargeable battery$22.99
Wyze Battery Charging DockCharges two batteries simultaneously$17.99
FeatureWyze Battery Cam ProWyze Battery Cam Pro + Solar Panel
Video Resolution2.5K HDR2.5K HDR
Power SourceRemovable, Rechargeable Battery PacksRemovable, Rechargeable Battery Packs + Solar Panel for continuous power
WirelessWire-Free, No Hub requiredWire-Free, No Hub required
Integrated Spotlight & SirenYesYes
Motion DetectionRadar + PIR Motion DetectionRadar + PIR Motion Detection
Weatherproof RatingIP65IP65
WiFi Support2.4 & 5 GHz2.4 & 5 GHz
Local RecordingYes (with MicroSD card)Yes (with MicroSD card)
Battery Life ExtensionBattery packs onlySolar Panel extends battery life
SetupInstant BluetoothⓇ Setup, No QR codeInstant BluetoothⓇ Setup, No QR code
Two-Way AudioEnhanced Two-Way AudioEnhanced Two-Way Audio
Price (Single Unit)$89.98$109.98
Color OptionsBlack, WhiteBlack, White
Included in Package1x Wyze Battery Cam Pro1x Wyze Battery Cam Pro + 1x Wyze Solar Panel
Mounting OptionsFlexible, including ceiling mount (with accessory)Flexible, including ceiling mount (with accessory)
Additional FeaturesRemovable battery packs, Radar + PIR sensors, Integrated spotlightSame as Battery Cam Pro plus Solar Panel for continuous power
What is the Wyze Battery Cam Pro?The Wyze Battery Cam Pro is a rugged, wire-free security camera designed for both home and business use. It features 2.5K HDR video resolution, dual motion detection technology, and an IP65 weatherproof rating, making it ideal for outdoor security in any climate.
Does the Wyze Battery Cam Pro work without wires?Yes, the Wyze Battery Cam Pro is completely wire-free, operating on removable, rechargeable battery packs. It does not require any hubs or complicated wiring for installation.
How long does the Wyze Battery Cam Pro battery last?Each Wyze Removable Battery Pack has a 6200mAh capacity and can last up to 6 months on a single charge under typical usage. Battery life may vary depending on usage and environmental conditions.
Is the Wyze Battery Cam Pro weatherproof?Yes, the Wyze Battery Cam Pro has an IP65 weatherproof rating, which means it is designed to withstand rain, dust, and extreme temperatures, making it suitable for outdoor use.
What video quality does the Wyze Battery Cam Pro offer?The Wyze Battery Cam Pro delivers stunning 2.5K HDR video resolution with high dynamic range and color night vision, ensuring clear and vibrant images both day and night.
How does the Wyze Battery Cam Pro detect motion?The camera uses dual motion detection technology, combining Radar and PIR (Passive Infrared) sensors for enhanced accuracy and reduced false alarms. You can also customize detection zones via the Wyze app.
Can I use a solar panel with the Wyze Battery Cam Pro?Yes, the Wyze Battery Cam Pro is compatible with an optional solar panel, which converts sunlight into power to extend the camera’s runtime and reduce the need for frequent battery charging.
Does the Wyze Battery Cam Pro support local video storage?Yes, the camera supports local recording via a microSD card (up to 256GB), allowing for continuous video capture without the need for a subscription.
What are the key features of the Wyze Battery Cam Pro + Solar Panel bundle?The Wyze Battery Cam Pro + Solar Panel bundle includes the rugged, wire-free camera and a dedicated solar panel for continuous, eco-friendly power. It offers 2.5K HDR video, dual motion detection, IP65 weatherproofing, and easy installation without the need for an electrician.
What accessories are available for the Wyze Battery Cam Pro?Available accessories include the Wyze Removable Battery Pack (6200mAh), Wyze Battery Charging Dock (charges two batteries simultaneously), and the Wyze Universal Mount (Long) for flexible installation options.
How do I set up the Wyze Battery Cam Pro?The Wyze Battery Cam Pro features instant Bluetooth setup for quick and easy installation. Simply follow the instructions in the Wyze app to connect your camera and start monitoring.
Does the Wyze Battery Cam Pro have two-way audio?Yes, the Wyze Battery Cam Pro includes two-way audio, allowing you to communicate through the camera using the Wyze app.
What is the price range for the Wyze Battery Cam Pro and its accessories?The Wyze Battery Cam Pro is priced between $89.98 and $219.98, depending on the configuration. The Wyze Battery Cam Pro + Solar Panel bundle is $109.98. Accessories such as the Removable Battery Pack and Battery Charging Dock are available for $22.99 and $17.99, respectively.
What makes the Wyze Battery Cam Pro a good choice for outdoor security?The Wyze Battery Cam Pro is built with a rugged exterior housing, offers long battery life with rechargeable and solar options, provides advanced motion detection, and delivers high-quality 2.5K HDR video. Its wireless design and easy setup make it an excellent choice for reliable outdoor security.
What are the key features of the Wyze Battery Cam Pro?How does the dual motion detection technology work in the Wyze Battery Cam Pro?Do you have any deals, ongoing sales, discounts, or promotions for the Wyze Battery Cam Pro?
