Battery Powered Video Doorbell and Smart Plug Solutions for Airbnb Hosts
For Airbnb hosts, ensuring guest safety and convenience is paramount. Integrating smart home devices like battery-powered video doorbells and smart plugs can elevate your property’s security and guest experience. Below, discover top Wyze products designed to provide seamless control, security, and automation tailored for Airbnb rentals.
Smart Plugs for Airbnb: Indoor and Outdoor Power Control
Wyze Plug Outdoor: Weather-Resistant Smart Plug for Outdoor Use
Power your outdoor devices effortlessly with the
Wyze Plug Outdoor, perfect for Airbnb hosts who want to automate garden lights, holiday decorations, or outdoor appliances.
- Weatherproof Design: Rated IP64, it withstands rain, dust, snow, and dirt, making it ideal for all seasons.
- Dual Outlets with Independent Control: Manage two devices separately from the Wyze app, such as turning off garden lights while keeping a pond pump running.
- Extended WiFi Range: Up to 300 feet in open space ensures reliable connectivity even in large outdoor areas.
- Energy Monitoring: Track energy consumption and set alerts to optimize power usage.
- Voice Control Compatibility: Works with Alexa and Google Assistant for hands-free operation.
- High Power Output: 15 AMP with overload protection supports heavy-duty outdoor devices safely.
This plug is a smart addition to any Airbnb property, allowing hosts to remotely control outdoor lighting and appliances, enhancing guest comfort and security.
Enhance your Airbnb’s outdoor ambiance with smart plug control.
Wyze Plug: Compact Indoor Smart Plug for Versatile Automation
The
Wyze Plug is an excellent choice for indoor automation in Airbnb rentals, enabling hosts to make everyday devices smart and remotely manageable.
- Compact Size: Fits easily into any outlet without blocking adjacent sockets.
- Easy App Control: Schedule devices like coffee makers, fans, or lamps to create a welcoming environment for guests.
- Voice Assistant Integration: Compatible with Alexa, Google Assistant, and IFTTT for seamless smart home integration.
- Reliable Connectivity: Operates on 2.4GHz WiFi for stable performance.
- Safe and Certified: ETL certified with a 1-year warranty for peace of mind.
- Operating Temperature: Suitable for typical indoor environments (-4°F to 104°F).
This plug helps Airbnb hosts automate guest room appliances, improve energy efficiency, and offer a modern stay experience.
Control indoor devices remotely for guest convenience.
Battery-Powered Video Doorbell Alternative: Wyze Cam Floodlight Solutions
While Wyze does not offer a dedicated battery-powered video doorbell, their
Wyze Cam Floodlight series combined with plug-in mounts offers a powerful, easy-to-install security lighting and camera solution ideal for Airbnb properties.
Wyze Cam Floodlight Plug-In Mount: Simple Power Solution
- Plug-and-Play Installation: No need for complex junction box wiring or electricians.
- 20-Foot Durable Cable: Easily reach outdoor-rated outlets for flexible placement.
- Compatible with Wyze Floodlights: Supports all Wyze Cam Floodlight models for versatile security setups.
- Cable Management: Includes a velcro strap for neat installation.
This mount simplifies adding floodlight cameras to your Airbnb, enhancing security with bright lighting and video monitoring.
Wyze Cam Floodlight Pro + Plug-In Mount: Premium Security Bundle
- 2.5K QHD Video Resolution: Ultra-clear video with a 180° ultra-wide field of view.
- 3000 Lumens Brightness: Powerful floodlights illuminate large outdoor areas.
- Color Night Vision & Motion Alerts: Detects people, pets, vehicles, and packages with AI-powered alerts.
- Dual-Band WiFi: Supports both 2.4GHz and 5GHz for reliable connectivity.
- Weather Resistant (IP65): Built to withstand harsh outdoor conditions.
- Easy Mounting: Wall or ceiling installation with included plug-in mount.
This bundle is perfect for Airbnb hosts seeking top-tier outdoor security with minimal installation hassle.
Secure your Airbnb with bright floodlight cameras.
Why Choose These Wyze Products for Your Airbnb?
"Smart home devices like Wyze smart plugs and floodlight cameras provide Airbnb hosts with peace of mind, enhanced security, and guest convenience — all manageable remotely via a user-friendly app."
- Easy Installation: No professional help needed for plugs or floodlight mounts.
- Remote Control: Manage devices and monitor your property from anywhere.
- Energy Efficiency: Monitor and reduce power consumption.
- Guest-Friendly: Create a welcoming, safe environment with automated lighting and security.
- Affordable: High-quality smart home tech without breaking the bank.
Summary of Recommended Products
Product | Key Features | Ideal Use Case |
Wyze Plug Outdoor | Weatherproof, dual outlets, energy monitor | Outdoor lighting & appliances |
Wyze Plug | Compact, voice control, indoor use | Indoor device automation |
Wyze Cam Floodlight Pro + Mount | 2.5K video, 3000 lumens, AI detection | Outdoor security & lighting |
Wyze Cam Floodlight Plug-In Mount | Easy plug-in power for floodlights | Flexible floodlight installation |
By integrating these Wyze smart plugs and floodlight cameras, Airbnb hosts can effortlessly upgrade their property’s security and guest experience with reliable, easy-to-use smart home technology.
What are the best smart plug solutions for Airbnb hosts?
Wyze offers two excellent smart plug options for Airbnb hosts: the Wyze Plug Outdoor and the Wyze Plug. The Wyze Plug Outdoor is weather-resistant, features dual outlets with independent control, and is ideal for automating outdoor devices like garden lights and appliances. The Wyze Plug is a compact indoor smart plug that allows you to automate and remotely control indoor devices such as lamps, fans, and coffee makers, enhancing guest convenience and energy efficiency.How does the Wyze Plug Outdoor benefit Airbnb properties?
The Wyze Plug Outdoor is designed for outdoor use with an IP64 weatherproof rating, making it resistant to rain, dust, snow, and dirt. It features dual outlets with independent control, extended WiFi range up to 300 feet, energy monitoring, and voice assistant compatibility. This smart plug allows Airbnb hosts to remotely control outdoor lighting and appliances, improving both security and guest comfort.Can I control Wyze smart plugs remotely for my Airbnb rental?
Yes, both the Wyze Plug Outdoor and Wyze Plug can be controlled remotely through the Wyze app. This allows Airbnb hosts to manage devices, set schedules, and monitor energy usage from anywhere, providing flexibility and convenience for both hosts and guests.Are Wyze smart plugs compatible with voice assistants?
Yes, Wyze smart plugs are compatible with popular voice assistants such as Amazon Alexa and Google Assistant. The indoor Wyze Plug also supports IFTTT integration, making it easy to incorporate into your existing smart home ecosystem for hands-free control.What is the best alternative to a battery-powered video doorbell for Airbnb?
While Wyze does not offer a dedicated battery-powered video doorbell, the Wyze Cam Floodlight series with plug-in mounts provides a powerful alternative. These floodlight cameras offer bright lighting, high-resolution video, AI-powered motion alerts, and easy plug-and-play installation, making them ideal for enhancing security at Airbnb properties.How easy is it to install Wyze Cam Floodlight solutions at my Airbnb?
Wyze Cam Floodlight solutions are designed for easy installation. The plug-in mount allows for simple plug-and-play setup without the need for complex wiring or professional electricians. The included 20-foot cable and cable management accessories make it easy to position the floodlight camera for optimal coverage.What security features does the Wyze Cam Floodlight Pro offer for Airbnb hosts?
The Wyze Cam Floodlight Pro offers 2.5K QHD video resolution, a 180° ultra-wide field of view, 3000 lumens of brightness, color night vision, and AI-powered motion alerts for people, pets, vehicles, and packages. It also features dual-band WiFi support and weather resistance (IP65), making it a robust security solution for Airbnb properties.Why should Airbnb hosts choose Wyze smart home products?
Wyze smart home products are affordable, easy to install, and offer remote control via a user-friendly app. They help Airbnb hosts enhance property security, improve guest convenience, monitor and reduce energy consumption, and create a welcoming environment—all without the need for professional installation.Can Wyze smart plugs help improve energy efficiency in my Airbnb?
Yes, Wyze smart plugs, especially the Wyze Plug Outdoor, feature energy monitoring capabilities. Hosts can track energy consumption, set alerts, and schedule devices to optimize power usage, helping to reduce energy costs and promote sustainability in their Airbnb rental.Are Wyze smart plugs and floodlight cameras safe and reliable for Airbnb use?
Yes, Wyze smart plugs are ETL certified and come with a 1-year warranty, ensuring safety and reliability. Wyze Cam Floodlight solutions are weather-resistant and designed for outdoor use, providing dependable security and automation for Airbnb properties.
