Best Affordable Wired Doorbell Chimes for Indoor Sound Alerts
When it comes to enhancing your home security and convenience, having a reliable doorbell chime that provides clear indoor sound alerts is essential. Whether you prefer a simple wired setup or want to integrate smart features, there are excellent options available that fit various budgets and needs. Below, we explore the best affordable wired doorbell chimes and related accessories designed to keep you informed whenever someone is at your door.
Wyze Video Doorbell (Wired) with Chime
Compact and Clear HD Video Doorbell with Wired Chime
The Wyze Video Doorbell (Wired) offers a budget-friendly solution for those seeking a wired doorbell with indoor sound alerts. This doorbell features full HD 1080p video quality, ensuring you get a clear view of your front porch. It comes with a wired chime that plugs into a standard US power outlet, delivering a variety of chime sounds to suit your preference.
  • Video Quality: 1080p full HD with 8x digital zoom
  • Field of View: 120° vertical x 88° horizontal for broad coverage
  • Audio: Built-in speaker and microphone with two-way audio and noise cancellation
  • Chime Sounds: 5 modern, 4 classic, 3 animal, 6 automation, and 1 intruder alarm tone
  • Weather Resistance: IP65 rated for durability in outdoor conditions
  • Installation: Hardwired for consistent power and reliable chime alerts
  • Compatibility: Works seamlessly with the included wired chime; existing mechanical chimes will not function after installation
This wired doorbell and chime combo is perfect for homeowners who want a straightforward, dependable indoor sound alert system without breaking the bank.
Wyze Universal Wi-Fi Chime
Wireless Chime Compatible with All Wyze Doorbells and Cameras
For those who want a fuss-free chime solution without complicated wiring, the Wyze Universal Wi-Fi Chime is an excellent choice. This plug-in chime connects via Wi-Fi and works with all Wyze cameras and doorbells, including wired models.
  • Installation: Simple plug-in setup, no wiring needed
  • Tones: 17 different chime tones to customize your alert sound
  • Connectivity: Wi-Fi (2.4 GHz) and Bluetooth BLE 5.0 for reliable performance
  • Smart Features: Supports automations, such as chiming when a Wyze camera detects a person
  • Indoor Use: Designed specifically for indoor sound alerts
  • Compatibility: Works with Alexa, Google Assistant, and IFTTT for smart home integration
This chime is ideal if you want to add an indoor sound alert to your existing Wyze doorbell or camera system without the hassle of wiring.
Wyze Video Doorbell v2 with Chime Controller
Advanced Wired Doorbell with Enhanced Video and Sound Alerts
If you are looking for a more feature-rich wired doorbell with an indoor chime, the Wyze Video Doorbell v2 is a top contender. It offers superior 2K video resolution and comes bundled with a Wyze Chime Controller for indoor sound alerts.
  • Video Resolution: 2K (2048 x 1536) for crystal-clear video
  • Field of View: Ultra-wide 135° horizontal and 103° vertical coverage
  • Audio: Two-way audio with real-time alerts and motion-activated voice deterrence
  • Storage: Local microSD support up to 256GB plus optional cloud storage
  • Power: Wired with 16V-24V AC for stable operation
  • Chime Controller: Included for indoor sound alerts with multiple tone options
  • Weather Resistance: IP65 rated for all-weather durability
  • Smart Integrations: Compatible with Alexa, Google Assistant, and IFTTT
This wired doorbell and chime combo is perfect for those who want advanced security features alongside reliable indoor sound notifications. Homeowner answering door with video doorbell Alt text: Homeowner using a wired video doorbell with indoor chime alert
Standalone Wyze Chime for Wired Doorbell
Simple Indoor Chime for Wyze Wired Doorbell (v1)
If you already own a Wyze Video Doorbell (Wired) and need an additional or replacement indoor chime, the Wyze Chime accessory is a cost-effective option.
  • Compatibility: Works only with Wyze Video Doorbell (Wired) v1
  • Installation: Easy plug-in to standard US power outlet
  • Sound: Multiple chime tones for indoor alerts
  • Note: Not compatible with Wyze Video Doorbell Pro or v2 models
This standalone chime is a practical choice for expanding your wired doorbell system’s indoor sound coverage.
Why Choose Wired Doorbell Chimes for Indoor Alerts?
Wired doorbell chimes provide consistent power and reliable sound alerts without the need for frequent battery changes. They integrate seamlessly with your home’s electrical system, ensuring you never miss a visitor’s ring. Additionally, many wired doorbells now come with smart features like video, two-way audio, and customizable chimes, combining convenience with security.
Summary of Affordable Wired Doorbell Chimes
ProductPrice RangeKey FeatureIndoor Chime Type
Wyze Video Doorbell (Wired)$29.99+1080p HD video + wired chimeWired chime included
Wyze Universal Wi-Fi Chime$19.98Wireless, plug-in, 17 tonesWireless chime
Wyze Video Doorbell v2 + Chime$44.982K video + advanced chime controlWired chime controller
Wyze Standalone Chime$13.99Replacement chime for wired doorbell v1Wired chime only
Choosing the right wired doorbell chime depends on your preference for video quality, installation type, and smart home compatibility. The Wyze lineup offers affordable options that cover basic to advanced needs, ensuring you get clear indoor sound alerts every time your doorbell rings.
FeatureWyze Video Doorbell (Wired)Wyze Universal Wi-Fi ChimeWyze Video Doorbell v2Wyze Chime
TypeWired Video DoorbellWireless Wi-Fi ChimeWired Video Doorbell v2Wired Chime
Video Resolution1080p Full HD (1920x1080)N/A2K QHD (2048x1536)N/A
Field of View4:3 aspect ratio, head-to-toe viewN/A135° horizontal, 103° vertical, 166.8° diagonalN/A
Two-way AudioYesN/AYesN/A
Motion Detection & AlertsYes, with motion-activated LED and push notificationsCan chime on person detection via automationYes, with person detection and voice deterrenceN/A
StorageLocal microSD storage (up to 256GB)N/ALocal microSD storage (up to 256GB)N/A
Night VisionTraditional night visionN/A6 x 940nm IR lightsN/A
Weather ResistanceIP65N/AIP65N/A
PowerWired (16V-24V AC, ≥10VA)Plug-in (Wi-Fi powered)Wired (16V-24V AC, ≥10VA)Wired (compatible with Wyze Video Doorbell Wired)
CompatibilityWorks with Wyze Chime (sold separately)Works with all Wyze cameras and doorbellsWorks with Wyze Chime ControllerOnly works with Wyze Video Doorbell (Wired)
Chime Sounds19 different chime sounds (with Wyze Chime)Customizable via app automationsUses Wyze Chime Controller (sold separately)Single standalone chime
InstallationDIY, replaces existing wired doorbellPlug and play, no wiringDIY, replaces existing wired doorbellEasy wiring installation
Included ItemsDoorbell (and optional chime variant)Chime unitDoorbell v2 + Chime Controller + accessoriesStandalone chime unit
Price$29.99 (Doorbell Only), $34.99 (Doorbell + Chime)$19.98$44.98 (Doorbell + Chime Controller)$13.99
What are the benefits of using a wired doorbell chime for indoor sound alerts?Wired doorbell chimes provide consistent power and reliable indoor sound alerts without the need for frequent battery changes. They integrate seamlessly with your home’s electrical system, ensuring you never miss a visitor’s ring. Many modern wired doorbells also offer smart features like video, two-way audio, and customizable chimes for added convenience and security.
Which affordable wired doorbell chimes are available for indoor alerts?Affordable wired doorbell chimes for indoor alerts include the Wyze Video Doorbell (Wired) with Chime, Wyze Video Doorbell v2 with Chime Controller, and the Standalone Wyze Chime for Wired Doorbell v1. These options offer a range of features from HD and 2K video to multiple chime tones and easy installation.
What features does the Wyze Video Doorbell (Wired) with Chime offer?The Wyze Video Doorbell (Wired) with Chime features 1080p full HD video, a 120° vertical by 88° horizontal field of view, two-way audio with noise cancellation, and a wired chime with multiple sound options. It is IP65 weather-resistant and requires hardwired installation for consistent power and reliable indoor alerts.
Is the Wyze Universal Wi-Fi Chime compatible with all Wyze doorbells and cameras?Yes, the Wyze Universal Wi-Fi Chime is compatible with all Wyze doorbells and cameras, including both wired and wireless models. It connects via Wi-Fi and offers 17 different chime tones, making it a flexible solution for indoor sound alerts.
How do I install the Wyze Universal Wi-Fi Chime for indoor alerts?The Wyze Universal Wi-Fi Chime is easy to install—simply plug it into a standard US power outlet and connect it to your Wi-Fi network. No wiring is required, and it can be set up to work with Wyze doorbells and cameras for customizable indoor sound alerts.
What are the advantages of the Wyze Video Doorbell v2 with Chime Controller?The Wyze Video Doorbell v2 with Chime Controller offers 2K video resolution, ultra-wide field of view, two-way audio, motion-activated voice deterrence, and local microSD storage. It comes with a chime controller for reliable indoor sound alerts and supports smart home integrations with Alexa, Google Assistant, and IFTTT.
Can I use the Standalone Wyze Chime with any Wyze doorbell model?The Standalone Wyze Chime is only compatible with the Wyze Video Doorbell (Wired) v1. It is not compatible with the Wyze Video Doorbell Pro or v2 models. This accessory is ideal for those needing an additional or replacement chime for their existing Wyze wired doorbell v1.
Are Wyze doorbell chimes weather-resistant for outdoor use?Wyze doorbell units, such as the Wyze Video Doorbell (Wired) and Wyze Video Doorbell v2, are IP65 rated for weather resistance and can be installed outdoors. However, the chime accessories are designed for indoor use only and should be plugged into a standard indoor power outlet.
Do Wyze wired doorbell chimes support smart home integration?Yes, Wyze wired doorbell chimes and the Universal Wi-Fi Chime support smart home integration with Alexa, Google Assistant, and IFTTT, allowing you to customize alerts and automations for enhanced convenience.
How do I choose the best affordable wired doorbell chime for my home?To choose the best affordable wired doorbell chime, consider your preferences for video quality, installation type (wired or wireless), compatibility with existing systems, and smart home integration. Wyze offers a range of options from basic HD video doorbells to advanced 2K models with customizable chimes, ensuring reliable indoor sound alerts for every budget.
What are the key features of the Wyze Video Doorbell v2?Can you explain the installation process for the Wyze Video Doorbell (Wired)?Are there any ongoing sales or discounts for Wyze products?
