Affordable Cordless Vacuum with LED Screen & 20,000 Pa Suction
Affordable Cordless Vacuum with LED Screen and 20,000 Pa Suction
Looking for a high-performance cordless vacuum that combines powerful suction, smart features, and affordability? The Wyze Cordless Vacuum S is your perfect cleaning companion. Designed to deliver industrial-level suction power with a sleek, lightweight design, this vacuum makes home cleaning effortless and efficient.
Wyze Cordless Vacuum S: Powerful Cleaning Meets Smart Convenience
Experience the freedom of cordless cleaning with the Wyze Cordless Vacuum S, boasting an impressive 20,000 Pa suction power that tackles dirt, dust, and pet hair with ease. This vacuum is engineered with two powerful motors — one in the main body and another in the brush head — ensuring deep cleaning on all surfaces.
  • Suction Power: Choose from three cleaning speeds — Eco (6,000 Pa), Medium (9,000 Pa), and Turbo (20,000 Pa) — to match your cleaning needs.
  • LED Display: Monitor your vacuum’s speed and battery life clearly with a bright, easy-to-read LED screen.
  • Lightweight Design: Weighing just 2.8 pounds, it’s as light as a fluffy corgi puppy, making it easy to maneuver around furniture and up stairs.
  • Long Battery Life: Equipped with a 40-minute interchangeable lithium-ion battery, you can clean your entire home without interruption.
  • Illuminated Cleaning: Six daylight-bright LED lights on the brush head reveal hidden dust and debris under furniture and in dark corners.
  • Advanced Filtration: A 3-stage filtration system with a HEPA filter captures 95% of particles as small as 0.3 microns, perfect for allergy sufferers.
  • Easy Maintenance: The dust cup and filters are washable and easy to empty with just one finger.
“Finally! A vacuum that is free and independent and no longer reliant on its parents for financial and emotional support.” — Wyze
Wyze Cordless Vacuum S in use with pet on sofa Lightweight and pet-friendly cordless vacuum
Why Choose Wyze Cordless Vacuum S?
  • Industrial-Level Suction: The brushless digital motor reduces friction for longer life and consistent power.
  • Versatile Cleaning: Perfect for hardwood floors, carpets, and upholstery.
  • Smart LED Screen: Stay informed about your vacuum’s performance and battery status at a glance.
  • Pet Hair Specialist: Dual motors and LED lights make it ideal for homes with pets.
Lifestyle image of vacuuming hardwood floor Effortless cleaning on hardwood floors
Summary
If you want an affordable cordless vacuum with a bright LED screen and powerful 20,000 Pa suction, the Wyze Cordless Vacuum S stands out as the best choice. It combines smart technology, lightweight design, and strong suction power to keep your home spotless without breaking the bank.
Product Specifications at a Glance
FeatureSpecification
Suction PowerUp to 20,000 Pa (Turbo mode)
MotorsDual motors (main + brush head)
Battery Life40 minutes (interchangeable)
Weight2.8 lbs (lightweight)
LED DisplayYes (speed and battery info)
LED Lights on Brush Head6 daylight-bright LEDs
Filtration3-stage with HEPA filter
Price$139.99 (affordable)
Related Products (Not Cordless Vacuums)
While your query focuses on cordless vacuums, Wyze also offers a range of smart home security products such as the Wyze Cam v4 Outdoor Bundle and Wyze Cam v4, which provide advanced home monitoring solutions. These products feature high-resolution video, color night vision, and smart alerts, perfect for enhancing your home’s security.
What is the suction power of the Wyze Cordless Vacuum S?The Wyze Cordless Vacuum S offers up to 20,000 Pa of suction power in Turbo mode, making it highly effective at removing dirt, dust, and pet hair from all surfaces.
Does the Wyze Cordless Vacuum S have an LED display?Yes, the Wyze Cordless Vacuum S features a bright, easy-to-read LED screen that displays the vacuum’s speed and battery life for convenient monitoring.
How long does the battery last on the Wyze Cordless Vacuum S?The Wyze Cordless Vacuum S is equipped with a 40-minute interchangeable lithium-ion battery, allowing you to clean your entire home without interruption.
Is the Wyze Cordless Vacuum S lightweight and easy to use?Yes, the vacuum weighs just 2.8 pounds, making it lightweight and easy to maneuver around furniture, up stairs, and throughout your home.
What types of surfaces can the Wyze Cordless Vacuum S clean?The Wyze Cordless Vacuum S is designed for versatile cleaning and works effectively on hardwood floors, carpets, and upholstery.
Does the Wyze Cordless Vacuum S have features for cleaning pet hair?Absolutely. With dual motors and six daylight-bright LED lights on the brush head, the Wyze Cordless Vacuum S is ideal for homes with pets, making it easy to spot and remove pet hair.
What kind of filtration system does the Wyze Cordless Vacuum S use?The vacuum uses a 3-stage filtration system with a HEPA filter that captures 95% of particles as small as 0.3 microns, making it perfect for allergy sufferers.
Is the Wyze Cordless Vacuum S easy to maintain?Yes, the dust cup and filters are washable and can be emptied easily with just one finger, ensuring hassle-free maintenance.
How much does the Wyze Cordless Vacuum S cost?The Wyze Cordless Vacuum S is affordably priced at $139.99, offering powerful performance and smart features without breaking the bank.
What are the main features of the Wyze Cordless Vacuum S?Key features include up to 20,000 Pa suction power, dual motors, a 40-minute interchangeable battery, lightweight 2.8 lb design, LED display, six LED lights on the brush head, and a 3-stage HEPA filtration system.
What are the different cleaning speeds available for the Wyze Cordless Vacuum S?How long does the battery last on the Wyze Cordless Vacuum S?Do you have any deals, ongoing sales, discounts, or promotions for the Wyze Cordless Vacuum S?
