Refurbished High Suction Cordless LED Vacuum for Apartments
Refurbished High Suction Cordless LED Vacuum for Apartment & Under Furniture Cleaning
When it comes to keeping your apartment spotless, especially in those hard-to-reach spaces under furniture, a powerful yet lightweight cordless vacuum is essential. The Wyze Cordless Vacuum S stands out as a top choice for anyone seeking a refurbished high suction cordless vacuum equipped with LED lighting to illuminate dark corners and tight spaces.
Wyze Cordless Vacuum S: Powerful, Lightweight, and LED-Equipped
Exceptional Suction Power for Deep Cleaning
The Wyze Cordless Vacuum S delivers an impressive 20,000 Pa suction power in Turbo Mode, ensuring even the most embedded dust and debris are effortlessly removed. It offers multiple suction modes to balance power and battery life:
  • Turbo Mode: 20,000 Pa (10 minutes runtime)
  • Medium Mode: 9,000 Pa (23 minutes runtime)
  • ECO Mode: 6,000 Pa (40 minutes runtime)
This versatility makes it perfect for quick cleanups or thorough apartment-wide cleaning sessions.
Lightweight and Ergonomic Design
Weighing only 2.8 lbs for the main unit and 4.9 lbs when fully assembled, this vacuum is as light as a couple of feathers, making it easy to maneuver around furniture and carry up and down stairs without fatigue.
LED Lighting for Under Furniture Cleaning
Equipped with 6 daylight-bright LED lights on the brush head, the vacuum illuminates dark spaces under sofas, beds, and cabinets, helping you spot hidden dust and pet hair. This feature is a game-changer for apartment dwellers who want to maintain a pristine living environment.
Long-Lasting Battery and Quick Recharge
Powered by a 6-cell lithium-ion battery (2,000mAh*6), the vacuum offers up to 40 minutes of runtime in ECO mode. It fully charges in 4-6 hours via AC charging, so it’s ready when you need it.
Advanced Filtration and Attachments
The vacuum includes a 3-stage filtration system with a HEPA filter, capturing fine dust and allergens to improve indoor air quality. It comes with multiple attachments such as:
  • Crevice Tool for tight corners
  • Floor Brush for hard floors and carpets
  • Dust Cap and Filter Housing for easy maintenance
Dimensions and Noise Level
  • Main unit size: 12.4 x 4.5 x 8.7 inches
  • Assembled length: 41.1 inches
  • Noise level: 65 dBA in Turbo Mode, quiet enough for apartment living
Experience the freedom of cordless cleaning with the Wyze Cordless Vacuum S — powerful, lightweight, and smartly designed for every nook and cranny of your home.
Lifestyle vacuuming with pet-friendly cordless vacuum Cordless vacuuming made easy in apartments with pets
Why Choose a Refurbished Wyze Cordless Vacuum?
Refurbished units offer the same high-quality performance as new models but at a more affordable price point. Each Wyze Cordless Vacuum S is carefully inspected and tested to ensure it meets strict standards, giving you peace of mind and excellent value.
Additional Smart Home Cleaning Solutions
While the Wyze Cordless Vacuum S is the perfect tool for apartment and under-furniture cleaning, Wyze also offers a range of smart home devices to complement your lifestyle, including security cameras and bundles. These products help you maintain a clean, safe, and connected home environment. Wyze Plug-in Cam mounted outdoor Smart home security complements your clean living space
Summary of Wyze Cordless Vacuum S Specifications
FeatureSpecification
Suction Power20,000 Pa (Turbo), 9,000 Pa (Medium), 6,000 Pa (ECO)
Weight2.8 lbs (main), 4.9 lbs (assembled)
Battery6-cell lithium-ion, 2,000mAh*6
RuntimeUp to 40 minutes (ECO mode)
Charging Time4-6 hours
Dust Cup Volume0.7 L
Noise Level65 dBA (Turbo)
LED Lights6 daylight-bright LEDs on brush head
Filtration3-stage with HEPA filter
Dimensions12.4 x 4.5 x 8.7 in (main unit)
ColorSteel grey with Wyze green accents
Conclusion
For apartment dwellers and anyone needing a cordless vacuum that excels at cleaning under furniture, the Wyze Cordless Vacuum S is a refurbished powerhouse. Its high suction, LED lighting, lightweight design, and long battery life make it an ideal choice for maintaining a spotless home with ease.
What makes the Wyze Cordless Vacuum S ideal for apartment and under furniture cleaning?The Wyze Cordless Vacuum S is designed for apartment living with its lightweight build (only 2.8 lbs for the main unit), powerful suction (up to 20,000 Pa in Turbo Mode), and 6 daylight-bright LED lights on the brush head. These features make it easy to maneuver and effective at cleaning hard-to-reach spaces under furniture.
How powerful is the suction on the Wyze Cordless Vacuum S?The Wyze Cordless Vacuum S offers exceptional suction power with three modes: Turbo Mode at 20,000 Pa, Medium Mode at 9,000 Pa, and ECO Mode at 6,000 Pa. This ensures deep cleaning for embedded dust and debris on various surfaces.
How long does the battery last on a single charge?The Wyze Cordless Vacuum S provides up to 40 minutes of runtime in ECO mode, 23 minutes in Medium mode, and 10 minutes in Turbo mode. The 6-cell lithium-ion battery fully recharges in 4-6 hours.
Does the Wyze Cordless Vacuum S have LED lights for cleaning dark areas?Yes, the vacuum is equipped with 6 daylight-bright LED lights on the brush head, making it easy to see and clean dust and debris under sofas, beds, and other furniture.
What filtration system does the Wyze Cordless Vacuum S use?The vacuum features a 3-stage filtration system with a HEPA filter, which captures fine dust and allergens to improve indoor air quality.
What attachments are included with the Wyze Cordless Vacuum S?The vacuum comes with multiple attachments, including a Crevice Tool for tight corners, a Floor Brush for hard floors and carpets, and a Dust Cap and Filter Housing for easy maintenance.
How noisy is the Wyze Cordless Vacuum S during operation?The Wyze Cordless Vacuum S operates at a noise level of 65 dBA in Turbo Mode, making it quiet enough for apartment living.
What are the dimensions and weight of the Wyze Cordless Vacuum S?The main unit measures 12.4 x 4.5 x 8.7 inches and weighs 2.8 lbs. When fully assembled, it weighs 4.9 lbs and has an assembled length of 41.1 inches.
Why should I choose a refurbished Wyze Cordless Vacuum S?Refurbished Wyze Cordless Vacuum S units offer the same high-quality performance as new models at a more affordable price. Each unit is carefully inspected and tested to meet strict standards, ensuring reliability and value.
What is the dust cup volume of the Wyze Cordless Vacuum S?The Wyze Cordless Vacuum S has a dust cup volume of 0.7 liters, allowing for efficient cleaning sessions without frequent emptying.
Are there other smart home cleaning solutions available from Wyze?Yes, Wyze offers a range of smart home devices, including security cameras and bundles, to help you maintain a clean, safe, and connected home environment.
What are the different suction modes available for the Wyze Cordless Vacuum S?How long does it take to fully charge the Wyze Cordless Vacuum S?Is there a warranty available for the Wyze Cordless Vacuum S?
