Affordable 128GB MicroSD Card Compatible with Wyze Security Cameras
When it comes to enhancing your Wyze security camera system, having a reliable and affordable 128GB microSD card is essential. The
Wyze MicroSD Card is specifically designed to unlock continuous local recording and time lapse features for Wyze Cams, making it the perfect companion for your home security setup. This page highlights the best options for 128GB microSD cards compatible with Wyze devices, focusing on affordability, compatibility, and performance.
Wyze MicroSD Card: Perfect Storage for Wyze Cameras
Reliable and Affordable Storage Solution
The
Wyze MicroSD Card offers a 128GB microSDXC variant priced at just $16.99, making it an affordable choice for users who want ample storage without breaking the bank. This card is optimized for Wyze cameras, ensuring smooth continuous recording and easy access to your footage.
Key Features:
- Capacity: 128GB microSDXC, ideal for storing hours of HD video.
- Compatibility: Designed for Wyze Cams with built-in microSD slots.
- Performance: Class 10, UHS-1 (U1) speed class for reliable video recording.
- No Subscription Needed: Local recording means no monthly fees.
- Easy Playback: Access footage via the Wyze app or by removing the card to view on your computer.
- Additional Sizes: Also available in 32GB and 256GB variants for flexible storage needs.
Unlock continuous recording and time lapses for Wyze Cams with this memory card.
Wyze Cam v4 + FREE 32GB MicroSD Card: Advanced Security with Included Storage
Enhanced Security Camera with Included MicroSD Card
For those looking to upgrade their security system, the
Wyze Cam v4 bundle includes a free 32GB microSD card, providing immediate local storage out of the box. While the included card is 32GB, the camera supports microSD cards up to 128GB and beyond, allowing you to upgrade to the affordable 128GB Wyze MicroSD Card for extended recording.
Highlights of Wyze Cam v4:
- Resolution: Crystal-clear 2.5K QHD video for detailed footage.
- Color Night Vision: Enhanced hardware captures vibrant colors even in low light.
- Motion-Activated Spotlight: Adds an extra layer of security by illuminating detected motion.
- Wi-Fi 6 Support: Stronger, more reliable connection for seamless streaming.
- Smart Home Integration: Compatible with Alexa and Google Assistant.
- 24/7 Local Recording: Supports continuous recording with microSD cards.
The clearest Wyze Cam ever made with advanced local recording.
Wyze Video Doorbell v2: Crisp 2K Video with Local MicroSD Storage
Smart Doorbell with Local Storage Capability
The
Wyze Video Doorbell v2 is a wired video doorbell that supports local microSD storage up to 256GB, including the affordable 128GB Wyze MicroSD Card. This makes it an excellent choice for users who want detailed video recordings stored locally without relying solely on cloud subscriptions.
Features:
- Video Quality: 2K (2048 x 1536) resolution for sharp, clear video.
- Field of View: Wide 166.8° diagonal for comprehensive coverage.
- Two-Way Audio: Communicate with visitors in real-time.
- Motion-Activated Voice Deterrence: Warn unwanted guests with a recorded message.
- Weather Resistant: IP65 rating ensures durability in various climates.
- Local Storage: Supports microSD cards up to 256GB for continuous recording.
Answer your door from anywhere with detailed local video storage.
Why Choose Wyze MicroSD Cards for Your Wyze Security Devices?
Using the official
Wyze MicroSD Card ensures optimal compatibility and performance with your Wyze security cameras and doorbells. The 128GB size strikes a perfect balance between storage capacity and affordability, allowing you to keep days of footage locally without monthly fees.
Benefits:
- Seamless Integration: Designed specifically for Wyze devices.
- Cost-Effective: Competitive pricing for high-capacity storage.
- Easy Setup: Simply insert the card and configure recording settings in the Wyze app.
- Reliable Performance: Class 10 speed ensures smooth video capture without lag or corruption.
Summary
For affordable, high-capacity storage compatible with Wyze security cameras, the
Wyze MicroSD Card 128GB is the top choice. Whether you are using the Wyze Cam v4, Wyze Video Doorbell v2, or other Wyze devices, this microSD card unlocks continuous local recording and advanced camera features without the need for costly subscriptions.
Invest in the Wyze MicroSD Card 128GB today to enhance your home security system with reliable, affordable storage tailored for Wyze products.
Is the 128GB Wyze MicroSD Card compatible with all Wyze security cameras?
Yes, the 128GB Wyze MicroSD Card is designed for compatibility with all Wyze security cameras that have a built-in microSD slot, including the Wyze Cam v4 and Wyze Video Doorbell v2.What are the benefits of using a Wyze MicroSD Card with my Wyze camera?
Using a Wyze MicroSD Card enables continuous local recording, time lapse features, and easy playback of footage without the need for a monthly subscription. It also ensures optimal compatibility and reliable performance with Wyze devices.How much video can a 128GB microSD card store on a Wyze camera?
A 128GB microSD card can store hours of HD video, allowing for several days of continuous recording depending on camera settings and video quality.Do I need a subscription to use local recording with a Wyze MicroSD Card?
No, you do not need a subscription. Local recording with a Wyze MicroSD Card is completely free and does not require any monthly fees.What speed class is the Wyze MicroSD Card?
The Wyze MicroSD Card is a Class 10, UHS-1 (U1) card, which ensures reliable and smooth video recording for your Wyze security cameras.Can I use a 128GB microSD card with the Wyze Video Doorbell v2?
Yes, the Wyze Video Doorbell v2 supports microSD cards up to 256GB, including the affordable 128GB Wyze MicroSD Card for local video storage.How do I access footage stored on my Wyze MicroSD Card?
You can access your footage directly through the Wyze app or by removing the microSD card from your camera and viewing it on your computer.Is the Wyze MicroSD Card available in other sizes?
Yes, the Wyze MicroSD Card is also available in 32GB and 256GB variants, providing flexible storage options for different needs.What is the price of the 128GB Wyze MicroSD Card?
The 128GB Wyze MicroSD Card is affordably priced at $16.99, making it a cost-effective solution for expanding your Wyze camera storage.Why should I choose the official Wyze MicroSD Card over other brands?
The official Wyze MicroSD Card is specifically optimized for Wyze devices, ensuring seamless integration, reliable performance, and easy setup for continuous local recording.
