Wyze Video Doorbell Chime Compatibility: Using v1 Chime with v2 Model
For those interested in the compatibility of Wyze Video Doorbell v2 with chimes, it's important to note that the Wyze Video Doorbell v2 is compatible with nearly every mechanical chime, even broken ones, as long as the power input is between 16-24V AC. However, the standalone Wyze Chime is not compatible with the Wyze Video Doorbell v2. It is specifically designed to work only with the Wyze Video Doorbell (Wired). Here are some key features of the Wyze Video Doorbell v2:
  • 2K Video Resolution: Provides clear and detailed video quality.
  • Local microSD Storage: Capture every moment with local storage options.
  • Two-Way Audio: Communicate in real-time with visitors at your door.
  • Motion-Activated Voice Deterrence: Helps deter unwanted visitors.
  • Weather Resistance: Rated IP65, suitable for various weather conditions.
For those using the Wyze Video Doorbell (Wired), the standalone Wyze Chime offers:
  • Audio Coverage: Up to 90+ dB, suitable for approximately 1,000 sq ft.
  • Volume Levels: 8 adjustable levels to suit your preference.
  • Tunes Available: 19 different chime tunes to choose from.
If you have any further questions or need assistance, feel free to reach out!
FeatureWyze Video Doorbell v2Wyze Chime
CompatibilityWorks with most in-house mechanical chimesOnly works with Wyze Video Doorbell (Wired)
Video Resolution2K (2048 x 1536)N/A
AudioTwo-way audioUp to 90+ dB audio coverage
StorageLocal microSD storage up to 256GBN/A
Weather ResistanceIP65N/A
Motion-Activated Voice DeterrenceYes, with Cam Plus or Cam Protect subscriptionN/A
Chime ControllerIncluded, works with existing in-house chimeStandalone, not compatible with v2
Volume LevelsN/A8 adjustable levels
Tunes AvailableN/A19 different chime tunes
Power Requirements16V-24V AC, ≥10VAStandard US Power Outlet: 100V-240V, 0.1A, 50/60Hz
What are the key features of the Wyze Video Doorbell v2?Can the Wyze Video Doorbell v2 be used with a wireless chime?Do you have any deals, ongoing sales, discounts, or promotions?
Need help finding the perfect Wyze Cam? Check out our   Product Finder ✨
Shop with AI powered by Big Sur AI
