Wyze SL C Kit: Advanced 2.5K Home Security Camera Bundle
Wyze SL C Kit: Advanced Home Security Solutions
If you're searching for the Wyze SL C Kit, you're likely interested in Wyze's cutting-edge security camera technology and comprehensive home security bundles. Wyze offers a range of products designed to keep your home safe with crystal-clear video, smart features, and easy installation. Below, we explore the key Wyze products relevant to your query, focusing on the Wyze Cam v4 and the Wyze Cam v4 Home Security Bundle, which together form the core of the SL C Kit offerings.
Wyze Cam v4: The Heart of the SL C Kit
The Wyze Cam v4 is a versatile, high-performance security camera that delivers exceptional video quality and smart home integration.
Key Features and Specifications
  • Video Quality: Stunning 2.5K QHD (2560x1440) resolution ensures crystal-clear footage.
  • Field of View: Wide-angle lens with 115.8° diagonal, 98.5° horizontal, and 53.1° vertical field of view captures more of your surroundings.
  • Sensor: Equipped with a CMOS Starlight Sensor for enhanced low-light performance.
  • Night Vision: Features 4 IR LEDs (850 nm) plus 2 white spotlight LEDs (72 lumens) for color night vision.
  • Audio: 99dB waterproof speaker with simultaneous two-way talk and built-in siren for alerts.
  • Connectivity: Supports Wi-Fi 6 and Bluetooth 5.2 for fast, reliable connections.
  • Mounting Options: Flexible installation with stand, wall mount, ceiling mount, and magnetic wall mount (adhesive).
  • Weather Resistance: Rated IP65, suitable for both indoor and outdoor use.
  • Storage: Supports microSD cards up to 512GB for local storage, plus optional cloud storage with subscription.
  • Compatibility: Works seamlessly with Android 9.0+ and iOS 15.0+, and integrates with Alexa, Google Assistant, and IFTTT.
  • Dimensions & Weight: Compact 2in x 2in x 2 3/8in size, weighing just 0.49 lb (222 g).
What’s Included
  • Wyze Cam v4 camera
  • Quick Start Guide
  • Wall Mount Plate and Tape
  • Screw Kit
  • Indoor USB Power Adapter
  • 6-Foot Flat micro USB to USB-A cable
The Wyze Cam v4 is designed to provide reliable, high-quality home monitoring with smart features that adapt to your lifestyle.
Wyze Cam v4 in outdoor home setting Wyze Cam v4 providing outdoor security with night vision
Wyze Cam v4 Home Security Bundle: Complete Protection
For those looking for an all-in-one solution, the Wyze Cam v4 Home Security Bundle offers everything you need to secure your home with enhanced features and convenience.
Bundle Highlights
  • Includes: Multiple Wyze Cam v4 cameras bundled for comprehensive coverage.
  • Video Resolution: 2.5K QHD for sharp, detailed video.
  • Color Night Vision: Enhanced color night vision with motion-activated spotlight.
  • Person Detection: Smart AI detects people to reduce false alerts.
  • Audio Quality: Improved two-way audio for clear communication.
  • Storage: Comes with 128GB microSD card (Class 10, UHS-3) for extensive local recording.
  • Connectivity: Supports Wi-Fi 6 for faster, more stable connections.
  • Weatherproof: IP65 rating for indoor and outdoor use.
  • Mounting: Same versatile mounting options as the single camera.
  • Video Frame Rate: 20 FPS daytime, 15 FPS nighttime for smooth video.
  • Warranty: 1-year warranty included.
Why Choose the Bundle?
This bundle is perfect for users who want multiple cameras with advanced features like person detection and motion-activated spotlights, ensuring your home is monitored day and night with minimal false alarms. Wyze Cam v4 Home Security Bundle lifestyle Wyze cameras mounted outdoors for comprehensive home security
Why the Wyze SL C Kit Stands Out
Wyze’s SL C Kit, centered around the Wyze Cam v4 and its bundled options, offers:
  • Exceptional Video Quality: 2.5K QHD resolution surpasses many competitors.
  • Smart Features: Person detection, two-way talk, and built-in siren enhance security.
  • Flexible Installation: Multiple mounting options for any home setup.
  • Robust Night Vision: Color night vision with spotlight LEDs for clear nighttime monitoring.
  • Reliable Connectivity: Wi-Fi 6 and Bluetooth 5.2 ensure smooth operation.
  • Weather Resistance: IP65 rating for dependable outdoor use.
  • Expandable Storage: Supports large microSD cards and cloud options.
  • Smart Home Integration: Compatible with Alexa, Google Assistant, and IFTTT for voice control and automation.
Whether you want a single camera or a full security bundle, the Wyze SL C Kit provides a reliable, feature-rich solution to protect your home.
Summary
The Wyze SL C Kit is built around the powerful Wyze Cam v4 and its Home Security Bundle, offering:
  • High-resolution 2.5K QHD video
  • Advanced night vision with color spotlight
  • Smart person detection and two-way audio
  • Multiple mounting options and weatherproof design
  • Seamless integration with popular smart home platforms
Invest in the Wyze SL C Kit for peace of mind and comprehensive home security that fits your lifestyle and budget.
FeatureWyze Cam v4Wyze Cam v4 Home Security Bundle
Price$100.00$169.99 (Compare at $211.88)
Quantity1 camera4 cameras + 4x 128GB Wyze MicroSD Cards
Video Resolution2.5K QHD (2560x1440)2.5K QHD (2560x1440)
Night VisionEnhanced Color Night VisionEnhanced Color Night Vision
SpotlightMotion-activated spotlightMotion-activated spotlight
Two-Way TalkEnhanced two-way talkImproved 2-way audio quality
SirenYes (99 dB)Yes
Local RecordingMicroSD card support up to 512GBMicroSD card support (128GB cards included)
Wi-Fi SupportWi-Fi 6Wi-Fi 6
Motion & Sound DetectionYesYes
Motion Detection ZonesYesYes
Smoke & CO AlertsYesYes
Power SourceWiredWired
Weather ResistanceIP65IP65
CompatibilityAlexa, Google Assistant, IFTTTAlexa, Google Assistant
Additional FeaturesAuto-zoom with AI, Wide Dynamic Range (WDR)Wide Dynamic Range (WDR)
Return Policy30-day hassle-free returns30-day hassle-free returns
What is the Wyze SL C Kit?The Wyze SL C Kit is a comprehensive home security solution centered around the Wyze Cam v4 and its Home Security Bundle. It offers advanced features like 2.5K QHD video resolution, color night vision, person detection, two-way audio, and flexible installation options for both indoor and outdoor use.
What are the key features of the Wyze Cam v4?The Wyze Cam v4 features 2.5K QHD (2560x1440) video resolution, a wide-angle lens, CMOS Starlight Sensor for enhanced low-light performance, color night vision with IR and spotlight LEDs, two-way audio with a built-in siren, Wi-Fi 6 and Bluetooth 5.2 connectivity, IP65 weather resistance, and support for microSD cards up to 512GB.
What is included in the Wyze Cam v4 Home Security Bundle?The Wyze Cam v4 Home Security Bundle includes multiple Wyze Cam v4 cameras, a 128GB microSD card (Class 10, UHS-3), mounting hardware, and a 1-year warranty. The bundle is designed for comprehensive home coverage and includes all necessary accessories for installation.
Does the Wyze Cam v4 support night vision?Yes, the Wyze Cam v4 supports advanced night vision with 4 IR LEDs and 2 white spotlight LEDs, providing color night vision for clear footage even in low-light conditions.
Is the Wyze Cam v4 weatherproof?Yes, the Wyze Cam v4 is rated IP65, making it suitable for both indoor and outdoor use in various weather conditions.
What storage options are available for the Wyze Cam v4?The Wyze Cam v4 supports local storage with microSD cards up to 512GB and offers optional cloud storage through a subscription service.
Does the Wyze Cam v4 work with smart home platforms?Yes, the Wyze Cam v4 is compatible with Alexa, Google Assistant, and IFTTT, allowing for seamless smart home integration and voice control.
What are the mounting options for the Wyze Cam v4?The Wyze Cam v4 offers flexible mounting options, including stand, wall mount, ceiling mount, and magnetic wall mount with adhesive, making it easy to install in various locations.
What makes the Wyze Cam v4 Home Security Bundle a good choice?The Wyze Cam v4 Home Security Bundle is ideal for users seeking multiple cameras with advanced features like person detection, motion-activated spotlights, and extensive local storage. It provides comprehensive home coverage and minimizes false alarms.
What is the warranty on the Wyze Cam v4 Home Security Bundle?The Wyze Cam v4 Home Security Bundle comes with a 1-year warranty, ensuring peace of mind and reliable support.
Can you tell me more about the features of the Wyze Cam v4?What is included in the Wyze Cam v4 Home Security Bundle?Do you have any ongoing sales or discounts for the Wyze SL C Kit?
