Wyze Sense Hub & Motion Sensor for Comprehensive Home Monitoring
When it comes to securing your home with smart technology, the
Wyze Sense Hub combined with the
Wyze Sense Motion Sensor offers a powerful and reliable solution. Designed to provide comprehensive home monitoring, these devices work seamlessly together to keep you informed and in control of your home’s security.
Wyze Sense Hub: The Brain of Your Home Monitoring System
The
Wyze Sense Hub is the central unit that connects all your Wyze Sense sensors and sends real-time alerts to your smartphone. It acts as the "brains behind the brawn," ensuring your home monitoring system operates smoothly and efficiently.
Key Features:
- Connectivity: Supports Ethernet, WiFi (2.4 GHz), Bluetooth 4.1+ BLE 5.1, and 915MHz RF communication for robust and flexible connections.
- Sensor Capacity: Can support up to 100 sensors, allowing you to expand your system as needed.
- Siren Alarm: Built-in 88db siren at 2 feet to alert you instantly of any security breach.
- Battery Backup: Comes with a built-in rechargeable 3.7V, 2600mAh battery providing up to 10 hours of backup power.
- Compact Design: Matte white base with a grey speaker top, measuring 4.5” x 4” x 1” (114.3 x 101.6 x 25.4 mm), perfect for indoor use.
- Included Accessories: Power adapter, Ethernet cable, window decals, and quick start guide for easy setup.
The Wyze Sense Hub is your home's command center, ensuring all sensors communicate effectively and alerts reach you without delay.
Enhance your home security with Wyze smart devices integrated seamlessly.
Wyze Sense Motion Sensor: Detect Movement with Precision
The
Wyze Sense Motion Sensor is designed to detect motion within a 25-foot range and a 120° field of view, making it ideal for monitoring entryways, hallways, or any room where movement detection is critical.
Highlights:
- Detection Range: Up to 25 feet with a wide 120° field of view.
- Adjustable Sensitivity: Customize sensitivity settings to reduce false alarms.
- Installation: Easy to install with adhesive backing or screws for added security.
- Battery Life: Long-lasting battery life of up to 18 months, minimizing maintenance.
- Compatibility: Works exclusively with Wyze Sense Hub v2 or Wyze Home Monitoring systems.
- Indoor Use: Designed specifically for indoor environments.
With the Wyze Sense Motion Sensor, you can monitor movement in your home effortlessly, receiving instant notifications when motion is detected.
Additional Wyze Sense Sensors for a Complete Monitoring Setup
To complement the Wyze Sense Hub and Motion Sensor, consider adding these sensors for a more comprehensive home security system:
Wyze Sense Entry Sensor & Entry Sensor v2
- Detects when doors or windows open or close.
- Requires the Wyze Sense Hub for operation.
- Available in multiple pack sizes (1, 2, or 3 packs).
- Entry Sensor v2 offers updated compatibility with Wyze Sense Hub v2 and Wyze Home Monitoring.
Wyze Sense Keypad
- Allows you to arm and disarm your home security system remotely.
- Features an emergency button for quick access to first responders.
- Requires Wyze Home Monitoring and Wyze Sense Hub.
- Compact and easy to mount indoors.
These sensors work in unison with the Wyze Sense Hub and Motion Sensor to provide a layered security approach, ensuring every entry point and movement is monitored.
Control your home security system remotely with the Wyze Sense Keypad.
Why Choose Wyze Sense for Your Home Monitoring?
- Scalable System: Supports up to 100 sensors, allowing you to customize your security setup.
- Reliable Communication: Multiple communication methods ensure consistent connectivity.
- User-Friendly: Easy installation with adhesive or screws and intuitive app integration.
- Long Battery Life: Sensors designed to last months or years on a single battery.
- Indoor Focused: Designed specifically for indoor use, perfect for homes, apartments, and RVs.
Wyze Sense Hub and its sensors provide peace of mind by keeping your home safe, connected, and smart.
Summary
For anyone looking to build a comprehensive home monitoring system, the
Wyze Sense Hub paired with the
Wyze Sense Motion Sensor is an excellent choice. Together with additional sensors like entry sensors and the keypad, you can create a smart, responsive, and scalable security network tailored to your home’s needs.
What is the Wyze Sense Hub and how does it work?
The Wyze Sense Hub is the central unit of the Wyze home monitoring system. It connects all Wyze Sense sensors and sends real-time alerts to your smartphone, ensuring your home security system operates smoothly and efficiently. The hub supports up to 100 sensors and features robust connectivity options, a built-in siren, and battery backup.What are the key features of the Wyze Sense Hub?
Key features of the Wyze Sense Hub include support for Ethernet, WiFi (2.4 GHz), Bluetooth 4.1+ BLE 5.1, and 915MHz RF communication, capacity for up to 100 sensors, an 88db siren, a rechargeable battery with up to 10 hours of backup, and a compact design suitable for indoor use.How does the Wyze Sense Motion Sensor enhance home security?
The Wyze Sense Motion Sensor detects movement within a 25-foot range and a 120° field of view, making it ideal for monitoring entryways, hallways, or rooms. It sends instant notifications to your phone when motion is detected, helping you stay informed about activity in your home.What is the detection range and field of view of the Wyze Sense Motion Sensor?
The Wyze Sense Motion Sensor has a detection range of up to 25 feet and a wide 120° field of view, allowing it to monitor large areas effectively.Can I adjust the sensitivity of the Wyze Sense Motion Sensor?
Yes, the Wyze Sense Motion Sensor features adjustable sensitivity settings, allowing you to customize it to reduce false alarms and tailor it to your specific needs.What is the battery life of Wyze Sense sensors?
The Wyze Sense Motion Sensor offers a long-lasting battery life of up to 18 months, minimizing the need for frequent maintenance. The Wyze Sense Hub also includes a rechargeable battery that provides up to 10 hours of backup power.Are Wyze Sense devices easy to install?
Yes, Wyze Sense devices are designed for easy installation. The sensors can be mounted using adhesive backing or screws, and the system comes with a quick start guide and necessary accessories for a hassle-free setup.What additional sensors can I use with the Wyze Sense Hub?
You can expand your system with Wyze Sense Entry Sensors (including Entry Sensor v2) to monitor doors and windows, and the Wyze Sense Keypad for arming and disarming your system. All these devices work together with the Wyze Sense Hub for comprehensive home monitoring.Is the Wyze Sense system suitable for indoor use?
Yes, the Wyze Sense Hub, Motion Sensor, Entry Sensors, and Keypad are all designed specifically for indoor environments, making them ideal for homes, apartments, and RVs.How many sensors can the Wyze Sense Hub support?
The Wyze Sense Hub can support up to 100 sensors, allowing you to scale and customize your home security system as needed.What is required for the Wyze Sense Motion Sensor to work?
The Wyze Sense Motion Sensor requires the Wyze Sense Hub v2 or Wyze Home Monitoring system for operation. It is not compatible as a standalone device.What are the benefits of using Wyze Sense for home monitoring?
Wyze Sense offers a scalable and reliable home monitoring solution with easy installation, long battery life, robust connectivity, and seamless integration with the Wyze app. It provides peace of mind by keeping your home safe, connected, and smart.
