The Wyze Sense Hub is a central component of our home monitoring system, designed to connect and manage various sensors to keep your home secure. Here's how it works with different sensors:
- Wyze Sense Entry Sensor: This sensor detects when doors or windows open or close. It requires the Wyze Sense Hub for operation and is compatible with Wyze Sense v2 or Wyze Home Monitoring. It supports up to 100 sensors per hub and has a detection range of up to 500 feet.
- Wyze Sense Motion Sensor: This sensor detects motion within a 25-foot range and a 120-degree field of view. It also requires the Wyze Sense Hub and is designed to detect people, not pets. It supports up to 100 sensors per hub.
- Wyze Sense Leak Sensor & Probe: This sensor alerts you to leaks and requires the Wyze Sense Hub. It can differentiate between the leak sensor and the probe, providing detailed notifications. It is compatible with Wyze Sense v2 or Wyze Home Monitoring.
- Wyze Sense Climate Sensor: This sensor tracks temperature and humidity in your home and requires the Wyze Sense Hub to function. It has a 500-foot range, making it suitable for various locations within your home.
These sensors, when paired with the Wyze Sense Hub, provide a comprehensive home monitoring solution, ensuring you receive timely alerts and can manage your home security effectively.
What types of sensors can I connect to the Wyze Sense Hub?How far can the Wyze Sense sensors detect motion?Do you have any deals, ongoing sales, discounts, or promotions for the Wyze Sense Hub?
