Wyze Sense Hub Battery Life: Everything You Need to Know
The Wyze Sense Hub is equipped with a built-in rechargeable battery that provides a backup life of up to 10 hours. This ensures that your home monitoring system remains operational even during power outages. The battery is composed of a single 18650 cell with a capacity of 2600 mAh, operating at 3.7 volts. This robust battery setup allows the Wyze Sense Hub to maintain connectivity and continue sending alerts to keep your home secure.
What features does the Wyze Sense Hub offer for home monitoring?How does the Wyze Sense Hub maintain connectivity during a power outage?Can the Wyze Sense Hub be used with other Wyze products?
Need help finding the perfect Wyze Cam? Check out our   Product Finder ✨
Shop with AI powered by Big Sur AI
