Enhance Your Home Surveillance with Wyze Security Yard Sign and More
When it comes to protecting your home, visibility and deterrence are key. The
Wyze Security Yard Sign is a simple yet powerful accessory designed to enhance your home surveillance by warning potential intruders that your property is monitored. Paired with Wyze’s advanced security cameras and smart home bundles, you can create a comprehensive security system that keeps your home safe and secure.
Wyze Security Yard Sign: Stylish Crime Deterrence
Tough, Durable, and Highly Visible
The Wyze Security Yard Sign is crafted from tough aluminum, making it weatherproof and fade-resistant to withstand all outdoor conditions. Its bright blue color and highly visible reflective surface ensure it catches the eye of anyone approaching your property, effectively deterring crime without being an eyesore.
- Material: Aluminum
- Color: Blue
- Dimensions: Combined length 30", shield and metal support pole 12" W x 16" L, metal pole 14" L
Features:
- Easy to see and install
- Extremely durable and weatherproof
- Reflective surface for enhanced visibility at night
- Complements your Wyze camera setup perfectly
What’s in the Box?
- 1 Wyze yard sign
- 1 Aluminum stake
- 1 Installation kit
Stand tall, stay safe! The Wyze Security Yard Sign is your first line of defense, making your home a less attractive target for intruders.
Enhance your outdoor security with visible deterrents
Wyze Cam v4 Home Security Bundle: Crystal Clear Surveillance
Advanced Camera Features for Day and Night Protection
The Wyze Cam v4 offers unmatched home security with its 2.5K QHD resolution and enhanced color night vision. This camera is designed for both indoor and outdoor use, featuring weather resistance (IP65) and a motion-activated spotlight to illuminate suspicious activity.
- Video Resolution: 2.5K QHD (2560x1440)
- Night Vision: Enhanced color night vision with 4 IR LEDs and 2 white spotlight LEDs
- Field of View: Wide angles (DFOV 115.8°, HFOV 98.5°, VFOV 53.1°)
- Audio: Improved 2-way audio for clear communication
- Connectivity: Wi-Fi 6 support, Alexa and Google Assistant compatible
- Storage: Supports up to 128GB microSD card for local recording
- Mounting Options: Stand, wall, ceiling, magnetic adhesive
This camera is perfect for monitoring your yard, front porch, or any vulnerable area around your home, providing crystal-clear video day and night.
Wyze Cam v4 keeps watch over your property day and night
The Front Porch Security Bundle: Complete Smart Home Entry Protection
All-in-One Solution for Front Door Security
The Front Porch Security Bundle combines the Wyze Video Doorbell, Wyze Lock, and Wyze Chime to give you full control and visibility of your front entrance. With 1080p HD video and two-way audio, you can see and speak to visitors from anywhere.
Wyze Video Doorbell:
- 1080p HD video with 120° vertical and 88° horizontal field of view
- Two-way audio with noise and echo cancellation
- Infrared night vision and daylight white LEDs
- Weather-resistant (IP65)
Wyze Lock:
- Remote lock/unlock via app
- View lock history and receive notifications
- Bluetooth and Zigbee communication
- Battery life of 5-6 months
Wyze Chime:
- Multiple sound options including intruder alarm
- Easy plug-in installation
This bundle is ideal for securing your front porch, allowing you to monitor visitors, control access, and receive alerts in real-time.
Why Combine the Wyze Security Yard Sign with Wyze Cameras and Bundles?
A visible security yard sign acts as a powerful deterrent, signaling to potential intruders that your home is protected by advanced surveillance technology. When paired with Wyze’s smart cameras and security bundles, you create a layered defense system that not only monitors but actively discourages crime.
By integrating the Wyze Security Yard Sign with the Wyze Cam v4 or the Front Porch Security Bundle, you enhance your home’s security presence both visually and technologically.
Summary of Key Products for Enhanced Home Surveillance
Product | Key Features | Price (USD) |
Wyze Security Yard Sign | Durable aluminum, reflective, weatherproof | $16.99 - $22.98 |
Wyze Cam v4 Home Security Bundle | 2.5K QHD, color night vision, motion spotlight | $169.99 |
Front Porch Security Bundle | Video doorbell, smart lock, chime, 1080p HD | $123.99 - $173.97 |
Enhance your home surveillance today with the Wyze Security Yard Sign and complement it with Wyze’s smart cameras and security bundles for a safer, smarter home.
What is the Wyze Security Yard Sign and how does it enhance home security?
The Wyze Security Yard Sign is a highly visible, weatherproof sign made from durable aluminum. It serves as a crime deterrent by warning potential intruders that your property is monitored by Wyze security systems. When paired with Wyze cameras and smart home bundles, it creates a comprehensive and layered home security solution.What materials and features make the Wyze Security Yard Sign durable?
The Wyze Security Yard Sign is crafted from tough aluminum, making it weatherproof and fade-resistant. Its reflective blue surface ensures high visibility both day and night, and it is designed to withstand all outdoor conditions.What are the dimensions and installation details of the Wyze Security Yard Sign?
The Wyze Security Yard Sign has a combined length of 30 inches, with the shield and metal support pole measuring 12 inches wide by 16 inches long, and the metal pole measuring 14 inches long. It comes with an aluminum stake and an installation kit for easy setup.What is included in the Wyze Security Yard Sign package?
The package includes one Wyze yard sign, one aluminum stake, and one installation kit, providing everything needed for quick and easy installation.How does the Wyze Cam v4 Home Security Bundle improve home surveillance?
The Wyze Cam v4 Home Security Bundle features a 2.5K QHD camera with enhanced color night vision, weather resistance (IP65), motion-activated spotlight, and improved two-way audio. It supports Wi-Fi 6, works with Alexa and Google Assistant, and offers flexible mounting options for comprehensive indoor and outdoor monitoring.What are the key features of the Wyze Cam v4 for day and night security?
The Wyze Cam v4 offers 2.5K QHD resolution, enhanced color night vision with 4 IR LEDs and 2 white spotlight LEDs, a wide field of view, improved two-way audio, and weather resistance. It also supports up to 128GB microSD card for local recording and can be mounted in various ways.What does the Front Porch Security Bundle include and how does it protect my entryway?
The Front Porch Security Bundle includes the Wyze Video Doorbell (with 1080p HD video, two-way audio, and night vision), Wyze Lock (remote lock/unlock, notifications, and Bluetooth/Zigbee communication), and Wyze Chime (multiple sound options and easy installation). This bundle provides complete control and visibility over your front entrance.How does combining the Wyze Security Yard Sign with Wyze cameras and bundles improve home security?
Combining the Wyze Security Yard Sign with Wyze cameras and security bundles creates a layered defense system. The visible sign deters intruders, while the advanced cameras and smart devices provide real-time monitoring, alerts, and control, making your home less attractive to criminals.Are Wyze security products weatherproof and suitable for outdoor use?
Yes, both the Wyze Security Yard Sign and Wyze Cam v4 are designed to be weatherproof and durable, making them ideal for outdoor use in various weather conditions.What are the prices of Wyze home security products?
The Wyze Security Yard Sign is priced between $16.99 and $22.98, the Wyze Cam v4 Home Security Bundle is $169.99, and the Front Porch Security Bundle ranges from $123.99 to $173.97.
