Wyze S Cordless Vacuum Extra Battery Pack for Longer Cleaning
Wyze S Cordless Vacuum Extra Battery Pack Upgrade for Extended Cleaning Performance
If you're looking to enhance your Wyze S Cordless Vacuum experience with an extra battery pack, you're on the right track to achieving longer, uninterrupted cleaning sessions. The Wyze Cordless Vacuum S is already a powerhouse with its impressive suction and lightweight design, and adding an extra battery pack will take your cleaning performance to the next level.
Why Choose Wyze Cordless Vacuum S?
The Wyze Cordless Vacuum S is designed for freedom and efficiency, making it a top choice for those who want a powerful yet portable cleaning solution.
Powerful Suction and Lightweight Design
  • Suction Power: Up to 20,000 Pa in Turbo Mode, ensuring deep cleaning on carpets and hard floors.
  • Weight: Only 2.8 lbs for the main unit, making it easy to maneuver around furniture and tight spaces.
  • Dual Motors: Two motors work together to maximize cleaning efficiency.
  • Battery Life: A single 6-cell lithium-ion battery provides up to 40 minutes of runtime in ECO mode.
Advanced Features for Better Cleaning
  • 3-Stage Filtration System: Captures fine dust and allergens, improving air quality.
  • LED Screen: Displays battery life and suction mode for easy monitoring.
  • 6 Daylight-Bright LED Lights: Illuminate dark corners and under furniture for thorough cleaning.
  • Attachments Included: Crevice tool, floor brush, HEPA filter, and more for versatile cleaning tasks.
Battery Upgrade Benefits
Adding an extra battery pack to your Wyze Cordless Vacuum S means:
  • Extended Cleaning Time: Swap batteries on the go to clean larger areas without waiting for a recharge.
  • Convenience: Keep one battery charging while using the other.
  • Maximized Productivity: Perfect for busy households or larger homes.
Experience the freedom of cordless cleaning with the power and endurance you need.
Wyze Cordless Vacuum S in action with pet Lightweight and pet-friendly cleaning with Wyze Cordless Vacuum S
Product Specifications at a Glance
FeatureSpecification
Suction Power100 AW (Normal), 20,000 Pa (Turbo)
Battery Type6-cell Lithium-ion
Battery Capacity2,000mAh*6
Runtime40 min (ECO), 23 min (Medium), 10 min (Turbo)
Weight2.8 lbs (main unit), 4.9 lbs (assembled)
Dust Cup Volume0.7 L
Noise Level65 dBA (Turbo Mode)
Charging Time4-6 hours
Dimensions (Main Unit)12.4 x 4.5 x 8.7 inches
Operating Temperature-4ºF to 169ºF
Enhance Your Cleaning Setup with Wyze Smart Home Products
While focusing on the Wyze Cordless Vacuum S and its battery upgrade, consider complementing your smart home ecosystem with Wyze’s other innovative products:
Wyze Cam v4 – Smart Home Security and Monitoring
  • 2.5K QHD Video Resolution: Crystal-clear video for indoor or outdoor use.
  • Color Night Vision: See in full color even in low light.
  • Weather Resistant: IP65 rating for durability.
  • Smart Integrations: Works with Alexa, Google Assistant, and IFTTT.
Whole Home Security Starter Kit
  • Includes Wyze Cam v4, Wyze Video Doorbell v2, and Home Monitoring Starter Kit.
  • Provides comprehensive home security with easy setup.
These products help you maintain a clean, safe, and smart home environment. Wyze Cam v4 mounted outdoors Wyze Cam v4 enhances home security alongside your cleaning routine
Conclusion
Upgrading your Wyze Cordless Vacuum S with an extra battery pack is the perfect way to extend your cleaning sessions and maintain a spotless home without interruption. With its powerful suction, lightweight design, and smart features, the Wyze Cordless Vacuum S stands out as a top choice for efficient home cleaning. Pair it with Wyze’s smart home security products for a connected lifestyle that keeps your home clean, safe, and smart. Wyze Cordless Vacuum S lifestyle cleaning Enjoy hassle-free cleaning with Wyze Cordless Vacuum S and extra battery power
What are the benefits of upgrading my Wyze Cordless Vacuum S with an extra battery pack?Upgrading your Wyze Cordless Vacuum S with an extra battery pack allows for extended cleaning sessions without interruption. You can swap batteries on the go, clean larger areas without waiting for a recharge, and maximize productivity—especially useful for busy households or larger homes.
How long does the Wyze Cordless Vacuum S battery last on a single charge?The Wyze Cordless Vacuum S provides up to 40 minutes of runtime in ECO mode, 23 minutes in Medium mode, and 10 minutes in Turbo mode on a single 6-cell lithium-ion battery.
How powerful is the Wyze Cordless Vacuum S?The Wyze Cordless Vacuum S delivers up to 20,000 Pa of suction power in Turbo Mode and 100 AW in Normal Mode, making it effective for deep cleaning on both carpets and hard floors.
Is the Wyze Cordless Vacuum S lightweight and easy to use?Yes, the main unit of the Wyze Cordless Vacuum S weighs only 2.8 lbs, making it easy to maneuver around furniture and tight spaces for hassle-free cleaning.
What advanced features does the Wyze Cordless Vacuum S offer?The Wyze Cordless Vacuum S features a 3-stage filtration system to capture fine dust and allergens, an LED screen for battery and suction mode monitoring, 6 daylight-bright LED lights for cleaning dark areas, and multiple attachments including a crevice tool, floor brush, and HEPA filter.
How long does it take to fully charge the Wyze Cordless Vacuum S battery?It takes approximately 4 to 6 hours to fully charge the Wyze Cordless Vacuum S battery.
What is the dust cup capacity of the Wyze Cordless Vacuum S?The Wyze Cordless Vacuum S has a dust cup volume of 0.7 liters, allowing for efficient cleaning before needing to empty the container.
Can I use the Wyze Cordless Vacuum S for pet hair and allergen removal?Yes, the Wyze Cordless Vacuum S is pet-friendly and equipped with a 3-stage filtration system, including a HEPA filter, to effectively capture pet hair, fine dust, and allergens.
What are the dimensions and weight of the Wyze Cordless Vacuum S?The main unit of the Wyze Cordless Vacuum S measures 12.4 x 4.5 x 8.7 inches and weighs 2.8 lbs. When fully assembled, it weighs 4.9 lbs.
What other Wyze smart home products complement the Wyze Cordless Vacuum S?Wyze offers a range of smart home products that complement the Wyze Cordless Vacuum S, including the Wyze Cam v4 for home security and monitoring, and the Whole Home Security Starter Kit, which includes a Wyze Cam v4, Wyze Video Doorbell v2, and Home Monitoring Starter Kit.
Can you tell me more about the features of the Wyze Cam v4?What is the runtime of the Wyze S Cordless Vacuum in different modes?Do you have any deals, ongoing sales, discounts, or promotions for the Wyze products?
