Our Wyze Home Monitoring System is designed to provide comprehensive security for your home with a variety of sensors and devices. Here's a breakdown of the sensor capacity and features:
- Wyze Sense Hub: This is the central component of the system, supporting up to 100 sensors. It connects all monitoring components and sends alerts, ensuring seamless communication within your home security setup.
- Wyze Sense Motion Sensor: Detects motion with a range of up to 25 feet and a 120° field of view. It's designed for indoor use and requires the Wyze Sense Hub.
- Wyze Sense Entry Sensor: Monitors when doors or windows open or close. It has a detection range of up to 500 feet and is also compatible with the Wyze Sense Hub.
- Wyze Sense Climate Sensor: Tracks temperature and humidity in your home. It has a 500 ft range and can be placed in various locations like basements or attics.
- Wyze Sense Leak Sensor & Probe: Alerts you to leaks, with a sensor range of up to 500 feet. It can differentiate between the leak sensor and the probe for precise notifications.
- Wyze Sense Keypad: Allows you to arm and disarm your system remotely. It includes an emergency alarm button for added security.
These components work together to provide a robust home monitoring solution, ensuring your home is secure and monitored effectively.
