The Wyze Climate Sensor is designed for indoor use only. It is not suitable for outdoor environments due to its weather resistance specifications. Here are some key features of the Wyze Climate Sensor:
- Indoor Use Only: The sensor is designed to operate within a temperature range of 32°F to 104°F (0°C to 40°C) and a humidity level of ≤ 85% at 86°F (30°C).
- Temperature and Humidity Tracking: It allows you to monitor the temperature and humidity in various rooms of your home through the Wyze app.
- 500 ft Range: You can place it in distant rooms, basements, or attics, thanks to its extensive range.
- Sleek Design: The sensor has a sleek, white design that blends seamlessly into any environment.
- Easy Installation: It can be set on any surface or mounted on walls using the peel-and-stick adhesive backing.
For outdoor monitoring needs, you might want to explore other products that are specifically designed for outdoor use.
