How to Adjust Volume on Wyze Chime Pro: A Complete Guide
To adjust the volume of your Wyze Chime Pro, you can easily do so through the Wyze app. Simply navigate to the Doorbell Settings, then select Accessories. From there, you can tap on your Wyze Video Doorbell, access the Settings icon, and choose Accessories > Chime > Tunes. You can then adjust the volume by tapping and dragging the slider to your desired level. This feature allows you to customize the sound level to suit your preferences, ensuring you never miss a visitor.
How do I change the sound of my Wyze Chime?Can I customize the tunes for my Wyze Chime?Is there a way to reset the Wyze Chime Pro if I encounter issues?
