Wyze Charging Dock: Camera Battery Full Charge Time Explained
The Wyze Battery Charging Dock is a convenient solution for charging your Wyze Battery Cam Pro's removable battery packs. When using the Wyze Battery Charging Dock, it takes approximately 8 hours and 30 minutes to fully charge a battery from 0% to 100%. This is slightly faster than using the included USB-C to USB-A charging cable, which takes about 9 hours. The charging dock allows you to charge up to two batteries simultaneously, ensuring that your camera is always ready for use. Please note that the Wyze Battery Charging Dock is sold separately and includes a power adapter.
Feature | Wyze Battery Charging Dock | Wyze Battery Cam Pro |
Type | Accessories | Cameras |
Description | Charge two batteries simultaneously | 2.5K HDR Video Resolution, Wire-Free, Integrated Spotlight & Siren |
Price | $17.99 | Starting at $89.98 |
Stock Availability | Available | Available in various options |
Charging Time | Approximately 8.5 hours | Approximately 9 hours |
Compatibility | Wyze Battery Cam Pro's battery packs | Removable, Rechargeable Battery Packs |
Wi-Fi Support | N/A | 2.4 & 5 GHz WiFi Support |
Weather Resistance | N/A | IP65 Weatherproof |
Battery Life | N/A | Up to 6 Months |
Collections | Best Sellers | New Arrivals, Best Sellers, Wyze Black Friday & Cyber Monday Sale |
Additional Features | Includes power adapter and USB-A to USB-C cable | Radar + PIR Motion Detection, Cloud Storage with Cam Plus |
How do I charge the Wyze Battery Cam Pro using the USB-C to USB-A charging cable?Can I charge the Wyze Battery Cam Pro battery while it is inside the camera?What are the different ways to charge the Wyze Battery Cam Pro?
