While the Wyze Cam v4 is not directly compatible with a solar panel, we offer the Wyze Lamp Socket, which can power the Wyze Cam v4 without the need for a traditional plug. Here are some key features of the Wyze Cam v4 and the Wyze Lamp Socket:
- Wyze Cam v4:
- Crystal-clear 2.5K QHD resolution for sharp video quality.
- Enhanced Color Night Vision for clear images even in low light.
- Motion-activated spotlight for added security.
- 24/7 local recording with support for microSD cards up to 512 GB.
- Compatible with Alexa and Google Assistant for voice control.
- Wyze Lamp Socket:
- Conveniently powers Wyze Cam v3/v4 without the need for extension cords.
- Converts standard bulbs into motion-activated security lights.
- Wirelessly link up to 5 lamp sockets together.
- Dusk to dawn scheduling to automatically turn lights on at sunset and off at sunrise.
These products together can enhance your home security setup by providing flexible power options and advanced camera features.
