The Wyze Cam v4 is an excellent choice for those looking to enhance their home security with advanced features. Here are some key highlights of the Wyze Cam v4 that make it a great option:
- Motion Detection Zones: Customize specific areas to monitor for motion, ensuring you only receive alerts for the areas that matter most to you.
- 2.5K QHD Resolution: Enjoy crystal-clear video quality with 2.5K QHD resolution, providing detailed and sharp images.
- Enhanced Color Night Vision: Keep your home safe day or night with enhanced color night vision, allowing you to see clearly even in low-light conditions.
- Motion-Activated Spotlight: The built-in spotlight enhances security by illuminating the area when motion is detected.
- 24/7 Local Recording: With support for microSD cards up to 512 GB, you can record continuously and access your footage anytime.
- Smart Home Compatibility: Works seamlessly with Alexa and Google Assistant for convenient voice control.
These features make the Wyze Cam v4 a versatile and reliable choice for your home security needs.
