Discover Compatible Accessories for Wyze Cam v4
We are pleased to offer a range of accessories compatible with the Wyze Cam v4 to enhance your security setup:
  • Wyze Lamp Socket: This accessory allows you to power your Wyze Cam v4 without the need for a plug. It features motion-activated lights and can wirelessly link up to 5 lamp sockets together. It also supports dusk to dawn scheduling, automatically turning your lights on at sunset and off at sunrise. The installation is as simple as screwing in a light bulb, making it a convenient addition to your home security system.
These accessories are designed to work seamlessly with your Wyze Cam v4, providing added functionality and convenience.
FeatureWyze Cam v4Wyze Lamp Socket
TypeCameraCamera Accessory
Resolution2.5K QHD (2560x1440)N/A
Night VisionEnhanced Color Night VisionConverts standard bulbs into motion-activated security lights
Weather ResistanceIP65 weather resistantNot weatherproof or waterproof, suitable for damp locations
PowerWired via USB cablePowers Wyze Cam v3/v4 without a plug
ConnectivityWi-Fi 2.4 GHz, Wi-Fi 6, Bluetooth 5.2802.11 b/g/n, 2.4GHz, Bluetooth
IntegrationsAlexa, Google Assistant, IFTTTN/A
StorageLocal (microSD card up to 512 GB), Cloud (with subscription)N/A
Motion DetectionYes, with motion-activated spotlightYes, motion-activated lights
Dimensions2in x 2in x 2 3/8in56.5mm x 56.5mm x 65mm
Weight0.49 lb (222 g)80 g
Additional FeaturesBuilt-in siren, two-way talk, Smart Focus, 24/7 local recordingDusk to dawn scheduling, link up to 5 lamp sockets
Price$25.98 (1-Pack)$16.98 (1-Pack)
What other accessories are available for the Wyze Cam v4?Can you tell me more about the Wyze Lamp Socket and how it works?Are there any ongoing promotions or discounts for Wyze products?
Need help finding the perfect Wyze Cam? Check out our   Product Finder ✨
Shop with AI powered by Big Sur AI
