Wyze Cam Pan v3 Review: dBrand Green Camo & Triple Black Skins
Wyze Cam Pan v3 Review: Elegant Green Camo & Triple Black dBrand Skins
The Wyze Cam Pan v3 is a versatile, weather-resistant security camera designed for both indoor and outdoor use. When paired with the stylish and protective dBrand skins in Elegant Green Camo and Triple Black, it not only enhances your home security but also adds a personalized, sleek look to your device. This review covers the key features of the Wyze Cam Pan v3, the benefits of the dBrand skins, and the value of the Cam Plus bundle.
Wyze Cam Pan v3: Cutting-Edge Security with 360° Coverage
Robust Design and Weather Resistance
The Wyze Cam Pan v3 is built to withstand the elements with a full IP65 weather resistance rating, making it perfect for outdoor installation when used with the Wyze Outdoor Power Adapter (sold separately). Its polycarbonate body and matte finish provide durability and a modern aesthetic.
  • Dimensions: 124mm (H) x 60mm (W) x 63mm (D)
  • Weight: 11.29 oz (320 g)
  • Material: Polycarbonate body with glass + plastic lens
  • IP Rating: IP65 for dust and water resistance
  • Operating Temperature: -20°C to 50°C (-4°F to 122°F)
<img src="https://www.wyze.com/cdn/shop/files/IMG_4216-5_1.jpg?v=1670422469&width=1500" alt="Wyze Cam Pan v3 in snowy outdoor setting">
Wyze Cam Pan v3 weather-resistant for outdoor use
Superior Video and Audio Capabilities
Equipped with a 1/2.9" CMOS image sensor, the camera delivers crisp 1080p Full HD video with smooth frame rates of 20 fps during the day and 15 fps at night. The 120° field of view combined with 360° horizontal and 180° vertical rotation ensures no blind spots.
  • Night Vision: 4 IR LEDs (850 nm) for clear black-and-white night vision
  • Digital Zoom: 8x zoom for detailed monitoring
  • Audio: Built-in speaker and microphone with 2-way audio, noise and echo cancellation
  • Alerts: Instant push notifications for motion or sound detection
Smart Home Integration
The Wyze Cam Pan v3 seamlessly integrates with popular smart home platforms including Alexa, Google Assistant, and IFTTT, allowing voice control and automation.
dBrand Skins for Wyze Cam Pan v3: Elegant Green Camo & Triple Black
Personalize and Protect Your Camera
The dBrand skins offer a stylish vinyl wrap that not only transforms the look of your Wyze Cam Pan v3 but also protects it from scratches and minor wear.
  • Styles Available: Elegant Green Camo, Triple Black
  • Material: High-quality, precision-cut vinyl for a flawless fit
  • Application: Easy to apply with included instructions; use a hair dryer for best results
  • Protection: Helps prevent scratches and keeps your camera looking new
These skins are perfect for users who want their security camera to blend into outdoor environments with the green camo or maintain a sleek, stealthy appearance with the triple black finish.
Wyze Cam Pan v3 + 30-Day Cam Plus Bundle: Enhanced Security Experience
What’s Included?
This bundle pairs the Wyze Cam Pan v3 with a 30-day trial of Cam Plus, Wyze’s advanced cloud service that unlocks additional features such as person detection, package detection, and unlimited event video length. Bundle Contents:
  • 1x Wyze Cam Pan v3 (Black or White)
  • 1x 6' Micro USB Cable
  • 1x Power Adapter
  • 1x Mounting Kit
  • 1x Quick Start Guide
  • 30-Day Cam Plus subscription
Benefits of Cam Plus
  • Extended event video recording without time limits
  • Enhanced AI detection for more accurate alerts
  • Access to cloud storage for easy video review
Why Choose Wyze Cam Pan v3 with dBrand Skins?
  • All-Weather Durability: Perfect for outdoor use with IP65 rating
  • Complete Coverage: 360° pan and 180° tilt for full room or yard monitoring
  • Clear Video & Audio: 1080p HD with two-way talk and night vision
  • Customizable Look: dBrand skins in green camo or triple black to match your style
  • Smart Home Ready: Works with Alexa, Google Assistant, and IFTTT
  • Expandable Storage: Supports up to 256 GB microSD cards
Whether you want a rugged outdoor camera or a stylish indoor security solution, the Wyze Cam Pan v3 combined with dBrand skins offers both functionality and flair.
Summary
The Wyze Cam Pan v3 stands out as a feature-rich, affordable security camera suitable for a variety of environments. Adding the dBrand skins in Elegant Green Camo or Triple Black not only personalizes your device but also protects it from everyday wear. For those seeking enhanced monitoring capabilities, the 30-day Cam Plus bundle is an excellent choice to unlock premium features.
Elevate your home security with Wyze Cam Pan v3 — smart, stylish, and ready for any setting.
Wyze Cam Pan v3 two-way audio lifestyle Enjoy clear two-way communication with Wyze Cam Pan v3
FeatureWyze Cam Pan v3Wyze Cam Pan v3 Skins by dBrand (Skin Only)Wyze Cam Pan v3 + 30-Day Cam Plus Bundle
TypeCameraAccessory (Skin Only)Camera Bundle
DescriptionRedesigned indoor/outdoor 360° pan & 180° tilt security camera, IP65 weather resistant. Requires Wyze Outdoor Power Adapter for outdoor use.Vinyl skins to customize and protect Wyze Cam Pan v3Wyze Cam Pan v3 with 30-day free Cam Plus subscription
Color OptionsBlack, WhiteGreen Camo, Triple BlackBlack, White
Pack Options1 Pack, 2 Pack, 3 PackSingle skinSingle camera
Price$39.98 (1 Pack), $77.96 (2 Pack), $114.94 (3 Pack)$11.98$39.98
Weather ResistanceIP65N/AIP65
Pan & Tilt Range360° horizontal, 180° verticalN/A360° horizontal, 180° vertical
Video Resolution1080p (1920 x 1080)N/A1080p (1920 x 1080)
Night VisionColor Night Vision with Starlight SensorN/AColor Night Vision with Starlight Sensor
Audio FeaturesTwo-way audio, built-in speaker & microphoneN/ATwo-way audio, built-in speaker & microphone
Motion TrackingAutomatic motion tracking with quiet motorN/AAutomatic motion tracking with quiet motor
Privacy ModeYesN/AYes
Connectivity802.11 b/g/n 2.4GHz Wi-Fi (no 5GHz)N/A802.11 b/g/n 2.4GHz Wi-Fi (no 5GHz)
StorageSupports up to 256GB microSD (ExFAT format)N/ASupports up to 256GB microSD (ExFAT format)
Included ItemsCamera, 6' micro USB cable, power adapter, mounting kit, quick start guideSkin onlyCamera, 6' micro USB cable, power adapter, mounting kit, quick start guide
Subscription IncludedNoNo30-day free Cam Plus (auto-renews $2.99/month/cam)
Cam Plus FeaturesOptionalN/AUnlimited event video cloud storage, advanced notifications
Warranty1 Year30-day hassle-free returns1 Year
What are the key features of the Wyze Cam Pan v3 security camera?The Wyze Cam Pan v3 offers 360° horizontal and 180° vertical rotation for complete coverage, 1080p Full HD video, night vision with 4 IR LEDs, two-way audio with noise and echo cancellation, instant motion and sound alerts, and an IP65 weather resistance rating for both indoor and outdoor use.
Is the Wyze Cam Pan v3 weather-resistant and suitable for outdoor use?Yes, the Wyze Cam Pan v3 is IP65 weather-resistant, making it suitable for outdoor installation when used with the Wyze Outdoor Power Adapter (sold separately). It is designed to withstand dust, rain, and extreme temperatures from -20°C to 50°C (-4°F to 122°F).
What are dBrand skins for Wyze Cam Pan v3 and what styles are available?dBrand skins are high-quality, precision-cut vinyl wraps designed to personalize and protect your Wyze Cam Pan v3. They are available in Elegant Green Camo for blending into outdoor environments and Triple Black for a sleek, stealthy look.
How do dBrand skins protect the Wyze Cam Pan v3?dBrand skins help protect your Wyze Cam Pan v3 from scratches and minor wear, keeping your camera looking new while adding a personalized touch.
How easy is it to apply dBrand skins to the Wyze Cam Pan v3?Applying dBrand skins is simple and comes with easy-to-follow instructions. For best results, use a hair dryer during application to ensure a flawless fit.
What is included in the Wyze Cam Pan v3 + 30-Day Cam Plus bundle?The bundle includes one Wyze Cam Pan v3 (Black or White), a 6' Micro USB cable, a power adapter, a mounting kit, a quick start guide, and a 30-day Cam Plus subscription for advanced cloud features.
What are the benefits of the Cam Plus subscription with Wyze Cam Pan v3?Cam Plus unlocks advanced features such as unlimited event video recording, enhanced AI detection for people and packages, and access to cloud storage for easy video review.
Does the Wyze Cam Pan v3 support smart home integration?Yes, the Wyze Cam Pan v3 integrates seamlessly with Alexa, Google Assistant, and IFTTT, allowing for voice control and smart home automation.
What storage options are available for the Wyze Cam Pan v3?The Wyze Cam Pan v3 supports expandable storage with microSD cards up to 256 GB, allowing for continuous local video recording.
Why should I choose Wyze Cam Pan v3 with dBrand skins?Choosing Wyze Cam Pan v3 with dBrand skins provides all-weather durability, complete 360° coverage, clear 1080p HD video and two-way audio, customizable appearance, smart home compatibility, and protection against scratches and wear.
What are the key features of the Wyze Cam Pan v3?How does the dBrand skin protect the Wyze Cam Pan v3?Do you have any deals, ongoing sales, discounts, or promotions?
