Explore Connectivity Options for Wyze Cam Pan v3
The Wyze Cam Pan v3 offers reliable connectivity options to ensure seamless operation. Here are the key connectivity features:
  • Wi-Fi Compatibility: The Wyze Cam Pan v3 supports 802.11 b/g/n and operates on a 2.4 GHz Wi-Fi frequency. Please note that it does not support 5 GHz Wi-Fi networks.
  • Phone Compatibility: It is compatible with Android 9.0+ and iOS 15.0+ devices, allowing you to easily control and monitor the camera through the Wyze app.
  • Smart Integrations: The camera integrates with popular smart home systems, including Alexa, Google Assistant, and IFTTT, enabling voice control and automation.
These features make the Wyze Cam Pan v3 a versatile choice for both indoor and outdoor security needs.
What are the smart home systems that the Wyze Cam Pan v3 integrates with?Can the Wyze Cam Pan v3 be used outdoors without any additional accessories?Is there a warranty policy for the Wyze Cam Pan v3?
Need help finding the perfect Wyze Cam? Check out our   Product Finder ✨
Shop with AI powered by Big Sur AI
