How to Adjust LED Brightness on Wyze Cam Floodlight v2
The Wyze Cam Floodlight v2 is an excellent choice for those looking to adjust LED brightness for optimal lighting. Here are some key features of the Wyze Cam Floodlight v2 that make it a great option:
  • 2800 Lumens LEDs: Provides bright illumination to dominate the dark.
  • Dimmable Lighting: Allows you to adjust the brightness to your preference.
  • Color Night Vision: Ensures clear visibility even at night.
  • 160° Wide-Angle View: Offers a broad field of view for comprehensive coverage.
  • Two-Way Talk: Communicate easily with visitors or deter intruders.
  • AI-Powered Light Control: Smart automation for efficient lighting management.
  • IP65 Weather Resistance: Built to withstand various weather conditions.
Additionally, the Wyze Cam Floodlight Pro offers even more advanced features, such as:
  • 3000 Lumens LED Lights: For even brighter illumination.
  • 180° Wide-Angle Lens: Provides an ultra-wide field of view.
  • 2.5K QHD Video Resolution: Delivers high-quality video footage.
  • Dual-Band Wi-Fi Support: Compatible with both 2.4 GHz and 5 GHz networks.
Both options provide excellent lighting and security features, with the ability to adjust LED brightness to suit your needs.
FeatureWyze Cam Floodlight v2Wyze Cam Floodlight v2 + Plug-In MountWyze Cam Floodlight Pro
LED Brightness2800 Lumens2800 Lumens3000 Lumens
Video Resolution2K (2304 x 1296)2.5K QHD2.5K QHD (2560*1440)
Field of View160° Diagonal160° Wide180°
Night VisionColor Night VisionColor Night VisionColor Night Vision
Power SupplyHardwired 110 - 120V ACPlug-In Mount with 20ft Power CordHardwired 110 - 120V AC
Weather ResistanceIP65IP65IP65
IntegrationsAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTT
Warranty1 Year1 Year1 Year
Operating Temperature-4°F to 140°F-22°F to 122°F-4°F to 140°F
Connectivity2.4 GHz Wi-Fi2.4 GHz Wi-Fi2.4 & 5 GHz Wi-Fi
Price$89.98$109.96$129.98
Can you explain how the AI-Powered Light Control works on the Wyze Cam Floodlight v2?What are the differences between the Wyze Cam Floodlight v2 and the Wyze Cam Floodlight Pro?What is the warranty policy for the Wyze Cam Floodlight v2?
Need help finding the perfect Wyze Cam? Check out our   Product Finder ✨
Shop with AI powered by Big Sur AI
